Old Sep 09, 2012, 11:40 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
They are not retracts just undercarriage.
clive45 is offline Find More Posts by clive45
Old Sep 09, 2012, 11:46 PM
Kurt is online now
Find More Posts by Kurt
Upstanding Member
Kurt's Avatar
United States, TX, Houston
Joined Sep 2003
thanks, I knew that must have had retracts on the mind
post edited.
Speaking of gear, I have a set of these to be fitted to my P-38 over the winter. Probably a bit too heavy for the Stinger, but now on sale for $11 (for a set of 3) from Hobbypartz is an unreal deal
http://www.hobbypartz.com/exi-jet-me...ndgearset.html
Kurt is online now Find More Posts by Kurt
Old Sep 11, 2012, 03:21 PM
busadriver is offline
Find More Posts by busadriver
United States, TX, Dallas
Joined Feb 2011
Thanks. Yes, the stinger & most of the gear is on order. The autopilot oscillations were due to bad airspeed measurement and scaling. There's more info on my diydrones blog page. The concept was to start in manual, switch to auto which didabled the servos, have the plane drop itself or sense freefall & cutaway. The plane was to return to launch and loiter down to an altitude where it could be visually controlled. The next version will have minimal fpv to handle the off nominal case where the plane is close to the tracking vehicle but not yet visually acquired.
busadriver is offline Find More Posts by busadriver
Old Sep 11, 2012, 07:49 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
I wonder how many would be interested in a larger version of the Stinger. I'm starting the process to make a slightly larger version in FG, for a 70mm fan. The new metal fan from HK might do well in this larger airframe. It will also have built up wings and stab, or hollow molded wings and stab for lightness. I'm planning on a light layup with CF in strategic locations for strength, while keep the frame light. It's not gonna be ready overnight, but should be well underway and finished during the winter months.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Sep 11, 2012, 07:51 PM
Joined Jan 2009
I'll also work on a better wing profile to tame the nastiness out of it during power off maneuvers. I'm thinking the upturned wingtips will have to go, but we'll see.
Rich
Old Sep 11, 2012, 09:05 PM
Norm62 is offline
Find More Posts by Norm62
United States, SC, Greenville
Joined Jun 2011
Originally Posted by Maddmax View Post
I really don't think there's a problem with the orange rx.
Agreed... I use orange receivers in 16 of my 18 planes. I only use the orange satellites in the very fast and larger airplanes. The other 2 planes use Spektrum with satellites that came with my radios. Been flying with the oranges for about 18 months and had zero problems. The only time I've ever had loss of control issues (once and on the Stinger), it was due to an ESC meltdown. I regularly fly a 110mph SkyFun Jet on an Orange w/satellite, almost as far as I can see and have never lost control. Guess this debate will always exist, but truth be told, I've seen just as many stories about Spektrum failures as I have Orange failures. I just always say, "To each his own". As for me, I'll always use whatever gives the best bang for the buck and lets just say there's a lot of variety in my hangar thanks to the $ I've saved on radio equipment.
Anyway, I got a balanced 4000 plus combo from Don's and am finally about to install it with a thrust tube. Going to run 4s 2200. Looking forward to the re-maiden with the new setup (if I could just decide where to put the 60a esc!).
Norm62 is offline Find More Posts by Norm62
Old Sep 11, 2012, 09:15 PM
RedTalon is offline
Find More Posts by RedTalon
The RED filters through
RedTalon's Avatar
Rendon, TX
Joined Feb 2007
Similar to this?
RedTalon is offline Find More Posts by RedTalon
Old Sep 11, 2012, 10:09 PM
Joined Jan 2009
Nah, that's a Habu clone. Ugly duckling. LOL.
Old Sep 11, 2012, 11:46 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
Originally Posted by Blizards316 View Post
I would like to hear opinions on the retracts. Thickness of the wing for the retract unit?!? What u okes think?
