HK Ryan STA EPO build
Wiki link for Ryan ST series:
http://en.wikipedia.org/wiki/Ryan_ST I think this presents a reasonably good history of the aircraft and it's variants. Another GREAT link: http://www.flickr.com/photos/sdasmar...7626514780879/ San Diego (Ryan's HQ was always here) Air & Space Museum's photo archives, Ryan Aeronautical collection on Flickr's servers. Tons of great photos that show the development of ST/PT variants and "users". Some have a real artsy-fartsy flavor (aroma?) to them. I guess because the basic design of the aircraft is so pleasing to begin with. I've grabbed a pile of these pics and put them in the screensaver of my 27" iMac and whenever inactive for a few minutes, a cool vintage slideshow automatically cranks up of all manner of Ryan ST/PT pics... Some show an STA piloted by "Tex Rankin". He's the guy that won the International Aerobatic Championship in 1937 in an STA (160hp supercharged version). I think he was a big celebrity around the Ryan plant after that! Somewhere in my on-line research I came across an image of a document that showed the price of a delivered basic Ryan ST (125 hp version) as I recall, about $6500! In depression-era money, that was a big pile of it! Before the US Gov't. and some other Gov'ts. came calling just before the war outbreak, it took a well-healed individual or one backed by someone well-healed to afford one of these then-cutting-edge little planes. Hope this helps and is enjoyed! Cheers! |
What I would be more concerned with is the weight of 29 oz. as this will mean you have to fly faster and need more power for that to avoid a stall. One thing that might help is adding a little incidence to the wing with a thin spacer at the rear. That will help the plane fly level, which reduces drag. But you could certainly reduce weight (a much better solution) without affecting the appearance -- which is important to you. The main alteration needed to reduce weight would be a smaller battery, moved forward, and the ESC moved forward, and removing the ballast. If you did this, I bet you could lose 3 ounces right away. It would take basically an evening to do that. And the cost of a 1300 mah 3S batt. I've moved both battery and ESC forward now, and will detail what I've done with photos in case it is of interest. |
vtdiy,
Yeah... turns out that I have a new 1300 mAh 3S that I bought for another project. I'll just have to make an EC3 to XT60 adapter and ***presto!*** The Ryan loses about 85 grams in a really beneficial spot. Michael the DLG pilot's comment was the Ryan has a "huge" elevator area and I'd probably do well keeping elevator rate/throw lower than Aileron or Rudder. But it sounds like your experience indicates the Rudder should be watched carefully too, to prevent low speed tip stalls. Is that an example of "coupling"? And--- you're right. Appearance is important to me, though I realize this HK (manufactured by Lanyu) model is "off" in a lot of places it's still a nice representation of a cool Thirties era aircraft! One other thing... HK still has on-line listings for the Ryan STA EPO but I checked Lanyu's website and they don't list it anymore. Could be a BH and HK exclusive I guess... Cheers! |
re my masking tape paint pull-off -- I was actually doing a test trying to pull off paint. You can use masking tape to remove paint on foamies if you plan on re-painting. It works better on some foams than others. Looks like it will be easy on the Ryan as I was only using low tack tape in the test.
Gents: I've had my ryan for sometime now (oh yeah since cristmas) I've flown it stock with a 1800mah turnigy stuffed up front.Not a bad flyer -alittle fast but that's o.k.. YEAH THOSE RIVETS ARE BIG-ALMOST AS BIG AS THE WIFE'S
![]() I found out not by choice how well the paint comes off with tape,because the cowl was taped onto the fuse from the factory! Geez the cowl was snug on there to begin with,i mean snug gents! Those horking pieces of tape had no mercy no matter how careful i was. I mean to get the ryan out again before the end of the flying season(end of october) as she's not a bad plane for $89... cheers gents-k
$59.95 at HK now. Bet they're being closed out -- get one while you can, if interested. Both the Red and White and blue and orange are the same price. I think the red and white is lighter (less paint).
I did a fair amount of foam carving foprward on mine, mounted the ESC under the turtledeck just aft of the cowl line. Motor will definitely be an Emax CF2822. I removed the screws from the tail section, and also all of the plastic buttons/retainers there for those. I put most of the radio and motor gear aboard and weighed again and was down to just over 22 oz. Big change from the original 27 oz! That was encouraging enough to make me decide to re paint. I found the tape didn't pull the paint off very well after all. So I sanded the blue lightly, and sanded down the rivets -- left them slightly raised, but a lot less obvious. Brushed on diluted lightweight spackle, and sanded it back off. Then sprayed a first coat of Rustoleum #7718 Chrome. I got some elastic cord, and may add the flying wires back using that after a maiden. One negative -- I found the last owner had glued the wing on when he repaired the break in the wing. No way I'll get that off again, but I guess it isn't necessary. |
| Thread Tools | |
| Discussion Hobby King Pearl EPO Glider Thread | tomcor | Foamies (Kits) | 14 | Aug 19, 2012 07:39 AM |
| New Product Bananahobby Ryan STA | fieldflierlux | Electric Warbirds | 1 | Jun 28, 2011 08:58 PM |
| Sold RYAN STA EP Price reduced AGAIN | rev.iain | Aircraft - Electric - Airplanes (FS/W) | 1 | May 20, 2011 09:38 AM |
| New Product Hobby king new micro cessna 4 ch EPO 555mm WS with VIDEO | Cheetah401 | Micro RTF | 9 | Apr 18, 2011 04:11 PM |
| New Product Hobby King 2.3M EPO EP Ventus PNF | Doubletap | Electric Sailplanes | 1 | Apr 05, 2011 10:00 PM |
