Old Nov 17, 2011, 07:44 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Originally Posted by Killab View Post
got the motor installed, I noticed though that the fan stick out of the shroud is that normal,
Now I understand , that is the Freewing rotor it should have had its own collar/collet to connect to the shaft on your old motor. As long as the old stock motor was 3mm shaft you can use it on the new motor, just remove the rotor plug on the motor I sent you with either a gear puller or with heat from a lighter (about 20 seconds worth on the aluminum part only) then the plug will expand from the heat and will slip off the motor shaft. For some reason I thought the Stinger came with the EDO rotor and that is the adapter I installed on the motor. My mistake.
Don
The Don is offline Find More Posts by The Don
Old Nov 17, 2011, 08:21 PM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
Don
is it worth doing that or just buying a new rotor? I would hate to rune something i may need in the future.
Killab is offline Find More Posts by Killab
Old Nov 17, 2011, 08:28 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Your choice, you can always reinstall the EDO plug with some loctite down the road.
Don
Old Nov 17, 2011, 10:08 PM
Strike3 is offline
Find More Posts by Strike3
I don't want to land yet!
Joined Jan 2010
what is the difference between the hawk edf and the stinger? also can you explain cutting it down to three blades. Can this be done with the stock set up?
Just did my first flight today, have a wicked 4000 in it on stock fan and upgraded esc to a eflite 40a i had around. So thinking of going 4s soon.
Should go really well on 4s Will that 40A ESC be enough for 4s??? ...good to have a little safety margin I think too!
The Stinger stock motor is 2627 4300kv with a 5 blade fan... you can't cut it back to 3 blades because it will be uneven.
The T45 Hawk from HK has a B3830 4300kv as stock motor with a 6 blade fan... which you can cut back to 3 blades if you want higher top end and lower amp draw(longer flight times), this is what I have put in my Stinger on 4s 2650's... for now at least!
Strike3 is offline Find More Posts by Strike3
Old Nov 17, 2011, 11:56 PM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
Dave, tempted to buy one of these stinger64's for myself if my 4s 3000's will fit and run the same power combo as my hawk.
jim350 is offline Find More Posts by jim350
Old Nov 18, 2011, 12:02 AM
Strike3 is offline
Joined Jan 2010
Do it Jim... I'm sure you can handle it, flies pretty straight and true where you point it once it's setup.... that power system would make her boogie! 3000 4s might be a little heavy unless you cut a bit of foam to get it more aft of where mine sits. You can try one of your packs in mine if you like, see if it balances!
Old Nov 18, 2011, 12:38 AM
jim350 is offline
Joined Aug 2011
Sounds like a plan. You heading out for a flight tomorrow?
p.s. Tried the 4s 4000 in the hawk last night although i'm not sure about them. Not sure i like the extra weight.
Flew them back to back with my 4s 3000 and i prefer the flight characteristics with the 3000's.
I'll give them another go in some wind as it was quite calm last night.
Old Nov 18, 2011, 10:17 AM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
Have any of you flown this plane with constant winds of 10mph+ yet. With the hour change, flying time has been cut some, and therefore I'm willing to fly in heavier winds. I have a flew 1400mm Warbirds that can handle 15mph wind.
Harold
shelterock is offline Find More Posts by shelterock
Old Nov 18, 2011, 12:40 PM
Evan D is offline
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
I have and it handles wind OK.
Evan D is offline Find More Posts by Evan D
Old Nov 18, 2011, 04:49 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
Harold
i flew in about 15mph today it did ok when it gusted in the 20's it didn't have enough umf to get past it. but it tracked really nice.
sorry no camera man just my 808 on my hat.
HK Stinger 64mm (4 min 1 sec)
Old Nov 21, 2011, 07:16 AM
NCRealEstateGuy is online now
Find More Posts by NCRealEstateGuy
I Used To Have More Free Time!
Charlotte, NC
Joined Feb 2011
Can this plane be purchased from the US warehouse?
When I go to the US warehouse, am I still able to use the search function, just for the US warehouse? It seems to take me back to search results from the International warehouse. If this is the case, do I just have to scroll through everything until I find the plane?
On another note... a club member was flying one yesterday in 10mph winds with no trouble at all. It seemed to be able to fly slow as well as fast. Perfect for someone like myself who will make this there first EDF jet.
NCRealEstateGuy is online now Find More Posts by NCRealEstateGuy
Old Nov 21, 2011, 08:00 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
we kinda have a new fan candidate..
HET 64mm
http://www.highendrc.com/index_eprod...roducts_id=282
pavcon is offline Find More Posts by pavcon
Old Nov 21, 2011, 08:15 AM
jim350 is offline
Joined Aug 2011
HET 64mm
looks interesting. do you have any thrust figures for a given motor? eg: with a 2W-18 for instance.
Old Nov 21, 2011, 08:31 AM
pavcon is offline
Joined Jan 2010
no.. this is brand new.. but having experience with HET edf units.. I know I pushed their 70mm to the limits.. witha 4130kv hoffman magnetics the beast and 5s
I also know that they come balanced and they compare well to the wemos..their performance fihures are so identical but they work differently. the wemo though always has the edge but it costs far too much..
they don't have the whooshing sound but theyperform real well especially with higher kv motors and also won't give you tons of amp draw.
another plus is that you can find replacement parts.
Old Nov 21, 2011, 08:44 AM
RafterDodger is offline
Find More Posts by RafterDodger
ballin to keep from stallin ;)
RafterDodger's Avatar
United States, NC, Stanley
Joined Jul 2010
Thanks to a great motor from Wicked Don, this baby will haul on a 4S 2200...
This video was from Saturday, on Sunday we clocked it when i flattened it out of a dive over the runway at 106. Thanks for a WICKED setup DON!
Wicked Stinger 64 (2 min 22 sec)
RafterDodger is offline Find More Posts by RafterDodger
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1577 Jun 06, 2016 08:52 AM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 09:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
