Old May 24, 2011, 12:33 PM
TurboFanElectric is offline
Find More Posts by TurboFanElectric
www.turbofanelectrics.com
TurboFanElectric's Avatar
Tampa, FL
Joined Apr 2002
Build Log
HET 90mm Composite L-39 By Turbo Fan Electrics ~~VIDEO ADDED~~
Hello all HET just released their 90mm composite L-39 and we are going to do a build/flight review for everyone. The glass work is beautiful on this jet and apparently HET has been listening to everyones request as they used Epoxy in the construction and not heavy and brittle polyester resin! Below are the specs and a few pictures to get your L-39 juices flowing.
http://www.shop.turbofanelectrics.co...2&categoryId=9
Features:
- Epoxy composite pre-painted fuselage and stabs
- Full intake/exhaust ducting with NO cheater holes
- Balsa foam sheeted wings
- Laser cut retract plywood mounts included
- Clear canopy
- Decal set
- Wing tip tanks included
Specifications:
- Wing Span : 1118 mm (44")
- Length : 1400 mm (55")
- Flying weight : 4000 grams
We plan on using a set of 90mm-120mm RC-Lander electric retracts and modifying them to accept the HET oleo struts. For anyone interested in this mod we will be selling RC-Lander electric retracts that will come ready to install with the HET oleo struts. More to come shortly.
best regards,
William
HET L39 Maiden Flight by Turbo Fan Electrics (3 min 19 sec)
HET 90mm L39 promo by TURBO FAN ELECTRICS (3 min 53 sec)
TurboFanElectric is offline Find More Posts by TurboFanElectric
Old May 24, 2011, 12:54 PM
egall232 is offline
Find More Posts by egall232
England/uk
Joined Oct 2007
William
Hello,
i do hope that finally HET have listened to customers comments ,generally i have found the quality and fit of parts to be poor at best,
good luck watching with fingers crossed
cheers Euan.
egall232 is offline Find More Posts by egall232
Old May 24, 2011, 01:23 PM
flemsus is offline
Find More Posts by flemsus
Denmark, Nordjylland, Gistrup
Joined Aug 2005
Super. Is the rudder precut? It was not on the prototype.
Flemming.
flemsus is offline Find More Posts by flemsus
Old May 24, 2011, 01:26 PM
Tampa, FL
Joined Apr 2002
Hello Euan I'm just getting started on the build on the HET 90mm L39. Time will tell, but the finish on the glass seems to be nicely done.
Flemming the rudder is not pre-cut, but should be a easy modification.
best regards,
William
Old May 24, 2011, 05:13 PM View Post
AceMigKiller
A moderator felt this post violated the following rule: Excessive Advertising (Over-competition). Show it to me anyway.
Old May 24, 2011, 11:08 PM
therealhiphop is offline
Find More Posts by therealhiphop
therealhiphop's Avatar
USA, UT, Springville
Joined Dec 2005
Man that looks awesome. I love the 2010 Breitling scheme.
Will watching this thread closely.
therealhiphop is offline Find More Posts by therealhiphop
Old May 24, 2011, 11:18 PM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Their newer models really do step up the bar.
The HET L-39 went to together much like other well known companies here in the US. Maybe not quite as easy, but just a little extra brain power and elbow grease results in a beautifully flying model. The HET L-39 is currently my favorite EDF jet to fly.
Vic
AceMigKiller is online now Find More Posts by AceMigKiller
Old May 25, 2011, 08:19 AM
Tampa, FL
Joined Apr 2002
Alright we start the build off with the fan mount install. Please take note that you don't want to mount the fan/motor assembly yet because the rudder/elevator wires need to be installed still.
Old May 27, 2011, 08:58 PM
Tampa, FL
Joined Apr 2002
Next we are going to move to the nose gear retract install. I've decided to use the Rc-Lander 90-120 electric retract units. Because of this the rail system needs to be modified as the Rc Lander retracts won't fit otherwise. Follow the pictures below and the modification is as simple as removing a few pieces of plywood and relocating them for clearance reasons. I will be fabricating a nose gear after the maiden flight, but for now I'm going to move on to the rudder assembly.
Old May 27, 2011, 09:24 PM
Tampa, FL
Joined Apr 2002
Like all of the HET jets the rudder needs to be cut and added. First thing on the list is to remove the rudder from the vertical stabilizer. Follow the steps below to achieve a workable rudder system.
Old May 28, 2011, 10:47 PM
Tampa, FL
Joined Apr 2002
Next we move onto the horizontal stabilizer installation along with the elevator servo install.
Old May 29, 2011, 01:04 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
OK I want one. You can stop now, or I`ll have to unsubscribe until I can fit one on the work bench.
Knife Liddle is online now Find More Posts by Knife Liddle
Old May 30, 2011, 10:20 PM
Joined Dec 2005
No kidding!
Im working on my justification for the wife. But then I remember the old saying, sometimes it is easier to ask for forgiveness than to get permission
Old May 31, 2011, 07:58 PM
Tampa, FL
Joined Apr 2002
HET has definately stepped up their game with this L39!
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Discussion Hobby Topgun 90mm L-39 in DDR markings ready for flight! 4stripes Foamy EDFs 35 Mar 05, 2012 03:32 AM
Sold SAPAC NAVY composite L-39 with gas retracts mgers21 Aircraft - Electric - Jets (FS/W) 4 Apr 28, 2011 04:06 PM
Discussion HET 90mm L-39, who wants it? SCALEFAN Electric Ducted Fan Jet Talk 0 Apr 21, 2011 01:51 PM
Sold Sapac Composite L-39 Complete airega1 Aircraft - Electric - Jets (FS/W) 1 Mar 24, 2011 01:02 PM
