Espritmodel.com Heli Air
This thread is privately moderated by beladog, who may elect to delete unwanted replies.
Old May 22, 2011, 05:23 PM
There's A Hack For That.
beladog's Avatar
San Diego
Joined Oct 2008
Aiptek Mod Manual For Semi-Advanced Hack
Ok so here is an abbreviated how to.
THIS MOD COVERS THE ACTION HD AND AHD PRO MODELS ONLY!!!
striking similarities between other models exist so many steps will work with other cameras as well. For example the A/V inputs etc etc.
This will remove the heavy cumbersome case and create a plug and play, FPV ready, Live out feeding, True HD camera, that is every bit as advanced and capable as a Go Pro, but only half the weight and much more streamlined!
If along the way you need more detail or explanation please feel free to post a comment with your question and I will modify the thread.
For now I will explain the basics which will get you well under way. I will go into much more detail with advanced techniques for really stripping down the camera and knocking off about another 15g! in just a few days as time permits.
Good Luck!!!
All the pictures are labeled with basic instructions and the picture descriptions go into a little more detail. Please read both carefully
If you do not own a LEAD FREE soldering station I would Highly recommend getting one. All the Solder on EVERY Aiptek is lead free. Adversly you should only be replacing/using a blend of leaded solder For all the steps below. I use and recommend 60/40 rosin core. Radio shack still carries this and its the best for strength and ease of use..032 is a great size for all your RC needs from .050 needle work up to 8gauge battery wire!
here is where I got IMO the best station money can buy at a price much lower than anything even close!!! The 2050+ from Black Jack SolderWerks
beladog is offline Find More Posts by beladog
Old May 25, 2011, 10:16 AM
Don't leave it Stock
mrfliboy's Avatar
USA, IL, Round Lake
Joined Feb 2004
Whats the max voltage it'll handle?? I'd like to power it with a steady 5v. Thanks for a great tutorial.
Did some more blog reading and found it. Thanks
3).Plug the Red Power Plug into your power source (i.e. on board receiver or any 4.8V source (5VMax).
mrfliboy is offline Find More Posts by mrfliboy
Old May 25, 2011, 06:14 PM
beladog's Avatar
San Diego
Joined Oct 2008
it will handle 5.5v all day long. If in airflow 6v is ok, but not recommended.
Build Log Slow Stick for AP with Mods, Aiptek cam mod, Strip LEDS for night flight(Plane RTF) TaSaJaRa Aerial Photography 44 Sep 08, 2009 09:01 AM
Article 1st U.S. R/C Flight School's Advanced Aerobatics Manual Review 78dave Sport Planes 5 Dec 19, 2008 05:19 PM
Discussion Mini SL hack/mod's IH8VTEC Micro RTF 28 Jul 26, 2007 01:12 PM
Question GWS DREAMSTARTER HACK/mod??? lostrider Radios 2 Mar 14, 2005 04:37 PM
