Old Nov 24, 2012, 09:25 AM
proline1 is offline
Find More Posts by proline1
United States, NY, Syracuse
Joined Sep 2011
Regarding CG... Can anyone give latest update/opinion on the correct CG for this jet? I have mine stock with 1800 3S with the battery all the way forward and it balances perfectly at the recommended CG point. Most opinions say to balance further back at the rear of the finger holes. My Stinger actually flies pretty well as it is but just wondering what the
'further back" CG point will accomplish? Thanks much!
proline1 is offline Find More Posts by proline1
Old Nov 24, 2012, 02:38 PM
Evan D is offline
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
It lands better with the CG back to the rear of the finger holes.
Evan D is offline Find More Posts by Evan D
Old Nov 24, 2012, 03:55 PM
proline1 is offline
Joined Sep 2011
Mine has a tendency to catch the nose and cartwheel quite a bit but is not nose heavy at 70mm back from wing front. Does this help with that? Otherwise it seeks to fly pretty well. Thanks!
Old Nov 24, 2012, 08:01 PM
Evan D is offline
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Yes, it helps.
Old Nov 25, 2012, 04:43 PM
Eric Henderson is offline
Find More Posts by Eric Henderson
Eric Henderson's Avatar
United States, NV, Las Vegas
Joined Dec 2005
Originally Posted by LuvEvolution7 View Post
anytime. I will plug Dons products because I believe in them based on what I have in front of me.
I put Don's 64mm set-up in my Stinger and, to be honest, I was a bit intimidated. I used his 60A ESc as well. My first flight used 3S and I liked it. then I used 4S and I was caught out a couple of times for not starting my turns soon enough. had to work hard at keeping the airplane in view.
Bear in mind that I cut my flying-teeth on high speed slope racers and some pretty hot glow ships. Don's set-up was perfect right out of the box. The only hard part was soldering the ESC to the motor as he reccommends.
Get ready for a lot of questions from other electric speed fans! Even some, "How much do you want for it?" questions.
Regards,
Eric.
Eric Henderson is offline Find More Posts by Eric Henderson
Old Nov 25, 2012, 06:28 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
yeah, she's a totally different animal on 4S AND Dons setup. LOL.
as someone else said earlier, it became my go-to plane before she went in. just gotta get a new fuselage and I'm up and running again.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Nov 25, 2012, 08:07 PM
supercollider is offline
Find More Posts by supercollider
C.E.R.N. field tester
supercollider's Avatar
United States, NE
Joined Sep 2012
sweet
supercollider is offline Find More Posts by supercollider
Old Nov 28, 2012, 04:15 PM
Kurt is online now
Find More Posts by Kurt
Upstanding Member
Kurt's Avatar
United States, TX, Houston
Joined Sep 2003
After reconstructing the nose (for the second time) after a broken control horn broke - see write up one page back - and cutting a slot in the wing to move the linkages to the top (which should be standard IMO) thanks to mustflynow2's suggestion, my Stinger went back in the air last weekend for her 4th flight with Don's Wicked set-up.
Little windy out, maybe 5g15, and her tail was wagging around a bit but just as smooth and powerful as the previous flights. Would be interesting to use a gyro on RUD only, maybe I'll plug in my HK gyro next time.
Pics below of the linkage and decidedly broken looking nose
I'd be curious to see exactly how much more thrust Don's set-up produces compared to stock on 3S. For sure it's got more top end, but I flew her stock for over 10 batteries and don't notice THAT much more power after the switch. Probably due in large part to me becoming more confident flying her, but has anyone tested the actual thrust difference between stock and Don's on 4S?
The sound is MUCH smoother and more "turbine like" that's for sure!
cheers
Kurt
Kurt is online now Find More Posts by Kurt
Old Nov 28, 2012, 06:09 PM
United States, NE
Joined Sep 2012
cheers
Kurt
No more Concorde!
Old Nov 30, 2012, 04:26 AM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
I just put in Dons wicked setup and what a nice setup it is...As most of you know i use a wheelchair to get around. Winter months.are not my friend anymore Winter is my enemy.. so i have found a flying site i can stay in my car and fly (Isn`t 2.4 GHZ Great?!!) Anyways back to my story. ..Since i do not want landing gear....(actually Take off gear would be more correct) I stand it on end then park 10 -15 feet away and BLAST OFF!!! up she goes (always onto her back (reminds me of ,,,"Throttle up" ) i took out Two fans skipping it across the parking lot before Don`s Wicked .. motor fan combo...Thank you Don. this is a great setup...Now i just need to find one fr the new Great planes Phazer
Mal
kushal_22 is offline Find More Posts by kushal_22
Old Nov 30, 2012, 06:47 AM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Glad to hear you guys enjoying your Wicked powered Stingers! That VTO is something I have to try!
The Don is offline Find More Posts by The Don
Old Nov 30, 2012, 06:58 AM
malden86 is offline
Find More Posts by malden86
malden86's Avatar
San Antonio, TX.
Joined Feb 2009
I just got my Stinger yesterday and I was wondering in anyone is running the stock fan and motor on a 4 cell battery with an upgraded 40 or 50 amp ESC? I was thinking of running this set up but I am unsure if the stock fan or motor can take it, any help would be appreciated.
Thanks in advance.
malden86
malden86 is offline Find More Posts by malden86
Old Nov 30, 2012, 12:27 PM
Alpha10 is offline
Find More Posts by Alpha10
Alpha10's Avatar
United States, IL, Chicago
Joined Aug 2011
Thanks in advance.
malden86
The stock motor won't take it... Not for long at least.
Alpha10 is offline Find More Posts by Alpha10
Old Nov 30, 2012, 12:40 PM
malden86 is offline
malden86's Avatar
San Antonio, TX.
Joined Feb 2009
Thanks for the reply Alpha10.
Old Nov 30, 2012, 01:56 PM
Joined Jan 2009
it might last longer if you don't go full throttle all the time..........................but who can do that!? LOL.
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1589 Jul 13, 2016 05:57 PM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 09:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
