Old Aug 28, 2012, 04:04 AM
wetsalami is offline
Find More Posts by wetsalami
Bunt!
wetsalami's Avatar
Joined Sep 2010
A few weeks ago I did my 1st VTO with my Stinger. I used the HK 4800kv Outrunner in the standard fan unit on 4s 1700 Dualsky Lipos. It did it much easier that I thought it would. I did it about 3 times that day and found it a lot easier than hand launching it.
Bring on the weekend again.
wetsalami is offline Find More Posts by wetsalami
Old Aug 28, 2012, 05:32 AM
Blizards316 is offline
Find More Posts by Blizards316
Glow? What is that?
South Africa, GP, Pretoria
Joined Apr 2009
Whick 4800kv did u use? The Turnigy 2615 or the Turnigy 2815?
And whats the ampdraw with 4s on that motor? Thanks.
Blizards316 is offline Find More Posts by Blizards316
Old Aug 28, 2012, 05:58 AM
Bunt!
wetsalami's Avatar
Joined Sep 2010
2815 and I didn't check the amp draw. I was using a Dualsky 60amp esc and 35c 1700 Dualsky which had no problem delivering that power... My guess would of been around 45amps.
Old Aug 28, 2012, 01:36 PM
Anasazi is offline
Find More Posts by Anasazi
Katowice, Poland
Joined Nov 2005
Speaking of turning while hand launching...
Shot at 2012-08-28
Shot at 2012-08-28
I must try tossing it with my left hand - that should give some initial right twist, what should result in more level flight.
I also pushed the battery slightly more to the back, as a result the jet stopped dropping nose when engine off, now it glides better. Need to make some final adjustments, but it seems the perfect CG for it will be at the back of recommended factory settings or even slightly further.
Anasazi is offline Find More Posts by Anasazi
Old Aug 28, 2012, 02:24 PM
tdab is offline
Find More Posts by tdab
tracey=Col Frank Fitts
tdab's Avatar
Carolina's
Joined May 2004
My Stinger (about 700 watts) does this on every hand launch . I have at least 5 or 6 EDF's that I hand launch right now and for some reason the stinger is the only one with this characteristic that is so pronounced. Even when I throw it 'overhead' it still does it! It is no biggie when you are expecting it though. Great pictures.
tdab is offline Find More Posts by tdab
Old Aug 28, 2012, 05:06 PM
CARIMALI is offline
Find More Posts by CARIMALI
CARIMALI's Avatar
Joined Oct 2006
I have encountered same problem when I use to launch it by holding on top between wings (as per above picture). Since holding it from underneath using fingholds it has a tendancy to not flick to the left at much on launches.
CARIMALI is offline Find More Posts by CARIMALI
Old Aug 29, 2012, 04:55 AM
Wilit run? 353 is offline
Find More Posts by Wilit run? 353
No such thing as overpowered
Wilit run? 353's Avatar
Suffolk, England
Joined Sep 2008
Has anyone got a fast 3S set up they could share?
Wilit run? 353 is offline Find More Posts by Wilit run? 353
Old Aug 29, 2012, 05:19 AM
Anasazi is offline
Katowice, Poland
Joined Nov 2005
Made another few flights today, stock setup is just fine, let's call it recreational flying. Now I am wondering - what next? Been thinking of ViperJet 70mm EDF maybe
Old Aug 29, 2012, 10:21 AM
JaggedEdge is offline
Find More Posts by JaggedEdge
Buildin'em and flyin'em
JaggedEdge's Avatar
United States, NY, Erie
Joined Dec 2007
$50 for the up to 30 ounce jetapult.
http://shop.rc-electric-jets.com/Min...nijetapult.htm
Originally Posted by LuvEvolution7 View Post
Yeah, a jetapult. Use your search button and you'll find tons of material on the jetapult. I believe its sold by EJF.com, but don't quote me on that. Think its about a hundred bucks, give or take. Certainly not as cheap as a 20 foot section of.bungee chord. A jetapult is a bungee system that has plastic rails. You hook the plane to the bungee and sit the plane on the rails. Give the plane full power, hit the foot activated switch and off she goes.
