Old May 23, 2011, 07:05 PM
Florida Mike is offline
Find More Posts by Florida Mike
Florida Mike's Avatar
United States, FL, Jupiter
Joined May 2011
Avroto 2814 vs. Avroto 2814 short shaft
Has anyone used the short shaft version? I contacted Monto yesterday to be notified when they arrive as the web site had a May 23-25 estimated delivery time and now today there is a price increase and an end of June estimated date.
I guess my question is if there is any disadvantage of just going with the standard shaft?
I am also looking at the Hyperion ZS-2213-22 but I have a concern about the 3mm shaft.
Thanks in advance,
Florida Mike is offline Find More Posts by Florida Mike
Old May 23, 2011, 07:10 PM
jpsabo is offline
Find More Posts by jpsabo
jpsabo's Avatar
Joined Feb 2011
Avroto
For a frame with 1 motor per arm there should be no problem. Where I see a problem would be with frames using 2 motors per arm and having the shafts get in the way.
Regards,
John
Thanks in advance,
jpsabo is offline Find More Posts by jpsabo
Old May 23, 2011, 07:12 PM
Dolby is online now
Find More Posts by Dolby
Needs more bacon!
Dolby's Avatar
United States, WI, Milwaukee
Joined Jan 2011
When I talked to Monto the only difference is of-course the shorter shaft so it doesn't stick out the bottom the motor and 600mm wire length so you can run the motor wire to the center of the frame and hide your ESCs.
Since these will be for my flat hexa they will work great as is. I have a y6 I want these on as well and tempted to wait until the end of june.
From what I've seen you can cut the shafts your self. Best done on a lathe but can be done with a dremel just need to keep the shaft cool.
Dolby is online now Find More Posts by Dolby
Old May 24, 2011, 06:17 PM
Joined May 2011
I guess I will just order one each of the Avroto and Hyperion and do some comparisons and testing. That will at least give me something to do while all of the other components sit here.
Discussion Does anyone know anything about the new Avroto 2814 770KV motors at MontoRC? Mactadpole Multirotor Electronics 136 Jul 06, 2013 11:33 AM
Discussion What Props for Avroto 2814-11s nicnaimless Multirotor Talk 2 Jun 24, 2011 04:28 PM
Question Avroto 2814 short shaft Dolby Multirotor Talk 2 May 16, 2011 04:29 AM
Discussion Avroto 2814 or turning or .... ? mantrid Multirotor Talk 1 Apr 07, 2011 09:19 PM
Discussion AXI 2814, how to REVERSE the Shaft? wattzup Power Systems 6 Nov 04, 2010 12:50 PM
