Old Jun 19, 2012, 10:46 AM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, New Tecumseth
Joined Nov 2010
Originally Posted by planex View Post
Got my 64mm RClander fan and 4000 motor ready to go
The stinger kit was posted today so should have it soon
What's the best way to install this fan as there is no locating pins or tabs?
Push fit with some double sided tape?
First EDF
Double sided tape works just fine and is easy to remove. Once the wing is on the fan can't go anywhere
vanderbrander is offline Find More Posts by vanderbrander
Old Jun 19, 2012, 10:52 AM
planex is offline
Find More Posts by planex
Rookie
planex's Avatar
Australia, VIC
Joined Jun 2011
Yeah I was going to try this way first to see how it holds up
Don't want a permanent fix with glue, plus tape is neater
Anyone put a clear coat of acrylic over the Stinger?
I've read the paint is bad, I don't want to lose the stock color scheme
Was thinking of sealing it some how with some kind of pressure pack acrylic clear
planex is offline Find More Posts by planex
Old Jun 19, 2012, 11:09 AM
kakofonixx is offline
Find More Posts by kakofonixx
Ελλάς, Αττική, Αθήνα
Joined Jun 2009
the paint is ok, it won't come off (large red (or blue) + black colored areas)
the stickers are the ones that flaking badly!
they peel off even when you touch them
kakofonixx is offline Find More Posts by kakofonixx
Old Jun 19, 2012, 05:01 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Mine peeled off without even touching them.. I just run fast setup
pavcon is offline Find More Posts by pavcon
Old Jun 19, 2012, 10:09 PM
planex is offline
Rookie
planex's Avatar
Australia, VIC
Joined Jun 2011
oh ok I see I'll just wait and see when it arrives I guess
I bought the red kit version
Old Jun 20, 2012, 03:15 AM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
I just found this discussion and it has me excited to do some upgrades to my Stinger as well. My regular FPV plane is in the shop for maintenance so I strapped a camera to my Stinger yesterday. The plane responded well and actually settled down in flight but you could tell right away the extra weight was there on launch. Check this out and enjoy!!
Stinger Jet Video 6-19-2012 (2 min 48 sec)
Maddmax is offline Find More Posts by Maddmax
Old Jun 20, 2012, 10:27 AM
Hixxer is offline
Find More Posts by Hixxer
United Kingdom, England, Nantwich
Joined Jan 2012
I crashed mine last night, veered left and stuck in the ground, reading up on here I'm now confused.....
My 3s is pushed as far back as it will to get the CG correct (5mm behind the finger holes)..this is a stock setup, looking at the piccys on here and your packs are all fully forward?
It must be me so just to be sure I'm doing it right - draw a line 5mm behind the finger holes to the wings, turn it upside down and put my fingers on the lines, move pack as required..is this right?
Hixxer is offline Find More Posts by Hixxer
Old Jun 20, 2012, 02:30 PM
Maddmax is offline
Joined Jun 2011
I use a 2200mah 3s in the stock location in the nose and works fine.
Old Jun 20, 2012, 02:39 PM
Paul 1968 is offline
Find More Posts by Paul 1968
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
As do I, my CG falls roughly in the middle of the finger holes, 5mm behind the finger holes sounds a lot to me like a recipe for disaster. It would put the CG roughly 20 mm behind where it's supposed to be. It would make the model extremely pitch sensitive and make it a real handful.
Paul 1968 is offline Find More Posts by Paul 1968
Old Jun 20, 2012, 03:58 PM
Hixxer is offline
Joined Jan 2012
Yea I pushed mine forward but then had to rearrange stuff so ran out of time
to try it. Weather is crap for a while so I will have to wait to see if it's ok. Cheers guys.
Old Jun 22, 2012, 06:00 PM
J3 guy is offline
Find More Posts by J3 guy
Broken Arrow, Okla
Joined Oct 2010
Installed the fix gear on mine, have not flown it yet. My field has a hard surface runway.
Have 5-6 flights on mine, but not into hand launching it.
The CG on these things are a mystery, if you check other posting they are at different points.
Will set mine to the finger hold mid point and see how it works.
The temps in Okla are hitting upper 90s now, hopefully the ESC holds up. I updated to a 40Amp also.
J3 guy is offline Find More Posts by J3 guy
Old Jun 22, 2012, 06:51 PM
ltz400 is offline
Find More Posts by ltz400
I piss ignorant people off
ltz400's Avatar
Joined Apr 2004
How are you guys using 2200 batts?I tried to use some 2200's and it would crash at every hand launch.I can fly it with my 1600's no problem.I just ordered a new Stinger today as the first one was destroyed.I wish i could have found just the fuselage as the wings and tail wings are in perfect condition.The nose on the fuse has been repaired toooo many times.Guess i'll stick with the 1600's with this one.
ltz400 is offline Find More Posts by ltz400
Old Jun 22, 2012, 09:11 PM
J3 guy is offline
Broken Arrow, Okla
Joined Oct 2010
I use 1600 and 1800 3cells, all stock except the ESC.
Old Jun 23, 2012, 01:18 AM
pavcon is offline
Joined Jan 2010
push the 2200s further back. you are probably noseheavy... the planecan handlaunch easily..
it's something that you are doing wrong and not the plane.. most here are flyign with 2200 batts 3 and 4s
Old Jun 23, 2012, 02:54 AM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
My handlaunches were a hit or miss with 3S.
I upgraded to 4S and it is so much easier now. I'm flying it with a 4S 1800, which is about the same weight as my 3S 2200.
If the plane rolls to one side upon launching, use the rudder to correct the roll. This is assuming you are flying mode 2 and launching with your right hand.
miketre is offline Find More Posts by miketre
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1589 Jul 13, 2016 05:57 PM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 09:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
