Old May 22, 2011, 11:59 AM
TBello is offline
Find More Posts by TBello
Joined May 2007
Help!
Reverse motor direction?
Hey guys... I'm only about a year into electrics and I've never come to this problem before now.
After hooking up the ESC to battery and motor the prop is moving in the wrong direction. Which on of the two colored connectors to the motor do I reverse, the black & red?
Thank you for your help..
Tim
TBello is offline Find More Posts by TBello
Old May 22, 2011, 12:12 PM
shultz is offline
Find More Posts by shultz
United States, NV, North Las Vegas
Joined Sep 2009
Why not just fly backwards
ANY two wires... with sensorless brushless motors it simply does not matter what two wires you choose... some ESC's and motors don't even have color coded wires
John
Edit:
Just read your post again... it this a BRUSHED set up? if so you don't want to reverse polarity at the motor UNLESS your sure the motor is timed for 0 degrees. If it's not timed for 0 Degrees and you reverse polarity it will not give as much power as it could and will not last as long as it should. Some ESC's have a program feature that allows you to reverse the motor, check that. Does this set up have a gear box? if so you may need a reversed pitch prop.
shultz is offline Find More Posts by shultz
Old May 22, 2011, 12:16 PM
TBello is offline
Joined May 2007
Thank you John, appreciate it. Didn't want to blow anything up. lol
Tim
Old May 22, 2011, 12:38 PM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Swapping any two of three wires is for the esc-motor connections, NOT the battery-esc connections (which is only two but you said black/red).
mw
Mark Wood is online now Find More Posts by Mark Wood
Question Name of 3D manuever: rolling harrier downward to reverse direction Neil_SC 3D Flying 11 May 10, 2011 12:02 PM
Question Brushed Motor - REVERSE Direction ? ? Sparkorama Electric Plane Talk 11 Feb 12, 2006 03:15 AM
To reverse prop direction of motor and gearbox?? mike93 Parkflyers 1 Mar 17, 2003 01:10 PM
Help - How to Reverse Motor Direction? AZ_Astro Beginner Training Area (Aircraft-Electric) 8 Dec 18, 2002 07:01 AM
OK to reverse motor direction? Battfly Power Systems 1 Nov 06, 2002 08:47 PM
