Old Nov 04, 2011, 03:27 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Originally Posted by pavcon View Post
This is better: http://www.hobbyking.com/hobbyking/s...s%5F4s%5F.html
1.6kg of thrust
e_lm_70 is offline Find More Posts by e_lm_70
Old Nov 04, 2011, 03:42 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
there must be a mistake there..
you get 1.6kg of thrust ou of 1140watts while on the 5s you get 1482 with 1482watts??? typo mistake obviously
pavcon is offline Find More Posts by pavcon
Old Nov 04, 2011, 03:49 AM
e_lm_70 is offline
Austria
Joined Jan 2004
NO TYPO here.
4700kv motor with 4S .. spin faster then a 3700kv on 5S
Not by much BTW
Tchuss
e_lm_70
EDIT ...
Actually the number on the 5S unit are a bit off ... anyhow ...
The 5S @ 3700kv, should spin at around 74k rpm
The 4S @ 4700kv should spin at around 75k rpm
It is possible that the 5S is more efficient, and this will compensate the little less theoretical rpm ... but both unit should provide the same amount of power ... more or less
Old Nov 04, 2011, 04:51 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Originally Posted by e_lm_70 View Post
I would not believe chinese factory figures, the factory posted a video up of the fan and it was not all that fast in the air, and their thread on the fan died off rather quietly too.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Nov 04, 2011, 04:53 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Originally Posted by DumthumbsFRANKIE View Post
Don....i got your 4000plus setup ...its awsome on 3s ....just got some Gensace 4s 2200 packs and shes pulling 1060watts at 57 amps....why is the watts so high? You say it should only be around 600..... Im puzzled...am i at risk?
Either you are using 5 cell packs or your meter is waaaaay out and should be binned
1060w divided by 57A is 18.5 volts, that 5s under load, and you must have taken the reading a few seconds after banging the throttle open.
Old Nov 04, 2011, 06:33 AM
pavcon is offline
Joined Jan 2010
I cant believe that 1100watts can produce so much thrust.
Old Nov 04, 2011, 08:31 AM
e_lm_70 is offline
Austria
Joined Jan 2004
Why not ?
A 3D propeller plane, can do 2kg of thrust with less power ... with a speed of 100km/h
More or less .. power is equal to thrust x speed ... so .. it need to be known what is the air speed after this EDF ... assuming around 200km/h ... it can make sense 1100watts
Tchuss
e_lm_70
Old Nov 04, 2011, 09:10 AM
pavcon is offline
Joined Jan 2010
e lm.. don't compare propellers with edfs.
with my 780 watts 2.2kg F3A foamie I can do unlimited vertical. thatwould barely fly my rclander Panther
in the panther I'm getting 1100watts and I'm talking same cells same battery pack same ESC..
the efficiency of an EDF unit is much less also due to position
Old Nov 04, 2011, 09:12 AM
pavcon is offline
Joined Jan 2010
see?? now they corrected the 5cell one
I knew I was right
Old Nov 04, 2011, 09:36 AM
e_lm_70 is offline
Austria
Joined Jan 2004
I knew I was right
Either the kv is wrong .. or all the number there are just random.
A 5S @ 3700kv ... does not spin faster then 4S @ 4700kv
Power is connected to the RPM
Tchuss
e_lm_70
Old Nov 04, 2011, 11:26 AM
Evan D is offline
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Voltage is connected to the RPM.
Evan D is offline Find More Posts by Evan D
Old Nov 04, 2011, 11:34 AM
e_lm_70 is offline
Austria
Joined Jan 2004
I was speaking about output power .. this is a direct formula that is based on RPM, are pressure, etc etc (but not on voltage or ampers)
The kv is an extrapolation between rpm and input volts .. but ... the kv is relative accurate without load on the motor, under load, the motor will have less rpm as the kv would suggest.
Anyhow ... either the 3700kv motor with 5S is more efficient then the 4700kv motor with 4S ... or the kv numbers are not very accurate
Tchuss
e_lm_70
Old Nov 04, 2011, 01:31 PM
pavcon is offline
Joined Jan 2010
Tchuss
e_lm_70
there is always some loss. especially with high kv motors.
more voltage = more torque too
that was explained tome somehow but when I find it I will repost here
Old Nov 09, 2011, 07:53 AM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Hey guys. I would like to cover my Stinger with fiberglass cloth. Can I leave the pre-painted decals on and just cover then add the water base poly acrylic?
ridge_racer is offline Find More Posts by ridge_racer
Old Nov 09, 2011, 10:01 AM
pavcon is offline
Joined Jan 2010
yes you can...
btw can you remember my order..?? still havent' got it... 4 months +
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1591 Sep 05, 2016 06:48 PM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 09:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
