Old May 22, 2011, 07:48 AM
Aaqib124 is offline
Find More Posts by Aaqib124
Joined May 2011
Help!
Throttle calibration problem of Hobbyking Blueseries ESC 20A
I have purchased 6 of these ESCs and whenever i enter the programming mode by putting the throttle stick at full and then powering the ESC,the beep sequence for brake setting starts. no beep is heard for the throttle calibration like mentioned in the manual. im stuck at the throttle calibration. anyone having the same problem? and what is the solution or am i doing it wrong?
Aaqib124 is offline Find More Posts by Aaqib124
Old May 22, 2011, 10:29 AM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
I have 3 of these coming in the next week or so . I'm interested to know this as well
Wilfor is offline Find More Posts by Wilfor
Old May 22, 2011, 04:54 PM
Aaqib124 is offline
Joined May 2011
Sure i'll update here as soon as i get them calibrated
Old May 22, 2011, 07:51 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
No, there's 4 beeps first which means throttle calibration, then followed by _*_* for brake.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old May 22, 2011, 11:33 PM
rogue277 is offline
Find More Posts by rogue277
Joined Dec 2010
The exact same thing happens to mine. I have just been assuming that I can't cal the throttle without also toggling the brake. I just repeat the process to make sure the brake is off, and I assume that along the way it gets the throttle cal. I've been meaning to get a programming card for these model escs.
rogue277 is offline Find More Posts by rogue277
Old May 22, 2011, 11:36 PM
timecop is offline
Joined Dec 2010
There's regular beeps before brake setting beeps. Its really easy to tell the difference.
Old May 23, 2011, 04:05 PM
Aaqib124 is offline
Joined May 2011
@timecop
Yes i know there should be a beep like . . . . indicating throttle calibration but the sequence directly starts from _*_*..what should i do?
Old May 24, 2011, 10:51 PM
dt8666 is offline
Find More Posts by dt8666
Joined Oct 2005
My last test was the same. The calibration will toggle the brake.
So I will do the calibration once more if the first has brake on.
dt8666 is offline Find More Posts by dt8666
Old May 31, 2011, 06:20 PM
Artie in Aus is offline
Find More Posts by Artie in Aus
Australia, NSW, Batemans Bay
Joined Feb 2011
Howdy, I use this esc as well and it seems correct that the beeps which set the brake are the first that you hear.. but... doing the full to low throttle change in the first 4 seconds does the calibration AS WELL as the brake on/off... so you have to set the brakes to on and then do the cal which also turns the brake off.
Stooopid programming.... I just bought a program card......
Artie in Aus is offline Find More Posts by Artie in Aus
Old Jul 21, 2011, 01:51 PM
rogue277 is offline
Joined Dec 2010
I recently bought a batch of the 12 A blueseries ESCs. This particular batch does not suffer the effect of throttle cal toggles braking option. Nonetheless, i'm using the programming card.
Mini-HowTo HK 30A BlueSeries ESC schematic and I2C/TWI mod [TwisteR] DIY Electronics 29 Sep 25, 2013 09:44 AM
Help! Phoenix Ice 75A - Throttle calibration. sgomes Power Systems 4 Apr 29, 2011 01:07 PM
Discussion No throttle Hobbyking Corsair 20a brushless bbells Power Systems 6 Feb 24, 2011 01:27 PM
Discussion Hobbyking SS Series 18-20A ESC High PWM firmware ? fmelle DIY Electronics 3 Aug 17, 2010 02:56 PM
Discussion Suppo 20A ESC throttle calibration procedure khaled_abobakr Power Systems 7 Apr 10, 2010 05:28 AM
