Old May 24, 2011, 03:29 AM
Chrizz is offline
Find More Posts by Chrizz
OY-5542
Chrizz's Avatar
Denmark, Central Denmark Region, Silkeborg
Joined Nov 2009
Build Log
Grumman Albatross Twin Engine
Hi!
Name: Grumman Albatross side view.png
Description: Name: Grumman Albatross.png
Description: Name: Grumman Albatross 'turning' view.png
Description:
Finally, she's ready for maiden flight!
Ultra Micro Grumman Albatross Movie (0 min 58 sec)
Original plans (intended for paper) are from http://www.bobscardmodels.net76.net/ .
Name: Bobscardmodels Grumman Albatross.jpg
Description:
The plane is made of Epp (3mm), Depron (mostly 3mm, some 6mm) and the wing has a balsa spar.
- Winspan aprox.: 52cm
- Length aprox.. 39cm
- estimated weigth : 50g
- AR6400 just rudder and elevator
- 2 x PZ J-3 Cub motor/gearbox/prop in parallel (Amp reading with cold motors, full throtle : 1,91amp at most)
I haven't maidened it yet, but glidetests are good. CG seems correct and it doesn't look like all these cables in the wing sets it to high vertically either.
During glidetests, she also showed her ability to auto-stabilize her flight. I might have got that dihedral and the V right this time!
Name: Grumman Albatross front.png
Description: Name: Grumman Albatross rear view.png
Description: Name: Grumman Albatross belly view.png
Description:
Additionnal landinggear is under constrution
Ultra Micro Grumman Albatross landinggear prototype (premounted on fuselage).mp4 (0 min 15 sec)
Chrizz is offline Find More Posts by Chrizz
Old May 24, 2011, 04:51 AM
gklein is offline
Find More Posts by gklein
Gary
gklein's Avatar
USA, CT, Sandy Hook
Joined Dec 2009
Wonderful job. I love it. Please tell us how you formed the fuselage. What is the span?
gklein is offline Find More Posts by gklein
Old May 24, 2011, 05:43 AM
Chrizz is offline
OY-5542
Chrizz's Avatar
Joined Nov 2009
Thanks!
The upper part of the fuselage is made out of 3mm Epp sheets, while the bottom is made of 3mm Depron. The Plan's drawing gives the fuselage it's form naturally (more or less:-)).
I first made, seperately, the bottom of the fuselage (in 3 main pieces). The upper section from the nose to just behind the cabin. The upper main fuselage, from behind the cabin to and with the tail. Allready then form was taking. Then, with two bulkheads, I assembled the upper main and the two lower main fuselages. Same for the nose/cabin section...
Name: Cross Section Fuselage.png
Description:
Look at these plans, they're more or less exacly what I did : http://www.bobscardmodels.net76.net/
Of course it requires a lot of cutting, sanding, bending and adjusting!... But it's great fun
Wingspan is aprox. 52cm and length aprox. 39cm
Old May 25, 2011, 03:51 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Very nice job. The Grumman has been on my list to build for a while. But, you've done it. Excellent.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old May 25, 2011, 07:28 PM
Chrizz is offline
OY-5542
Chrizz's Avatar
Joined Nov 2009
Grumman Albatross
Finaly maidened her! And she flew!
Name: Grumman Albatross black'n'white front view.png
Description: Name: Grumman Albatross black'n'white side view.png
Description:
I started with some glidetests to verify CG and trims. Sure she isn't a glider, but CG was confirmed suitable and no trim were needed. She didn't show any signs of disymmetry or bad behaviour. Made a few turns, just good. So far so good!
Next step: Simple gentle trow, with engines on, just flying straight. I was quiet scared of this flight-test-step. Would the motors have the right angels, what would they induce on the planes flight? ... Well, she just flew staight! Yupi!
