Old May 22, 2011, 06:49 AM
Aaqib124 is offline
Find More Posts by Aaqib124
Joined May 2011
Help!
Throttle calibration problem of Hobbyking Blueseries ESC 20A
I have purchased 6 of these ESCs and whenever i enter the programming mode by putting the throttle stick at full and then powering the ESC,the beep sequence for brake setting starts. no beep is heard for the throttle calibration like mentioned in the manual. im stuck at the throttle calibration. anyone having the same problem? and what is the solution or am i doing it wrong?
Aaqib124 is offline Find More Posts by Aaqib124
Old May 22, 2011, 08:49 AM
powerlines is offline
Find More Posts by powerlines
I am ready for HHAEFI!!
powerlines's Avatar
United States, GA, Cochran
Joined Apr 2004
May want to increase your end points....
powerlines is offline Find More Posts by powerlines
Old May 22, 2011, 03:53 PM
Aaqib124 is offline
Joined May 2011
and how to do that?
Sorry im newbie here, so i might sound a bit silly asking such questions
Old May 22, 2011, 08:14 PM
powerlines's Avatar
Joined Apr 2004
That is in your radio setting.. They differ from radio to radio. In JR it's servo travel .. put up to 125% and down to 125% See what that gets ya.
Old May 23, 2011, 08:44 AM
philipa_240sx is online now
Find More Posts by philipa_240sx
philipa_240sx's Avatar
Ontario, Canada
Joined Apr 2010
I have a few of these ESC's which are sold under another name from a different vendor. The throttle range is self calibrating and is not programmable.
It will set 'zero' throttle at power up. Ensure the TX is ON, throttle at minimum, and trim centered before powering the plane. If you don't follow this startup procedure, you will end up a motor that needs a fair bit of throttle before it spins.
Full throttle appears to be preset and should work with most TX's.
Of course if you fly Futaba, then you need to reverse the throttle channel to make these ESC's work.
You may want to pick up the programming card if you get a chance:
http://www.hobbyking.com/hobbyking/s...dProduct=13431
philipa_240sx is online now Find More Posts by philipa_240sx
Old May 23, 2011, 08:30 PM
Doug Bartley is online now
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
It may sound silly, but are you plugging your esc into the right port on the rx? JR trottle port is #1 and Futaba is #3. Do you have it plugged in upside down? Nothing works in either case.
Just thought I'd ask, I just did it myself today while programming a new esc.
I can be done!! hehe Doug B
Doug Bartley is online now Find More Posts by Doug Bartley
Mini-HowTo HK 30A BlueSeries ESC schematic and I2C/TWI mod [TwisteR] DIY Electronics 29 Sep 25, 2013 08:44 AM
Help! Phoenix Ice 75A - Throttle calibration. sgomes Power Systems 4 Apr 29, 2011 12:07 PM
Discussion No throttle Hobbyking Corsair 20a brushless bbells Power Systems 6 Feb 24, 2011 12:27 PM
Discussion Hobbyking SS Series 18-20A ESC High PWM firmware ? fmelle DIY Electronics 3 Aug 17, 2010 01:56 PM
Discussion Suppo 20A ESC throttle calibration procedure khaled_abobakr Power Systems 7 Apr 10, 2010 04:28 AM
