Old May 24, 2011, 07:53 PM
R/C Soaring "Lifer."
stevecondon's Avatar
Oceanside, CA
Joined Mar 2006
Fosa 1.86 KG Ballast Sets--Limited number available
Attention FOSA owners! If you want to extract the maximum performance out of that sweet new model, you will want the ability to go HEAVY. The Fosa has demonstrated its ability to launch the weight and go around the corners with it.
I had some custom molds made to cast lead slugs for the wing and fuse tubes and also had a limited number of brass pieces machined to the correct taper to fit in the wing joiner. I have flown with the rear compartments of the aft wing joiner full and did not experience any trim change.
With this set you will be able to put it all in and get your model to an (approx) 23.5 ounce wing loading.
I am selling these primarily to help re-coup my machining expenses and to buy a new wing panel for my Fosa after an unfortunate mis-hap . If you are interested, please shoot an e-mail to me at stevecondon at cox.net
Based on how much it cost to machine all this stuff and the time I am putting into crafting the slugs, I am asking $125 per set. Considering the cost of Tungsten, that is "cheap at twice the price" as my dad would say. I only have 5 sets left, so don't sandbag!
stevecondon is offline Find More Posts by stevecondon
Discussion 1/8th Mad Code Short Course Limited Edition Rally Car hobbypartz HobbyPartz.com 3 Sep 02, 2011 11:09 PM
For Sale Fosa 1.86 KG Ballas stevecondon Aircraft - Sailplanes (FS/W) 0 May 17, 2011 11:16 PM
Sold "MK" Flight Control Piezo Gyros LIMITED EDITION [only 1 left] timecop Aircraft - Electric - Multirotor (FS/W) 2 Apr 29, 2011 08:56 AM
Help! Choices on fan for the GJC F-86 Sabre 1/9 scale F15driver Electric Ducted Fan Jet Talk 4 Mar 09, 2011 12:10 PM
LImited number of dlg's !!! capt soap Hand Launch 13 Nov 27, 2003 09:52 PM
