Old Nov 11, 2011, 10:49 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Been nursing a hangover this morning - work dinner in town last night.
VJ's still waiting for servos to come in, then probably a couple of weeks? I'm building really slow at the moment for some reason.
How have those batts held up? The Stinger doesn't exactly have great cooling, and you've probably got more cycles on your packs than I do on mine now.
Odysis is offline Find More Posts by Odysis
Old Nov 11, 2011, 11:01 PM
Strike3 is offline
Find More Posts by Strike3
I don't want to land yet!
Joined Jan 2010
Yeah I think I will put some vents in the Stinger especially since the weather is warming up now...
Batteries are holding up alright, 1 has dropped low on a cell a couple of times but has come back pretty good... plenty of cycles now, using them in the Hawk as well... now have a 3300 35-70c from them too. It was on sale cheap, fits nice in the Hawk!
Strike3 is offline Find More Posts by Strike3
Old Nov 11, 2011, 11:07 PM
Odysis is offline
Joined May 2007
Sweet! I might have to get some more for the upcoming season.
I'm glad they didn't turn out to be junk!
Old Nov 12, 2011, 04:09 PM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
Ok so here is the story, I got my stinger in about 2 weeks ago and have been itching to fly it. I finally decide im going to give it a try, but for some reason the motor shuts down at half throttle. A few times it would go all the way to full, but after trying for hours to fix it. It finally goes to full throttle and shorts out sending a great fire ball of sparkes out the back of the plane..
So not im without a motor to run.. I need a motor i can get fast... Does anyone know of an eflite of something i can get locally?
PS why would the motor do this in the first place? I did swap my esc to a 40a eflite, but it tested fine on other motors so what the issue the motor the whole time?
Killab is offline Find More Posts by Killab
Old Nov 12, 2011, 04:12 PM
The Don is offline
Find More Posts by The Don
MA Indoor FreeFlight Columnist
Willoughby, Ohio
Joined Jan 2002
I can have a motor out to you on Monday if you cant find a local solution.
Don
The Don is offline Find More Posts by The Don
Old Nov 12, 2011, 04:22 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
these are the ones my hobby shop has
BL480 Ducted Fan Outrunner Motor, 4000Kv
Or
BL420 Ducted Fan Outrunner, 3800Kv
Will either of these fit the stock fan setup? Also Im currently running 3s, but may go 4s after i fly it some. This is my first edf.
Old Nov 12, 2011, 04:30 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
Don
Cool looking at your site now. Trying to find out what to get. I would like to have it by Wen.. Is that good?
Old Nov 12, 2011, 05:13 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
The Wicked 4000 with standoff and EDO plug will be the closest I have to stock power on 3S then you can also run on 4S if you want. You will have to remove the four molded plastic splines in the EDF housing to make the motor fit but that is easy to do, see link below:
http://www.rcgroups.com/forums/showp...9&postcount=37
I can ship it out on Monday, it is up to the post office after that
Old Nov 12, 2011, 05:24 PM
fooyukvoon is offline
Find More Posts by fooyukvoon
The Need4Speed
fooyukvoon's Avatar
Malaysia, Perak, Ipoh
Joined Aug 2008
After balancing the rotor with the E-flite V480 motor (4800kv) on 3S, with the setup installed in the fuse, I got :- 368W peak at approx 10.27V 38.xxAmps.
Having trouble making sure the rotor wont move round the adapter even after much tightening. Any suggestions on how to secure it properly. Would CA help?
Nd4spd
fooyukvoon is offline Find More Posts by fooyukvoon
Old Nov 12, 2011, 06:03 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
$ with shipping to 75070.
also is it the plus or cool wind motor?
Old Nov 12, 2011, 10:11 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
The website will calculate based on your zip code. It is between $3 and $ 6 depending on what service. The regular 4000 is fine. No need for the plus series especially if running on 3S. If you want more than stock power on 3S then get the 4800 KV it will be about 350-380 watts.
Old Nov 17, 2011, 03:06 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
got the motor installed, I noticed though that the fan stick out of the shroud is that normal, its like the standoff is too long? Did i miss something?
Also you said low timing for the motor, is this good?
Low Timing Advance dvance
Timing Degrees – 5 & 10
Motor Poles – 2 to 4
Expected Performance – Good balance of power and efficiency
Motor Poles – 6 or more
Expected Performance – Best efficiency and run time (lowest power)
Taken from my eflite esc manual.
Old Nov 17, 2011, 03:07 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
got her maidened today though, Flies nice...
How not to launch it
A different method.LOL
Old Nov 17, 2011, 07:04 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
Originally Posted by Strike3 View Post
Yeah Ody... I did one flight on 4s with the stock motor too but didn't continue to do anymore flights, I knew it would not handle it for long... saving that setup for something else and swapped the Hawk 64mm stock motor and cut down fan to 3 blades for the Stinger's power, no problems on 4s! Changed my ESC before any use at all...
Stock system goes pretty well though on 3s, if you use a good one with high discharge.
Are you bringing it out on the weekend?
what is the difference between the hawk edf and the stinger? also can you explain cutting it down to three blades. Can this be done with the stock set up?
Just did my first flight today, have a wicked 4000 in it on stock fan and upgraded esc to a eflite 40a i had around. So thinking of going 4s soon.
Old Nov 17, 2011, 07:16 PM
DumthumbsFRANKIE is offline
Find More Posts by DumthumbsFRANKIE
Flyin Acehole
DumthumbsFRANKIE's Avatar
USA, NJ, Glenwood
Joined Nov 2010
I have the 4000 plus on 4s... Its awsome...it will hover on ur fingertip with a 2200mah 4s in the cockpit. Makes for some quick passes in the trippel digits.. Only thing is 3 minute flights
DumthumbsFRANKIE is offline Find More Posts by DumthumbsFRANKIE
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1554 Nov 23, 2015 03:17 PM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 09:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
