This thread is privately moderated by MikeTheCrash, who may elect to delete unwanted replies.
Old May 23, 2011, 08:00 AM
MikeTheCrash is offline
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
Funjet improvements
So the Funjet has been having a few problems with the IMU picking up vibration from the prop. I have a new motor and prop and this problem is a new one really. The second APC prop I had on it was vibration-free. I ought to buy a prop balancer but instead, after much fiddling around, I have found the best layout for IMU with foamn damping.
I have inserted a tooth pick parallel to and about an inch from the wing spar. A small chunk of foam is hot-glued accross the toothpick and the wing spar. The IMU, wrapped in a piece of tape to protect it from the glue, is stuck to the foam
Next up is to improve the aerodynamics of the camera mount. I had the cam attached by elastic bands into a "chair" carved into the front of the canopy. This I then upgraded to a 180 Pan servo. But the body of the servo was glued into the top of the canopy and the camera was sticking out into the airstream, which made me unhappy. I have stuck some balsa in the front of the fuse (where I had originally intended to put a pan/tilt as seen on my avatar but never flown) and now the pan servo sits in that. I hope to find an aerosol lid to make this more streamlined one day. I have carved the canopy a bit to let the camera pan freely.
EDIT with this setup and the keychain camera on the nose the FJ is hard to balance with a big battery. I have to squeeze my 2700mAH right up the fuse to the wing spar and it's a tight fit, and the 4300mAh won't work. This may need another re-think. Perhaps if a make a cowl for the camera i may put the keychain on top of it, alternatively swapping the FPV camera for a board camera may do it, my camera is very heavy.
MikeTheCrash is offline Find More Posts by MikeTheCrash
For Sale Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra sotog Aircraft - Electric - Power Systems (FS/W) 0 Apr 01, 2011 01:47 AM
For Sale Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra sotog Aircraft - Electric - Power Systems (FS/W) 0 Mar 25, 2011 01:41 AM
For Sale Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra sotog Aircraft - Electric - Power Systems (FS/W) 5 Mar 19, 2011 01:52 PM
For Sale Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra sotog Aircraft - Electric - Power Systems (FS/W) 5 Mar 11, 2011 07:31 PM
For Sale Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra sotog Aircraft - Electric - Power Systems (FS/W) 0 Mar 04, 2011 02:38 AM