I have now done approx 10 skid ons onto tarmac. And the plastic skids wont really do anymore. They chafe through quick. Was think to put uluminium shaped skids over or onto the plastic skids. Just small plates but dunno... Opinions on the retracts?
try pieces of huge try raps for those skids , we hot glue them on and they last forever.
chas650r is offline Find More Posts by chas650r
Old Sep 13, 2012, 12:28 AM
Kurt is online now
Upstanding Member
Kurt's Avatar
Joined Sep 2003
very interesting Busa - please stop by here every once in a while and let us know how it's going!
Today my Stinger arrived - took all of about 30 minutes to assemble, including swapping out the dean's battery plug for an XT60.
Impressive power out of the big EDF - but then again it's my first EDF so I don't have anything to compare it to
Too windy today to maiden, hopefully this weekend.
What's the consensus for protecting the foam - clear tape on the leading edges? Anyone try painting theirs with clear polyurathane?
The LG just shipped from HK so it'll be a few weeks until they arrive - for the for few packs she'll be landing in fairly thick grass so would like to keep her as clean and straight as possible.
thanks!
Old Sep 13, 2012, 12:59 AM
protoplasmia is offline
Find More Posts by protoplasmia
protoplasmia's Avatar
Australia, VIC, Melbourne
Joined Feb 2012
thanks!
Yes, I've got some HK Fibre tape on leading edges and on its belly .. and also, some small wing skids as well.
Just make sure CG is around 70-72mm from leading edge and launch into the wind on FULL throttle ... and be ready to counter that left torque roll ... good luck with the maiden!
protoplasmia is offline Find More Posts by protoplasmia
Old Sep 13, 2012, 01:01 AM
mustflynow2 is offline
Find More Posts by mustflynow2
The Sequel
mustflynow2's Avatar
Australia, VIC
Joined Sep 2011
protecting the foam
it's the nose that will go first, I got a dozen happy landings before I caught the nose in some longish grass, during what was a good dead stick landing. I was maybe coming in a tad quick, nothing that should be a prob only the nose caught in a tuft of grass, the softest of breaks, the nose was still hanging on by the glue. So I figured I'd snubb nose mine, used a polyurathane glue which did react with the foam, make sure you test, but did go hard in the end. Also some carbon fibers, for strength, now I have a bearded stinger looks terrible, could be finished of with some paint etc.
mustflynow2 is offline Find More Posts by mustflynow2
Old Sep 13, 2012, 08:07 AM
Kurt is online now
Upstanding Member
Kurt's Avatar
Joined Sep 2003
Thanks Proto and Brendan.
I do plan on beefing up the nose and front fuse with some CF, like I did on my radjet in the pic below.
How are y'all securing the battery pack? I plan to use 3S 2.2A 25C+ packs I already have, and it seems a bit crowded in there. Putting the pack on top of the ESC, pushed back allows space for the RX in front, but then the battery has to go in first then the RX so it means regular stress on the servo plugs in the RX taking it out, and in etc.
The control surfaces seem to be pretty well centered out of the box. Will probably have someone else give it the first toss (full throttle, thanks for that reminder ) since I haven't mastered the left-handed throw.
Old Sep 13, 2012, 09:26 AM
Chlewi is offline
Find More Posts by Chlewi
Australia, QLD, Mount Stuart
Joined Jul 2012
ive doubled sided taped my receiver to the wall above the ESC. looks real tidy and away from the battery so no stress on the wires what so ever. However, iam using a 1800mah 3S, and my CG has worked out at about 75-78mm back from leading edge and this is probably a little too far back, so i may have to add some nose weight. Yet to maiden so we'll see how she is.
Chlewi is offline Find More Posts by Chlewi
Old Sep 13, 2012, 11:56 AM
Alpha10 is offline
Find More Posts by Alpha10
Alpha10's Avatar
United States, IL, Chicago
Joined Aug 2011
Balance wIth mAh... A 2200mAh Lipo would be ideal
Alpha10 is offline Find More Posts by Alpha10
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1558 Today 09:32 AM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 09:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