You can make your own rail system out of half inch PVC pipe with some T's and 90 degree bends. Just angle the rails at a 5-10 degree angle. Then your bungee gets.pulled to about two to three times your aircraft weight and you are off to the races. A fishing scale comes in handy for this. Just count your paces that it takes to pull the bungee to the correct.weight and you'll only have to measure once. The rest of the time, you'll just count paces for a particular model.
JaggedEdge is offline Find More Posts by JaggedEdge
Old Aug 29, 2012, 08:56 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
yeah, they've come down quite a bit since they were first introduced. there's a guy on RCCanada selling one for around that price at the moment. still not as cheap as a 20 foot length of bungee chord. LOL.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Aug 30, 2012, 01:04 PM
Glow? What is that?
Joined Apr 2009
I maidened my PNF Red Stinger64 today.
Setup:
Standard out the box servos, linkages and connections.
R610 with brown out cap.
Replaced stock esc with TP H40A.
4s 2200 nanotech 25-50c.
Cg set @ 70mm
Performance:
46 Amp @ WOT
730 watt
800gram auw.
415 watt per pound.
Had a friend handlaunch into a 5 knot breeze.
I saw the left torque roll but was no biggy at all.
I initially set flight modes up and turned all the FM0 rates to 50% throw and 25% expo.
On limmediately I went to FM1 set to 65% throws ang 30% expo As the aerie was very unresponsive.
I definately wouldnt say its a rocket.. But it keeps you busy definately.
Had a lot of fun flyin 5:30.
She landed pretty hot. Think i need more elevator throw to slow her down more.
Fun little aerie.
Old Aug 30, 2012, 02:37 PM
ledouxmike is offline
Find More Posts by ledouxmike
Joined Jul 2008
Hey guys. I'm upgrading to RC Lander aluminum fan, the silver one, with 4000kv motor, 60amp Plush esc and Nano 4s 2200mah 35-70c
What kind of mix can I put in to help the plane slow down and give lift for landin?. I was gonna set it up to one of my switches on my radio. thanks guys
I have a delta mix I can switch off and on now. thanks again
ledouxmike is offline Find More Posts by ledouxmike
Old Aug 30, 2012, 03:51 PM
pullup! is offline
Find More Posts by pullup!
HellBentPuppet
pullup!'s Avatar
Co.
Joined Jan 2005
Just got done installing my new Wiked edf 4000kv motor, new balanced fan and 40 amp esc. I soldered all motor connections per instructions and spooled her up.
Using new Turnigy 4s 2200 40/50c got 624 watts 40.5 amps static. Just doubled my watts from stock
Will try and fly it tonight.
Just ordered up 2 more Stingers for my buddies, and threw a twin 64mm 360 thrust vector job in the cart for me
This EDF stuff is fun!
pullup! is offline Find More Posts by pullup!
Old Aug 30, 2012, 09:49 PM
Joined Jul 2008
Don't know if anyone posted but the Stingers are on sale for a low low $69 at banana hobbies right now as so are a bunch of cool jets.
http://www.bananahobby.com/stinger-r...5429-prd1.html
The mini blue angles hornet and the F-22 are awesome looking. And only $75 for receiver ready with 50mm edf. I wanted both but ordered the blue angles jet to check it out. They also sell smaller, pocket jets. lol
Old Aug 31, 2012, 12:13 AM
Kurt is online now
Find More Posts by Kurt
Upstanding Member
Kurt's Avatar
United States, TX, Houston
Joined Sep 2003
I ordered a red Stinger last night (my first EDF) from BH for $84 shipped to my door.
Banana and HK are both showing the gear as out of stock.
Does anyone know of other sources, or other gear options that work well?
I'll be happy hand-launching/belly landing for a while, but landings and take-offs are a major part of the fun of RC flying so I'll want LG eventually.
Been reading a bunch here, thanks all for sharing tips and advice!
Other planes:
1450mm J-power P-38
1400mm FMS P-51
1100mm Parkzone T-28
800mm Radjet with 2826 motor (screamer!)
Kurt is online now Find More Posts by Kurt
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1589 Jul 13, 2016 05:57 PM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 09:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