Only thing thing left to do was to perform her first powered flight with turns. Maiden flight ! : Facing the wind, throtle at approx. 50%, a very gentle throw and there she went. The trust/weight ratio is good, she is climbing decently to the sky. Pitch control is soft but precise, no stall in sight. Throtle does affect the pitch just enough, but not to much (like on a real one). Getting to the first turn, I started pulling on the rudder... she started banking slowly and very softly, I barely had to correct the pitch. No noticeable loss in altitude while turnigng (without pitch correction) and the nose didn't want to point out of the turn, but followed it better than I did expect. She did turn better to one side than the other, I must correct those angels on the motors. Getting out of a turn needs quite some opposite rudder and the shifts are very slow. It does need anticipation.
My very first general impression of the Grumman Albatross's flight is astonnishingly good and it is satisfying for me how well she flies. Controls are respondant and precise, even if induced banking is slow. It makes it look relly realistic, massive, imposing! Thrust is there and the motor angels are allmost good. Speed is low, comparable to a UM T-28. It looks like she can handle some wind.
WHAT A GREAT SUCCESS !!
I'll try to get somebody to film soon, so I can post a/some flightvideo(s).
Grumman Albatross Movie engines running (0 min 58 sec)
(this is not a flight video)
Old May 25, 2011, 07:38 PM
Chrizz is offline
OY-5542
Chrizz's Avatar
Joined Nov 2009
Gordon
Give it a try! This plane was really fun to build and, if you have a look at the plans (http://www.bobscardmodels.net76.net/), you'll see that it's not that complicated. Mostly the difficult part is to visualise forming the plane with very few bulkheads.
I think I might want to build another one, but this time with ailerons maybe also with separate flaps?... I still have to finish the landinggear (dismountable) for this one...
...then, do I want to make it floatable ? ...
Old Aug 22, 2011, 06:13 AM
Wingnut31 is offline
Find More Posts by Wingnut31
Starting to Rebuild
Wingnut31's Avatar
Fayetteville NC
Joined Jun 2006
Chrizz that one slick lil plane. I do want to build this, I would live to see how you have the RX, ESC and the motors wired and set up. I was thinking about using my old PZ Cub guts and a second PZ Cub motor wired in parallel but i wasnt sure if the esc would handle the extra amps. Whats your take on this. Thanks for sharing your link with me.
Wingnut31 is offline Find More Posts by Wingnut31
Old Aug 22, 2011, 10:11 AM
Chrizz is offline
OY-5542
Chrizz's Avatar
Joined Nov 2009
Hey Wingnut31!
Using two UM Cub J-3's motor/gear/prop setups in parallel is a nice idea, but I'm not sure that the 3-channel brick from a UM Cub J-3 will handle the necesary amps. I do know, that it works fine with i.e. a AR6400, since the two motor/gearbox/prop setups will draw around 1,91 amp (max reading with new, cold, motors at imediate maximum throttle) and that a AR6400 allows 2 amps. Check out if the Cub's brick also will handle 2 amps or not and do keep in mind that the motors will draw more amps while aging. You'll need to check amp-readings regularly to be sure.
Name: Parallel motor wirering.png
Description:
If you look towards the end of the first video, you'll see the inside of the fuselage with some of the (only) two cables going up to the wing and the connecter I've installed to ease the acces for amp readings.
If the UM Cub J-3's brick isn't enough and you then get i.e. an AR6400, you could consider adding ailerons to the build (single servo with bellcrank or double servos with flap/spoiler programming option?). Or Ailerons and flaps!? I'm sure weight would not be that a big issue with the twin UM Cub J-3 setup.
It would of course add some building to the project. On my Grumman Albatross there are no ailerons or flaps... Its wing is made like on Bobscardmodels plan: two wing formed sheets, extrados and intrados (for each half wing). The extrados is a bit larger than the intrados, so that when glued together, the larger extrados (made of flexible 3mm EPP) forms a curve while the intrados (3mm Depron, stiff) remains flat. To obtain a look-alike Clark Y profile, the intrados leading and trailing edges has been cut to angles that leads the extrados to a correct curve. At the same time the angles helps reducing the edges thicknesses.
Name: Wing, edges.png
Description:
I think it would be farely easy to cut out the ailerons of both intra- and extrados. Then not cut an angle in the intrados where the ailerons are located, but only along the rest of the trailing edge. Glue it together giving the wing its profile and then sand down some ailerons out of 6mm Depron. The same thing could then also be done for flaps.
