Old May 09, 2012, 03:44 PM
nebuchadnezzar is offline
Find More Posts by nebuchadnezzar
gilford, new hampshire, usa
Joined Nov 2003
For launching problems try a short little bungee launcher which works great.
nebuchadnezzar is offline Find More Posts by nebuchadnezzar
Old May 09, 2012, 11:35 PM
vanderbrander is online now
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, L'Orignal
Joined Nov 2010
Originally Posted by bonnie9496 View Post
The spoon is from a MacDonalds Sundae. Cut the handle off and 1/3 of the spoon. Sand lightly.....Easy
Ah McDonalds!! The cure for hangovers and now cooling for my ESC - is there nothing they cannot do...??
vanderbrander is online now Find More Posts by vanderbrander
Old May 10, 2012, 12:18 AM
Ben D Wing is online now
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Yeh, they can't make decent food!
Ben D Wing is online now Find More Posts by Ben D Wing
Old May 10, 2012, 11:37 PM
hotpicks is offline
Find More Posts by hotpicks
Joined Jun 2006
Originally Posted by danrc View Post
I've flown my stinger a half dozen times now and love it. Last night I had a bad toss and jacked the nose some, but with a little CA it is back to flying shape. One issue popped up, I have a dead aileron servo that I need to replace. I have a couple 9 gram tower pro servos that are around the same size, would it be a good substitute or should I look for something a bit more robust? I have two in there now (rather than try to reverse one, I just swapped in the two servos. Anyone else have some advice or thoughts on this?
9g micro servo is ok for stinger 64mm, just make sure that it is installed properly
hotpicks is offline Find More Posts by hotpicks
Old May 11, 2012, 11:00 AM
danrc is offline
Find More Posts by danrc
danrc's Avatar
Rockford Illinois
Thanks hotpicks, I flew the stinger with the new servos last night with no issues.
danrc is offline Find More Posts by danrc
Old May 18, 2012, 06:47 AM
NJTailChaser is offline
Find More Posts by NJTailChaser
United States, NJ, Hillsborough
Joined Feb 2012
Stinger Review
I maddened my new Stinger (got it from Banana Hobby) last night. It really exceeded my expectations for a $90 PNP jet. The model was easy to assemble, appears really well made (and packed in the box). Hand launching was a little rough, but once it picked up some speed it flew like it was on rails. I am only 6 months into this hobby, with less than 5 hrs total stick time, and I had not problem flying this jet. It was fast at full throttle, but slowed down nicely at half throttle, and was easier to land than my Parkzone P-51. I am using a Spektrum DX7S with an Orange Receiver. I put in 40% expo into the ailerons on the second flight to make the jet a little less twitchy, and that was all i needed to make each subsequent flight effortless an predictable.
As others have suggested, true CG is about 5 mm back from manufacture's recommendation. Using a 3s 1800 pack makes for a perfect CG w/o any additional effort. This is a really well made and engineered plane that is well worth the $90 price tag. I am going to put in a BEC next just in case the stock ESC fails (as HK and BH products tend to do), but if I get 10 flights out of the stock power system, I will be happy.
NJTailChaser is offline Find More Posts by NJTailChaser
Old May 18, 2012, 02:33 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
yo will get tons without any probs as long as you keep it stock. .
pavcon is offline Find More Posts by pavcon
Old May 20, 2012, 08:54 AM
tofast4u is offline
Find More Posts by tofast4u
speeddemon
United States, TX, Whitesboro
Joined Jun 2011
Is there anyway of fitting a 28mm motor in the stock fan housing?
tofast4u is offline Find More Posts by tofast4u
Old May 20, 2012, 11:18 AM
ex-racr is online now
Find More Posts by ex-racr
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
None whatsoever, unless you want to cut out the motor tube and fabricate a new one.
Not worth it, IMHO.
Any particular reason why you want to use a 28mm motor?
ex-racr is online now Find More Posts by ex-racr
Old May 20, 2012, 01:56 PM
tofast4u is offline
speeddemon
Joined Jun 2011
well right now all i have is a HK 2800 70mm motor and would like to find a use for it int the stinger but after looking more i think i might be better off getting the hobbyking 70mm sport jet
Old May 20, 2012, 03:39 PM
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
Get the 70mm sport jet. So much easier than getting that motor to work in the Stinger.
Old May 20, 2012, 04:13 PM
Draven is offline
Find More Posts by Draven
Infinite Zenith
Draven's Avatar
United States, TX, Arlington
Joined Sep 2006
Just ordered mine. Can't wait.
Draven is offline Find More Posts by Draven
Old May 21, 2012, 02:12 AM
mickydee is offline
Find More Posts by mickydee
Hemet, California, United States
Joined Aug 2001
Hi,
Maidened mine this weekend with the stock system and 3S 1800 battery. Three flights with me doing all the hand launching. It takes a good chuck, but it's not too bad. This is a really nice flying jet.
Mickydee
mickydee is offline Find More Posts by mickydee
Old May 21, 2012, 01:12 PM
JaggedEdge is offline
Find More Posts by JaggedEdge
Buildin'em and flyin'em
JaggedEdge's Avatar
United States, NY, Erie
Joined Dec 2007
EDF Hobbies has a Wemo 64mm fan that will accept a 28mm motor.
I was going to do this with some 5s packs I have but I went with the cyclone power rig for now. The extreme 3950kv should make 4lbs of thrust lol.
JaggedEdge is offline Find More Posts by JaggedEdge
Old May 21, 2012, 03:56 PM
Joined Nov 2010
For those of you who want a 64mm fan that will accept a 28mm motor. Here's a link to a couple of options.
http://www.extremerc.com.au/estore/i...146_72_293_228
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1554 Nov 23, 2015 04:17 PM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 10:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 03:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 08:52 AM
