Old Aug 19, 2011, 11:38 AM
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Originally Posted by Tribal69 View Post
That came also in my mind but I got into the setup menu and for some reason the brake was ON instead of OFF so I changed that and now the motor is spinning up.
End good all good
Thanks to you guys helping me with ideas to solve the problem.
I fly helis and airplanes are completely new to me so any tips are very welcome.
First tip. Buy a good radio
Second tip. Crash and dont get dissappointed.. Everybody crashes
pavcon is offline Find More Posts by pavcon
Old Aug 19, 2011, 12:04 PM
choopi's Avatar
New Brunswick
Joined Feb 2006
Video of mine stock on 3s 78.5mph.
http://www.hobbyking.com/hobbyking/s...159feb011dfa38
HOBBYKING Stinger 64 (4 min 14 sec)
choopi is offline Find More Posts by choopi
Old Aug 19, 2011, 12:18 PM
Joined Jan 2010
yes but that's downwind
Old Aug 19, 2011, 12:22 PM
choopi's Avatar
New Brunswick
Joined Feb 2006
about 5mph wind! or 70 ish!
Old Aug 19, 2011, 12:27 PM
Joined Jan 2010
still.. not good enough.. it's a sports jet.. I got 103mph with my mini 50mm AMX on 4s stock everything but the fan
this is larger. I wanted more thats why I went 4s
Old Aug 19, 2011, 12:32 PM
choopi's Avatar
New Brunswick
Joined Feb 2006
I'm with you 100% to slow on the 3s config. my t45 50mm is 90mph. Slow but still fun. I will upgrade to 4s but I need to order a motor. What motor are you using?
Old Aug 19, 2011, 02:29 PM
Joined Jan 2010
Cyclone 4500kv
You can find it at x-flight
If you intent to use the stock fan please spend some time to balance it if you dont want your exhaust nozzle to throw up some blades i saw the stock fan when i got my arf and its kind of bendy.. Not stiff enough.
Btw if anyone wants it i will send. No cash needed just the shipping costs.
Oh i also have the stock fan of my f-16 tv from bh which is also 4s.. Good power and after i blown it on the first run my lhs balanced the fan for me so it runs real smooth
Old Aug 19, 2011, 02:30 PM
Joined Jan 2010
p.s. I wont be selling that but it would be a nice test bed. I think it was 32 amps and 480 watts or 516 watts.. Cant really recall
Old Aug 19, 2011, 03:52 PM
Sverige, Stockholms län, Täby
Made a video on my friends Stinger, really nice plan plane and fun to fly.
Original out of the box except the engine is changed to a HK2836 3500kv due to a 4s LiPo setup and HobbyWing 45A ESC. LiPo is Gensace 1800mah.
Hobbyking Stinger 64 EDF Sport Jet - 20110818 (6 min 29 sec)
blubberse is offline Find More Posts by blubberse
Old Aug 20, 2011, 06:44 AM
Cape Cod
Joined May 2007
I will have one of those.....I'll go stock on 3s at first. Great visibility for a dull sky. Very nice smooth flying, BTW. Hope HK gives you lots of points for that promo.
Will it land any slower than that? I think I might have cartwheeled it when it slewed.
muley is offline Find More Posts by muley
Old Aug 20, 2011, 10:37 AM
justy g's Avatar
Hong Kong
Joined Jan 2007
Blubberse..very nice video and flying..I want one
justy g is offline Find More Posts by justy g
Old Aug 20, 2011, 02:46 PM
lordsirob's Avatar
Joined Jul 2004
I got some 3s 1800 packs, and hand launching the Stinger is much much easier with the lighter setup (using 2200 3s packs before). If flys better with the lighter wing loading.
Now that I can hand launch consistently, I need another airframe to replace this poor bent, busted, glued, and band-aided monstrosity that used to look good!
lordsirob is offline Find More Posts by lordsirob
Old Aug 20, 2011, 07:15 PM
phoenix racing's Avatar
United Kingdom, England, Ipswich
Joined Mar 2007
I re-flew the stinger yesterday with a 1750mAh 3s pack, at first right up in the nose and it was nose-heavy! Moved it back around 10mm as I had for the original flightest and it was perfect, no trim shiny side up or inverted, I still think that lighter is the way to go, flies better and doesn't have elevator up-trim required that bleeds off speed.
phoenix racing is offline Find More Posts by phoenix racing
Old Aug 20, 2011, 07:58 PM
Joined Sep 2007
does anyone have pictures of a thrust tube for this plane? im still trying to figure out how to squeeze one in nicely without having to tear up any foam in the exhaust. the edf sits in a groove so sinking in a thrust tube by attaching it to the edf wont really work.
learninginverted is offline Find More Posts by learninginverted
Old Aug 20, 2011, 09:24 PM
Team Crash and Burn !!!!
tdab's Avatar
Carolina's
Joined May 2004
The easiest way to do it is to *carefully* take the fuse apart. Put the tube on the fan and again very carefully insert the whole unit back in and glue it back up. That is what I did. You can see the back of the tube in the pic.
Few other mods....I moved the linkages to the top of the wing, almost done with the puke green covering (my paint and decals were terrible)...The bottom will be black/white checkerboard. I also cut a slot behind the canopy to cool the ESC. I am using one of the linkage covers over the hole
I have one of Don's Wicked 4000's and some 4s2350's that fit nicely.
tdab is offline Find More Posts by tdab
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 117 May 14, 2013 05:03 AM
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1239 May 03, 2013 08:18 AM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