Whether build with one or two servos for ailerons, an interesting question is, if the servo(s) should be mounted inside the fuselage with torsion bars connecting it (them) to the ailerons. It would look prettier that two servos mounted under the wind for a dirrect attack on the ailerons. Another solution could also be to try to place them in the motor nacels, or even in the thickness of the wing. ???
Old Aug 22, 2011, 04:40 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
The J3-Cub brick is a modified 3-CH AR6400 with a 2amp ESC.
TODD
I R Irv is offline Find More Posts by I R Irv
Old Aug 29, 2011, 11:06 AM
Starting to Rebuild
Wingnut31's Avatar
Fayetteville NC
Joined Jun 2006
Some good ideas in there, I will keep you posted on how it goes, I will likely have to send it to Kwinters to test fly it for me, I ahve already been warned that anyting I try to fly here will be taken. Being im so close the LZ i wont be allowed to fly. Bummer.
I figured out the building board situation, Amazon had some laptop boads that look like they will work well. Made of EPP like my kayaks so warping shouldnt be a problem.
Old Aug 29, 2011, 05:00 PM
Chrizz is offline
OY-5542
Chrizz's Avatar
Joined Nov 2009
Originally Posted by Wingnut31 View Post
Some good ideas in there, I will keep you posted ... ... my kayaks so warping shouldnt be a problem.
Yes, please, keep us posted!
Sorry to hear that you have been grounded... :-)
Have a good build
Chris
Old Aug 31, 2011, 04:02 AM
indoor_fr is offline
Find More Posts by indoor_fr
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Hi Chrizz,
I like it very much! Good work!
This could be a nice project for me, as i was planning to build a seaplane (there is a little lake nearby).
I would make a 24" ws version with EPP.
indoor_fr is offline Find More Posts by indoor_fr
Old Dec 30, 2012, 02:37 PM
Chrizz is offline
OY-5542
Chrizz's Avatar
Joined Nov 2009
Starting a second build, but with ailerons and flaps!
Hi!
I've been wanting to build another version of a Grumman Albartoss, but this time with ailerons and flaps.
The precedent build was a simple RET with dihedral. It flew great, almost like a trainer, but was slow to react on yaw-input, with its relatively small rudder and the twin-engine setup. Still it flew great, but needed quite some anticipation.
After a lot of thinking, I've decided to setup both ailerons for a single servo and to link the two flaps to one single servo too.
I've considered having a servo per aileron (more precise control, stronger, mixing possibilities: fine tuning- differential- flap/spoileron), but the challenge of building a single servo system with hidden linkages and bellcranks inside the wing, while hopefully saving some weight and maybe even some electrons (?), is too tempting!
Name: Grumman Albatross - aileron & flap linkages 003.jpg
Description: Name: Grumman Albatross - aileron & flap linkages 004.jpg
Description: Name: Grumman Albatross - aileron & flap linkages 002.jpg
Description:
The flaps will use the same setup as seen on HH's UM T-28's ailerons, mounted beneath the wing (the wing is 6mm thick where the scotch-tape-hinges are located, which will give the flaps a nice movement downward). Both flaps will be linked to a single AR2000l inside the fuselage.
Name: Grumman Albatross - aileron & flap linkages 001.jpg
Description:
Old Dec 31, 2012, 04:46 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
i love anything twins. how did you build the fuse the first tome around? foam core, or formers and skin?
subbed.
nemoskull is offline Find More Posts by nemoskull
Motor calculations for Grumman Albatross Van Power Systems 2 Apr 22, 2009 05:14 PM
Question: should I gear down a Grumman Albatross? Van Scale Kit/Scratch Built 4 Jan 31, 2002 07:34 AM
Paint for Grumman Albatross? Jedd Scale Kit/Scratch Built 11 May 30, 2001 10:53 PM
GRUMMAN ALBATROSS VIDEO-ANYONE? CESARNOGUEIRA Electric Ducted Fan Jet Talk 0 May 26, 2001 10:47 AM
Grumman Albatross Flaps? Jedd Scale Kit/Scratch Built 3 May 10, 2001 08:35 PM
