Old Sep 09, 2011, 08:53 AM
tdab is offline
Find More Posts by tdab
tracey=Col Frank Fitts
tdab's Avatar
Carolina's
Joined May 2004
Originally Posted by FusionTiger View Post
Is it true that the heavier the plane the better it will handle winds?
I do enjoy flight performence but when I had tried a lighter setup before, it got bullied by the wind. I'm not getting any fun with the wind playing with my plane for me.
I think slightly heavier will have better penetration through the air with less effect from wind but if it's too heavy then you might need a lot more throttle to keep it up. I am normally fine if an EDF will fly at 50% throttle on a fresh pack without losing altitude. If it will not do that, it could be underpowered or too heavy. That is nothing scientific as wing area, power system, jet size, airframe type, etc. will always vary. I have a few jets that need a little more throttle than that to fly decent, but it is something to shoot for. Personally I wouldn't go much heavier on a stinger than what I have at 26oz but again, that's just me. It would be too much like trying to land a brick!
tdab is offline Find More Posts by tdab
Old Sep 10, 2011, 03:32 PM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
I just tried 4S on the stock setup on the bench and got 41amps and 589 watts on the watt's meter. I noticed on my flight today the Fan still turns when the throttle is off. This causes the plane to slow down and I noticed it tends to stall in maneuvers during zero throttle due to this. Anybody have the programming instructions for the stock ESC?
davecrash is offline Find More Posts by davecrash
Old Sep 10, 2011, 07:53 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
You actually did not burn the stock ESC or motor with a 4s pack??
ridge_racer is offline Find More Posts by ridge_racer
Old Sep 10, 2011, 09:41 PM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
I only ran it up to full for a second or 2. I decided to put a larger ESC in it tonight but going to try the stock motor on a 4S flight.
Old Sep 11, 2011, 03:45 AM
FusionTiger is offline
Find More Posts by FusionTiger
Joined Dec 2007
I am eager to know the flight results! Had you done any temperature measurements during your bench tests?
FusionTiger is offline Find More Posts by FusionTiger
Old Sep 11, 2011, 03:46 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
nice... smoke show
pavcon is offline Find More Posts by pavcon
Old Sep 11, 2011, 07:45 AM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
Well I haven't seen anything on anybody running any of the stock stuff on 4S so I figured I would. obviously the ESC wont hold up so that got changed and the speed was only so so for me and I don't care if the motor frys as I have Don's 4000 just sitting here. I will do some temp readings on it. BTW the stock stuff on 3S was only 80F after landing
Old Sep 11, 2011, 01:27 PM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
Tried it on one of my Nano 4S 2200mah today. Got peak 47amps and 680 watts on the stock fan and motor, She flew awesome. After landing the highest temp I could get was 95f. I used a HK trust 55 ESC. had a slight problem that it stuttered on throttle up then went right to 1/4 throttle every time. Played with the settings but couldn't get rid of it. don't know yet if it's the ESC or the motor on 4S.
Old Sep 11, 2011, 01:32 PM
pavcon is offline
Joined Jan 2010
make sure your bullet connectors are ok
Old Sep 11, 2011, 03:04 PM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
Tried another motor and it was better but still did it a bit. Switched to the ESC from my Habu and all is good now. This thing rocks on 4S and the stock Motor.
Old Sep 11, 2011, 03:29 PM
pavcon is offline
Joined Jan 2010
guys
Ive got the stock 4s setup of my blitzrcworks f-16 tv if anyones interested. 15usd plus shipping. Esc motor and and an external bec
Old Sep 11, 2011, 04:32 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Check a few pages back, 4s is doable for a while...
What I saw with the stock esc on 4s was thermal proection would kick in. When the esc was replaced, it didn't cut out, so the motor was the weak point. 5 flights later - smoke trail!
I rewound with 8t (can't remember the gauge), and it's now done 20 more flights
Odysis is offline Find More Posts by Odysis
Old Sep 11, 2011, 07:56 PM
earaoz is offline
Find More Posts by earaoz
Winnipeg, Canada
Joined Apr 2007
Yes, nice smoke and fireworks show!
earaoz is offline Find More Posts by earaoz
Old Sep 13, 2011, 07:48 AM
Anda Inc. is offline
Find More Posts by Anda Inc.
Rc Fan From Belgium
Belgium, Flanders, Antwerp
Joined Feb 2011
I decided to take the plunge and ordered the red version from the germany warehouse today.
I have 2 cyclone setups coming my way also from philip at pw-rc.com.
One of those will go inside the stinger on 4s
Grts Dave
Anda Inc. is offline Find More Posts by Anda Inc.
Old Sep 13, 2011, 08:32 AM
earaoz is offline
Winnipeg, Canada
Joined Apr 2007
Retracts?
Anybody tried installing retracts? I know it is designed to go fast and you want minimum drag and extra weight but I think it might be doable without too much impact on performance. I don't like hand launching and I think take offs and landings are half of the fun so I am really hoping it can be done.
The plane is too small for electrics so it'll have to be done with the old mechanicals where lots of tinkering is required...
Comments? ideas?
E
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1589 Jul 13, 2016 05:57 PM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 09:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
