Old May 24, 2011, 04:12 AM
maverick4you is offline
Find More Posts by maverick4you
maverick4you's Avatar
Italy, Lazio, Rome
Joined Apr 2010
Sail Boat Surmount Ballast Weight
Recently i have bought by Hobby King a Surmount sails boat, well made and very cheap boat but without a string of instruction or suggest.
For the assembly of the model i have search photos and other info in the net but i can't found none info about the ballast weitgh
Hobby King suggest a weight of 1,3kg ..... it seems much
Is there a rule for compute the of ballast weigth?
Some one have a Surmount can give me a suggest?
many thanks at all
maverick4you is offline Find More Posts by maverick4you
Old May 24, 2011, 05:51 AM
Gregg28 is online now
Find More Posts by Gregg28
Don't lie to my dog.
Gregg28's Avatar
United States, DE, Wilmington
Joined Jun 2005
The website lists 1.3kg, which is not out of line for an 800mm boat. If anything, it may be a little light. The picture shows a preformed ballast bulb. Why not just use it?
Spec.
Length : 800mm
Height : 1520mm
Weight : 1.4kg
Area of Sails : 0.25m2
Ballast weight: 1.3kg
Gregg28 is online now Find More Posts by Gregg28
Old May 24, 2011, 08:17 AM
seefest is offline
Find More Posts by seefest
seefest's Avatar
United States, MA, Bristol
Joined Sep 2009
Because it hollow! You must supply your own ballast.
seefest is offline Find More Posts by seefest
Old May 24, 2011, 08:56 AM
martin richards is online now
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
Fill the bulb with small lead shot for shooting or belt weights for scuba diving. You'll possibly get more than that 1.3 kgs if the shot is made from tungsten.
Be prepared to substitute your fixed and runing rigging with Spectra and be careful of leaks around the hatch opening.
martin richards is online now Find More Posts by martin richards
Old May 24, 2011, 09:22 AM
triplane is offline
Find More Posts by triplane
Shanghai, China
Joined Mar 2010
Hi, I have my surmount well over a couple of years, and I have updated this tiny thing several times. Keel is reworked and lengthened to 350mm. I currently use 1000g bulb and it performed quite well.
I think 1.4kg is to much for such a little boat, which may cause to high a waterline and drag.
I would say, 850g is minimum for a lengthened keel to keep it going in light air.
triplane is offline Find More Posts by triplane
Old May 24, 2011, 12:35 PM
Italy, Lazio, Rome
Joined Apr 2010
I think 1.4kg is to much for such a little boat, which may cause to high a waterline and hug drag.
Thanks at all for reply and suggest, i think will buy a small diameter lead shot and hope to reach 850gr/1000gr.. of ballast..
Old May 24, 2011, 03:49 PM
groundlooped is offline
Find More Posts by groundlooped
groundlooped
sydney nsw australia
Joined Mar 2005
g'day mate, our guys sail most of the hobbyking boats including ths surmount,plenty of tips and how to, here www.shipshaperc.com
Cheers Col
groundlooped is offline Find More Posts by groundlooped
Old Aug 27, 2011, 02:00 PM
Lucke is offline
Find More Posts by Lucke
Fly Safe !
Lucke's Avatar
SP, Brazil
Joined Jul 2004
Would be 850g enought ?
About the receiver is better 6 or 4,8v ?
Im a newbie on sailboats and hate the manual of this model...
Lucke is offline Find More Posts by Lucke
Old Aug 27, 2011, 07:04 PM
Useful Idiot
Asturias, Spain
Joined Mar 2001
The receiver should work both on 4.8 and 6 V, but the servo power is more on the higher voltage, which may be helpful in the sail servo.
Brazil has some of the world's leading sailors in the smaller RG65 class, and the link: http://www.abvrc.com.br/ could be of interst to you.
Old Sep 10, 2012, 04:43 AM
colbourne is offline
Find More Posts by colbourne
Canberra, Australia
Joined Jan 2003
People mention casting lead to fill the hollow bulb.
How much weight of lead can be inserted this way in to the standard bulb ?
I presume a plug is made and casting is into sand or something similar.
colbourne is offline Find More Posts by colbourne
Old Sep 10, 2012, 05:34 AM
chilisoling50 is offline
Find More Posts by chilisoling50
Joined May 2007
If you re using #9 lead shots for the keel. It will barely fit in at about 800gm.
We have tried it...
chilisoling50 is offline Find More Posts by chilisoling50
Old Sep 10, 2012, 08:07 AM
Canberra, Australia
Joined Jan 2003
I presume a cast keel would be heavier than shot. The bulb would be opened and the cast blob placed inside.
Alternatively the bulb could be disgarded and the lead used instead.
Still curiious how heavy a cst blob cann be inserted in the supplied bulb.
Old Sep 10, 2012, 05:06 PM
mrpenguin is offline
Find More Posts by mrpenguin
Australia, TAS, Penguin
Joined Mar 2012
@Colbourne:
There are now at least two versions of the Surmount. If you have purchased the boat recently, it will be different in that the keel bulb is a different shape.
One the earlier versions, the keel bulb was circular in cross section. If you tried hard you could get it up to maybe 700 grams gross weight.
The newer version keel bulb is somewhat larger and is more oval in shape (wider than high),and is also probably a little longer. Empty weight is 38 grams. I filled mine with Number 8 shot, now weighs about 980 grams. Take your time and pack the shot in firmly with a pencil or similar item.
This is plenty of weight for this boat. Here is some video of mine in very rough conditions:
Surmount in windy conditions (2 min 38 sec)
Recommended mods:
Add flotation
Replace the backstay bowsie BEFORE it breaks
Seal the hatch with tape
mrpenguin is offline Find More Posts by mrpenguin
Old Sep 10, 2012, 07:52 PM
Hircsailor is offline
Find More Posts by Hircsailor
Kimo
United States, HI, Honolulu
Joined Jun 2011
Nice video showing how the boat handles in both heavy and light winds. The canal that you are sailing in remindes me of the Ali Wai canal across the street from me. The only trouble is that there a strong currrents, mud flats from side creeks,lots of different hights of stone bottoms so you are never sure if you might run aground or not. Not to mention the strong wind that blows down the canal. The final straw is that if the boats grounds on the far side of the canal its a mile to the nearest bridge so a 4 mile round trip to reclaim your boat. So I will stick to the salt water tidal pond that we use.
Hircsailor is offline Find More Posts by Hircsailor
Old Oct 10, 2012, 05:36 AM
SilentPilot is offline
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Now then guys!
Glad I found this thread. I'm having trouble filling up my ballast weight myself, just does not seem big enough...
Picked up some top tips here. Maybe extending the keel with 850/900g will do for starters
SilentPilot is offline Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
For Sale 1/2 Model of 24' Bridges Point Sail Boat astrout99 Boats (FS/W) 0 Mar 27, 2011 10:20 AM
Help! Pro Boat Endeavor sail servor toyturn Sailboats 3 Mar 07, 2011 07:53 PM
For Sale One speed boat one sail boat BK 1125 Boats (FS/W) 12 Feb 19, 2010 05:48 PM
Discussion What's better? A question about weight and ballast. Wildewinds Hand Launch 9 Jun 08, 2006 09:43 AM
max ballast weight in banana? ando Sailplane Talk 0 Jul 01, 2005 07:52 AM
