Old Oct 27, 2012, 12:36 PM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
I put a Turnagy 40 in mine have not flown it yet loking forward to some striaght up tail take offs though
kushal_22 is offline Find More Posts by kushal_22
Old Oct 28, 2012, 03:43 PM
KURTIST is offline
Find More Posts by KURTIST
ILLSMOQ
KURTIST's Avatar
United States, CA, San Jose
Joined Dec 2004
I ran the hobbyking mercury metal 64mm fan on 2200mah four cells. It's a blast to fly but nowhere near 160mph. We even put a Tamjet TJ70 fan unit with a 2500 mah 6 cell into a stinger and that wasn't even close to 160mph...maybe with a 30-40mph tailwind :-)
Originally Posted by LuvEvolution7 View Post
that 160 MPH Stinger is running on a 70mm fan. I believe it's the E-Flite fan. if you want a fast setup, you gotta draw large Amps, resulting in short flights. 65C+ packs are a must. I would be using a 100 Amp ESC with that setup too.
not calling the guy a lier, but that Stinger didn't look anything close to 160 MPH, but looks can be deceiving. if I didn't know any better, I would have said it was closer to 160 KPH, which is closer to 100 MPH. doppler would prove or disprove that video.
KURTIST is offline Find More Posts by KURTIST
Old Oct 28, 2012, 07:42 PM
kushal_22's Avatar
Kamloops
Joined Dec 2001
I was fooled for a hour or so...Till Don Chimed in...i have to say ..it ain`t no 160 but it is fast for a foamie.....i would be more than happy with a foamie with that performance
Old Nov 01, 2012, 12:39 PM
joallen001 is offline
Find More Posts by joallen001
Tennessee
Joined Dec 2005
With the stock motor is anything needed to hold the motor in? Or just let the fuselage and wing cutouts hold it in.
joallen001 is offline Find More Posts by joallen001
Old Nov 01, 2012, 01:23 PM
kushal_22's Avatar
Kamloops
Joined Dec 2001
I used a little dab of glue..Not too much as you may want/need to remove it
Mal
Old Nov 01, 2012, 01:28 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
glue or silicone will do the job. Velcro might also work well, if it's a tight fit already.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Nov 01, 2012, 11:04 PM
supercollider is offline
Find More Posts by supercollider
C.E.R.N. field tester
supercollider's Avatar
United States, NE
Joined Sep 2012
Hi all,
Not sure if we talked about this, but does anyone use any mixing on the stinger?
supercollider is offline Find More Posts by supercollider
Old Nov 01, 2012, 11:49 PM
Joined Jan 2009
I don't use any mixing, just a lot of expo.
I have noticed some adverse yaw with the Stinger, so some mixing might not be a bad thing at all. and of course, don't let the Stinger go slow. I think those upturned wing tips are responsible for making it do some nasty things. wonder how that modded wing did on solving that problem?
Old Nov 02, 2012, 09:37 AM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
I dont use any glue, just put the fan unit in and mount the wing. I am using Turnigy 2815 Kv4800 EDF outrunner, ~500 W on 3 cells, and fan stays in there without problem.
MagnusEl is offline Find More Posts by MagnusEl
Old Nov 02, 2012, 03:26 PM
dth7 is offline
Find More Posts by dth7
Back in the hobby- ALL in!
dth7's Avatar
United States, NH, Greenland
Joined Feb 2012
Originally Posted by The Don View Post
I also found this on the maker of the GPS speed logger, looks like they have a V2 of that logger and they say:
http://www.velocity-rc.com/cgi-bin/v...on=show&pid=59
"We have improved it with a newer processer which is both lighter and will give more accurate results than the original version." I wonder what speeds the original one gave
Don
Don, I don't want to claim anything here but I am definitely close to 100mph (WOT) with the new 4000 kv, a 50A esc and 1600-2200 4cells. Thanks. I'm running at 2/3 throttle and getting about 5 minutes.
Also does vertical takeoffs with ease. The first couple seconds are exciting til some airflow gets over the controls. Usually involves some low inverted work to get established. Fortunately we have a wide open field!
Thanks again for the motor.
dth7 is offline Find More Posts by dth7
Old Nov 02, 2012, 03:30 PM
dth7 is offline
dth7's Avatar
Joined Feb 2012
You can get this slower than you would think. I was surprised how it performs low and slow. Not as nice as my 64mm Airfield F18 (w rudder mod) but this one definitely has it on the top end- fast little jet!
Old Nov 02, 2012, 03:31 PM
dth7 is offline
dth7's Avatar
Joined Feb 2012
Originally Posted by supercollider View Post
Hi all,
Very little for the KE is all I have needed
Old Nov 02, 2012, 03:34 PM
dth7 is offline
dth7's Avatar
Joined Feb 2012
I have not used it with the stock fan, but the fan/motor combo that Don sold me (balanced), is nothing more special than the one you have. not belittling Dons fan by any means............just trying to point out that it's a regular, plastic type fan, just like yours. he just puts them together and balances them silky smooth. his motor with your fan will be just fine, as long as yours is balanced. you could always send him your fan and he can put it together, balance it and send it back. or, do what I did and buy one of his used units. I paid a little more than $40 for the fan, motor and ESC, shipped to my door. I will recommend his products to anyone. super nice guy and an awesome product that he stands behind. you can't beat it for the money.
Rich
Did it, I agree on all points and I'm thinking in the 100 mph range too. Really goes with this new motor. Thanks for the recommendation.
Old Nov 02, 2012, 03:37 PM
dth7 is offline
dth7's Avatar
Joined Feb 2012
Nothing needed. The 4 wing screws and the slots top and bottom work fine. I just replaced my motor and it was still nice and tight after many flights. If you are running the stock motor and decide to go with 4 cells you WILL have to replace the motor eventually- it's fun while it lasts! Make sue you get a bigger ESC too 45+amp. Have fun. Great little jet for the $ even with a new $30 motor.
Old Nov 02, 2012, 09:03 PM
Joined Jan 2009
anytime. I will plug Dons products because I believe in them based on what I have in front of me.
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1577 Jun 06, 2016 08:52 AM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 09:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
