Old Oct 17, 2001, 08:47 PM
WKoltis is offline
Find More Posts by WKoltis
Woodridge, IL USA
Joined Jul 2001
Rotor Balancing
Since the search function doesn't seem to be working, I decided to just post a thread.
I'm curious as to what everybody uses for weight when balancing main rotor blades. Include your favorite method to fasten the weights on.
I know how much weight I need to add, and where to add it. I just want ideas on how to do it.
WKoltis is offline Find More Posts by WKoltis
Old Oct 17, 2001, 11:00 PM
misskimo is offline
Find More Posts by misskimo
TeamTP,Minicopter,Spartan
misskimo's Avatar
Mississippi 31 years , Now Kotzebue , Alaska 12
Joined Apr 2001
hey ,
well, I dont know if other guys uses the same methed as I do , but here it goes , well after you have the blades weighed out the same, then find the CGs of each blade and mark then with a pin and then stand them up against each other and see if the match each other , it not you will need to ad ( what I use is electrical tape) to help the CG to move and you will need to ad the same weight that you put on the end of the blade to the blade at the center of the cg mark , man I hope you catch my drift,
Tony
misskimo is offline Find More Posts by misskimo
Old Oct 18, 2001, 09:56 AM
wayne is offline
Find More Posts by wayne
Millarville,Alberta,Canada
Joined Jun 2000
Tony
I found this site, on blades. Have a look
http://www.helifever.com/intro/setup.cfm
Wayne
wayne is offline Find More Posts by wayne
Old Oct 18, 2001, 12:12 PM
ECOFlir is offline
Find More Posts by ECOFlir
ECOFlir's Avatar
Gardners, Pa. 17324
Joined Sep 2001
Thanks Wayne for posting that site. It's the best one I've seen.
ECOFlir is offline Find More Posts by ECOFlir
Old Nov 02, 2001, 12:05 PM
niek is offline
Find More Posts by niek
niek's Avatar
Almere, Netherlands
Joined Mar 1999
Is chordwise balancing needed too?
niek is offline Find More Posts by niek
MF 480 rotor balancing Olivier Electric Ducted Fan Jet Talk 2 Sep 13, 2010 01:00 PM
Corona Sub-Rotor Balancing Shiba Electric Heli Talk 13 Mar 08, 2004 05:09 PM
Corona Main Rotor Balancing k0tbt Electric Heli Talk 10 Feb 09, 2004 05:14 PM
Sub-Rotor balancing on Corona Orion_V Electric Heli Talk 11 Jun 27, 2003 09:46 PM
Corona Sub Rotor Balancing ??? johnitahoe Electric Heli Talk 2 May 26, 2002 06:42 PM
