Old Oct 13, 2012, 02:39 AM
supercollider is offline
Find More Posts by supercollider
C.E.R.N. field tester
supercollider's Avatar
United States, NE
Joined Sep 2012
Originally Posted by proline1 View Post
LOL... I'll start at finger hole area as suggested. BTW do you balance the jet inverted or upright? Thanks!
I balance the Stinger inverted due to the low wing. With 3s 1800s I just keep the lipo up against the foam ledge in the battery area and launch into the wind at full throttle. 2200s will make it a little nose heavy and it will drop the nose in the turns. I find it to have better performance and vertical with 1800s. This really is fun little jet.
supercollider is offline Find More Posts by supercollider
Old Oct 13, 2012, 04:59 AM
proline1 is offline
Find More Posts by proline1
United States, NY, Syracuse
Joined Sep 2011
Originally Posted by kushal_22 View Post
I was just using the Finger holes and keeping it upright..I found with a 1800 Nanotec pack as far forward for my first flights did just fine..after taking a 3OZ of lead from the nose!
Mal
just to be clear- you held balance point at the rear of the finger holes? also did you remove some lead from the nose or still had to add 3oz? I am using same 1800 nanotech so weight should be +- a few g's. thanks!
proline1 is offline Find More Posts by proline1
Old Oct 14, 2012, 10:42 AM
Kurt is online now
Find More Posts by Kurt
Upstanding Member
Kurt's Avatar
United States, TX, Houston
Joined Sep 2003
Hard wired the 2815 4800kv motor to the 65A ESC and mounted in the left inlet with hot glue. Shouldn't disrupt the airflow too much, I hope.
After hot gluing the RX just above there's now plenty of room for a 2700mAh 4S, just have to fiddle with the cg a bit.
Hopefully will get a chance to fly her before the really cold weather hits!
Kurt is online now Find More Posts by Kurt
Old Oct 14, 2012, 12:35 PM
United States, NE
Joined Sep 2012
The esc is tucked in really nice. May be a little heavy, but its gonna be a screamer for sure.
Old Oct 14, 2012, 08:04 PM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
I was at the very front of finger holes ALL Lead in nose REMOVED 1800MAH 3S Tucked as far up as possible. Flies just fine in my book....would like to go 4S ....after upgrading ESC
Mal
kushal_22 is offline Find More Posts by kushal_22
Old Oct 15, 2012, 04:56 AM
proline1 is offline
Joined Sep 2011
Thanks for the input on CG and balancing points. I usually balance my low wing planes inverted as well.
Old Oct 15, 2012, 08:43 AM
NCRealEstateGuy is offline
Find More Posts by NCRealEstateGuy
I Used To Have More Free Time!
Charlotte, NC
Joined Feb 2011
Where can I find the Stinger as a kit... I want all of the body parts, but no electronics nor servos nor motor. The best I can find is an ARF from HK, or parts from Hobby Lobby.
NCRealEstateGuy is offline Find More Posts by NCRealEstateGuy
Old Oct 15, 2012, 10:04 AM
Kurt is online now
Upstanding Member
Kurt's Avatar
Joined Sep 2003
Thanks.
Anyone have tips for keeping the fan on the motor shaft?
I ran her up to speed last night, and after about 2 seconds "PZZZZZ!!!!" the fan blade came off the shaft. This time the airframe was there to contain it so no damage to flesh (and can't see much damage to the foam), but I had really cranked the fan nut down hard.
Would putting a drop of locktite on the shaft help at all?
Any other ideas?
thanks!
Old Oct 15, 2012, 12:42 PM
tdab is offline
Find More Posts by tdab
tracey=Col Frank Fitts
tdab's Avatar
Carolina's
Joined May 2004
Thanks.
Any other ideas?
thanks!
Yes, Put Lock-Tite on the threads before you install the nut. Then let it dry for a few hours. That should work.
tdab is offline Find More Posts by tdab
Old Oct 15, 2012, 03:55 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
get the kind that you have to heat off. it'll make for a better lock than the non-heating kind.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Oct 15, 2012, 03:59 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
if u roughen the shaft it may help a bunch, i just use about 150 grit and rotate the bell by hand leaving small groves around the shaft for the collet to grab. obviously dont sand more than needed to just roughen .
chuck.
chas650r is offline Find More Posts by chas650r
Old Oct 15, 2012, 04:58 PM
Kurt is online now
Upstanding Member
Kurt's Avatar
Joined Sep 2003
thanks for the advice gents! Long range forecast looks good for next weekend so will do both for her first flights with the new powerplant!
Old Oct 17, 2012, 02:35 AM
United States, NE
Joined Sep 2012
It looks like you found it at HK. I googled "stinger 64 airframe "and that's what came up. $53 plus shipping. If you find an airframe anywhere else let us know. Almost better off buying an ARF from hobby lobby and stripping it. Those mg servos are pretty decent, same with the esc. Throw them on the workbench for the next plane.
Old Oct 17, 2012, 06:01 AM
Charlotte, NC
Joined Feb 2011
So no kits anywhere, Huh? If not then SC's advice to get the ARF may be the next best thing.
Old Oct 17, 2012, 09:45 AM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
$79 arf value hobby.
chuck.
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1554 Nov 23, 2015 03:17 PM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 09:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
