Canada, QC, Montreal
Joined May 2011
Help, Batteries get hot, motors extreme hot
Hi, I am new to this hobby so please anyone helping will be well appreciated. I'm not sure how bad but I think I have a temperature problem.
I modified this relatively cheap boat (http://www.raidentech.com/1scspxrareco.html) and added a real rudder with a servo and another servo mechanism to deploy a fish line. The extra hardware and a base made of wood to hold the servos, receiver and an ESC, as well as a plexi-glass for cover to make it water tight, so this added quite a bit more weight. See pics. The twin motors are supposed to be 380 type but I think they are a little bit bigger (I measure their length to be 44 mm, Mabuchi spec sheet have the 380 at 38mm). The battery pack that came with it is a 7.2v Ni-CD 1800 mAh. So, in it's maiden voyage I continuously run the boat at full throttle for 8-10 minutes. The boat seemed to be going at 5-6 mph rather than the racer type speed of 20 mph or more. After opening the cover and touching the motors and the small heatsink on them, they were extremely hot, I could barely keep my finger on it more than 3-4 secs. What surprised me more though is how hot the battery got. I could hold it in the palm of my hand but was very hot. The ESC got barely warm. I've read that batteries and especially motors get hot that's why they employ water cooling, but what bothers me is the battery. Has anyone experienced this kind of heating problems, are the motors too small for the extra weight, is the battery stressing to support the current demand, is this because it's a cheap battery and it's internal resistance is high. Do I need a better quality battery? How am I going to ran the motors and battery cooler. Thanks in advance!! |
Joined May 2011
Hi Jan,
I suppose one of these factories is Mabuchi Motor Co. They have a list of motors, see here http://www.mabuchi-motor.co.jp/en_US...ct/p_0304.html However in the spec sheet they don't state the number of poles nor the number of turns as many ESC's call for. How do you figure all that. And then looking around on Ebay or other online sellers some say some don't, what number of RPM falls in the low revving ones of the 550 type? Mabuchi shows two models (http://www.mabuchi-motor.co.jp/cgi-b..._ID=rs_555pcvc) one of which is RS-550PC at 7.2v, 15300rpm no load, is that ok. Isn't driveline drag the same in either series or parallel connected motors. since the same current must flow in both motors at some point both motors will turn, granted not at the same speed. On most of the rc boats, water cooling is the way to go, but for speed boats. What about my boat at 5 to 10mph, is that enough speed to pull in water and cycle it around a tube?? Will a heat sink like this one work just well enough. regards, Yiannis |
Joined May 2011
Hi Jan,
Again thanks for your replies. I actually gave you the link to the wrong motor. Quote:
I was looking at the 550 motor and gave you the link to the 555, sorry. Those are 12 volt and much less RPM (4800 rpm) and current. This is the link I meant, (http://www.mabuchi-motor.co.jp/cgi-b..._ID=rs_550pcvc), This is much higher RPM and a lot more current for 7.2 volt operation. I wander what sort of RPM, current, torque relationship I should look for 7.2 volt operation? I got the new 5.3aH Ni-mh battery and I'll try it, in series and parallel motor combinations. The inlet behind the prop should it be facing the prop or away from the prop, and can the outlet be above the water line from the side. regards, Yiannis |
| Thread Tools | |
| Discussion NiMH Batteries get hot during charging | Warthog_Fan | Batteries and Chargers | 5 | Jul 21, 2008 10:09 AM |
| Discussion CX motors get really hot but..... | Blade_Killer | Coaxial Helicopters | 17 | Oct 30, 2007 09:59 PM |
| Discussion CX motors get really hot but..... | Blade_Killer | Coaxial Helicopters | 2 | Jun 11, 2007 08:08 AM |
| Help! How hot should brushless main motors get? | Jeff2005 | Micro Helis | 6 | Apr 11, 2006 04:47 PM |
| How hot do your batteries get in your Shogun/Zoom? | 14U2NV | Mini Helis | 7 | Jun 01, 2004 09:34 PM |
