Old Jun 05, 2012, 08:32 PM
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, L'Orignal
Joined Nov 2010
Originally Posted by Alpha10 View Post
I'm pumped to get my Stinger in the air this weekend. Just curious as to what you guys are running as far as D/R and Expo on your surfaces.
I have triple rates so I was thinking:
Ailerons: 60, 70, 80% with +20, 30, 40 Expo
Elevator: 65, 75, 85% with +5 ,10, 15 Expo
Rudder: 65, 75, 85% with +5, 10, 15 Expo
IDK how sensative the elevators or rudder is?
I'd appreciate any suggestions. Thanks!
Depends on whether you're flying 3S or 4S. The ailerons are very sensitive - on high rates it rolls faster than my eyes can keep up.
Here's my setup (DX8 and 4S). For what it's worth - mine is pretty conservative. Everyone has their own personal preferences, but it's probably a good starting point.
Aileron 30/30, 40/50, 60/50 (I rarely use 60/50)
Elevator 75/40, 90/50, 100/50
Rudder 100/50
Set your CG at the rear of the finger grips, she should fly really nicely there. Set yourself to low rates until you get used to it. Give it a good throw into the wind upward at about 30 degree angle and hopefully you'll be home safely afterwards with some video or a detailed flight report
Good luck with the maiden
vanderbrander is offline Find More Posts by vanderbrander
Old Jun 07, 2012, 11:01 AM
speeddemon
United States, TX, Whitesboro
Joined Jun 2011
When im screwing the wings does anyone use glue to make sure the wings are succure, or are the screws effeciant enough to hold the wing in, also looking at buying the HK fan with the ADH300 motor, can that motor with a 45amp ESC handle my 4s battery? or is there some other edf system that can handle my 4s lipo?
tofast4u is offline Find More Posts by tofast4u
Old Jun 07, 2012, 03:32 PM
Infinite Zenith
Draven's Avatar
United States, TX, Arlington
Joined Sep 2006
I made an air brake for stinger. It might reduce the effectiveness of the vertical stabilizer but we'll see.
Air Brake mod on Stinger 64 (0 min 19 sec)
Draven is offline Find More Posts by Draven
Old Jun 07, 2012, 04:34 PM
porcia83's Avatar
United States, CT
Joined Jun 2009
looks cool, but totally not needed. This thing slows down and floats in very nicely!
porcia83 is offline Find More Posts by porcia83
Latest blog entry: magnum
Old Jun 07, 2012, 04:43 PM
Infinite Zenith
Draven's Avatar
Joined Sep 2006
It glides really well but I'd like to slow it down more. Where I fly the ground isn't so smooth so I need to shave off speed as quickly as a can before I plop it down to reduce the distance it drags on the ground. I broke off the nose in my last flight after it hit a bump after it landed.
Old Jun 07, 2012, 04:54 PM
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
Pull the nose up higher on the flare then. The Singer can be slowed to almost a crawl.
Paul 1968 is offline Find More Posts by Paul 1968
Old Jun 07, 2012, 05:10 PM
Today is a good day to fly.
networker's Avatar
United States, TX, Richardson
Joined Nov 2011
It does look cool!
Is there a way to program a mix with the ailerons and elevator for some pseudo flaps?
I flew mine the other day in a relatively small field. With the Texas breeze, a 1600mah, and some careful high-alpha, it practically hovers before landing. Of course, going downwind, I've got to be VERY careful that I don't end up in the next county!
networker is offline Find More Posts by networker
Old Jun 07, 2012, 05:19 PM
Infinite Zenith
Draven's Avatar
Joined Sep 2006
Well then It seems that I don't have enough elevator throw to pitch it up to flare. I'll readjust my elevator throws. Regardless, I still want to test out the air brake.
Old Jun 08, 2012, 12:23 PM
Australia, VIC, Narre Warren
Joined Jun 2011
I just ordered my Stinger kit, will be using my own EDF setup
Looking for a dedicated 4s setup, wanting to go fast 100mph+
Not looking at spending a heap on a EDF setup
Looking for something reliable, what would you guys recommend?
I've read the HET 6404 64mm fan is a good unit?
planex is offline Find More Posts by planex
Old Jun 08, 2012, 01:18 PM
porcia83's Avatar
United States, CT
Joined Jun 2009
Look into a set up from Dons Wicked...it's about 50 and change for fan/motor/balance. More than enough power
Old Jun 08, 2012, 01:40 PM
Infinite Zenith
Draven's Avatar
Joined Sep 2006
I tested out the air brakes and they were useless. I did however increase the elevator throws. I had so much fun doing high-alpha flight that I eventually stalled it and slightly cracked the intake.
Old Jun 08, 2012, 01:44 PM
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
The airbrake might not work. It will give you elevator up instead of braking. It would have to be on the cg point .
pavcon is offline Find More Posts by pavcon
Old Jun 08, 2012, 02:00 PM
Infinite Zenith
Draven's Avatar
Joined Sep 2006
Well to be fair I couldn't really tell any difference at all. So yes, it's not very effective. I already removed it.
Old Jun 08, 2012, 09:26 PM
Joined Nov 2010
Good on you for trying something new though
Old Jun 08, 2012, 09:34 PM
Joined Nov 2010
Yeap HET 6404 because it will take a 28mm inrunner motor like HET 1W30 or ARC 28-48-1.
You'll need the bigger can motor to get +110mph. I doubt there's a 24mm can motor out there that will get you 1000w reliably.
If you don't want to spend much - talk to Don's RC. He's got a couple of good outrunners that will get you close.
If you want to go seriously fast a HET 1W30 will get you there but you're going to need some serious high C rated batteries.
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 117 May 14, 2013 05:03 AM
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1239 May 03, 2013 08:18 AM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 02:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 07:52 AM
