Old Oct 17, 2012, 03:32 PM
NCRealEstateGuy is online now
Find More Posts by NCRealEstateGuy
I Used To Have More Free Time!
Charlotte, NC
Joined Feb 2011
I just saw that ten minutes ago Chas650r. that is a better deal than HK! I'm all over it. I'm getting over confident with it and stalling it out trying too many moves with it. Good thing they are fairly cheap.
NCRealEstateGuy is online now Find More Posts by NCRealEstateGuy
Old Oct 17, 2012, 08:02 PM
proline1 is offline
Find More Posts by proline1
United States, NY, Syracuse
Joined Sep 2011
Try to search for this but no luck. Can anyone tell me what they use to secure the cover just ahead of the tail to the fuse? Thanks much!
proline1 is offline Find More Posts by proline1
Old Oct 17, 2012, 08:04 PM
Charlotte, NC
Joined Feb 2011
double sided tape
Old Oct 17, 2012, 08:12 PM
proline1 is offline
Joined Sep 2011
Originally Posted by NCRealEstateGuy View Post
double sided tape
okay great! i was going to use hot glue! thanks!
Old Oct 18, 2012, 03:20 AM
yellowcolorado is offline
Find More Posts by yellowcolorado
United States, LA, Metairie
Joined Feb 2009
Im kinda of curious to what are some of the faster 4 cell setups out there? are the EDF units plastic or aluminum? What motors are people running? Any suggestions would be great. Thanks
yellowcolorado is offline Find More Posts by yellowcolorado
Old Oct 18, 2012, 06:14 AM
proline1 is offline
Joined Sep 2011
I have read many thoughts on CG after 141 pages!!! Great info but can anyone help me lock in for maiden on stock 3S 1800 25C (148g)? I'm thinking high rates at 70% Aileron/ 50% Rudder/ 100% Elevator. Low rates at 50% Aileron/ 50% Rudder/ 80% Elevator. Should i launch on high rates as i do with other non EDF planes? Also it seems that everyone says to leave Elevator rates almost full for more flare for low speed landing. Are Aileron rates still too high for first flights? I'm keeping rudder at a minimum as no knife edge expected initially. Thanks much!
Old Oct 18, 2012, 06:34 AM
proline1 is offline
Joined Sep 2011
More questions Sorry! I would like to paint or decal the under wing/ fuse as I have all my plane set ups. Top wing always gets a color and bottom wing with black or black stripes on 1/3rd of the under wing tip and usually black on bottom of the fuse under canopy and tail. Helps me a great deal with orientation especially with close fast manuevers. ANYWAY.. Can anyone suggest how to remove decals from bottom wing and is paint or decals better for this type of foam? If paint any suggestions on what brand/type of paint? Thanks much!
Old Oct 18, 2012, 09:56 AM
Charlotte, NC
Joined Feb 2011
I used masking tape to pull off the stickers and paint. I then used Krylon paint for plastics. I decanted the spray can and poured the paint out into a tupperware. I then brushed on the paint.
Old Oct 18, 2012, 11:23 AM
proline1 is offline
Joined Sep 2011
ok great thanks!
Old Oct 18, 2012, 12:35 PM
supercollider is offline
Find More Posts by supercollider
C.E.R.N. field tester
supercollider's Avatar
United States, NE
Joined Sep 2012
I use krylon fusion. After removing decals, you already have a white base to work with. I clean with rubbing alcohol, and mask off 2 stripes on the wings and spray paint. Have done this with a few edf's and works good. Good visibilty.
As for the cg, push the 1800 pack against the foam ledge towards the nose, it's that simple. The cg will be near the REAR of the finger holes. Plus, you still have 10mm fore or aft, it doesn't have to be perfect. The CG as listed in the maual is a little too foreward. Full throttle into the wind and it will fly. Get some altitude and trim. Mine needed 2 clicks of up.
And you're rates sound good but perhaps elevator on low rates should also be 50%. Add a little expo too, like 35%, to soften things up. You can launch on low rates with no problems. After around 45 flights, I still have my ailerons set at 50% travel. At 100%, the roll rate borders on violent. It looks funny to, not very scale. You start to wonder how the lipo doesn't fly out of the fuse when rolling.
Here's a couple of photos with some different mods too.
Good luck and let us know how the maiden goes.
supercollider is offline Find More Posts by supercollider
Old Oct 18, 2012, 03:50 PM
proline1 is offline
Joined Sep 2011
Originally Posted by supercollider View Post
I use krylon plasticote(I think thats what it's called), for plastics. After removing decals, you already have a white base to work with. I clean with rubbing alcohol, and mask off 3 stripes on the wings and spray paint. Have done this with a few edf's and works good. Good visibilty.
As for the cg, push the 1800 pack against the foam ledge towards the nose, it's that simple. The cg will be near the REAR of the finger holes. But still, you have 10mm or so margin. Full throttle into the wind and it will fly. Get some altitude and trim. Mine needed 2 clicks of up.
Excellent info thanks very much!!!
Old Oct 18, 2012, 04:03 PM
United States, NE
Joined Sep 2012
Your welcome, I also added some photos to my previous post
Old Oct 18, 2012, 04:08 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
personally, I prefer to launch on high rates and switch to low rates for high speed. I've tried low rates and it's more than flyable that way from launch to touchdown.
as far as best setups, Dons is the best by far. for the money, quality and plug and playability, you can't beat it. the metal fans are cool, but they don't belong in a foamie IMHO. the biggest reason, is that they sink the heat straight to the airframe, which is why I don't use them on foamies. weight can also be a factor too. not saying don't use them, just giving reasons why I don't use them for foamies. heat and foam just don't mix well.
I can also tell you this much...............my Dons setup was way less than any metal EDF out there and it performs on par, or better than my metal fans. you just can't beat it. plus, Don stands behind his products. I will continue to support him based on that selling feature alone.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Oct 18, 2012, 04:51 PM
United States, NE
Joined Sep 2012
I have not dealt with Dons personally, but he is well spoken of and he certainly does his homework on what works best.
Old Oct 19, 2012, 04:06 PM
Quadmad is offline
Find More Posts by Quadmad
Joined Jul 2012
Hi Guys I have read all of this thread and love this little plane already what are the best servos to use in this bird ?anyone used the EXTREME CNC ALLOY 10 BLADE 64mm FAN in this jet?
And who else sells this kit in airframe only?
Cheers
Quadmad is offline Find More Posts by Quadmad
Reply With Quote  (Disabled)
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1591 Sep 05, 2016 06:48 PM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 09:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
