OK Feda,
I admit the plane is a great flyer and I'll be honest to combo motor is a freight train. But, that damn prop adapter that comes with the motor must be made of butter. A nose over on landing and its bent to buggery and wobbles like an old woman's left jug! Any chance of replacement prop adapters for this 1000kV motor? Or any recommendations from Hk or the like? |
Latest blog entry: full scale
I buy my prop adapters from here bigroger ,all top quality and cheap postage
http://www.aircraft-world.com/shopdi...+PROP+ADAPTERS |
Thanks Wooshka.
On closer investigation just now it is the motor shaft rather than the adaptor that has the death wobble. |
Well, about an hour of motor surgery and the shaft is straight again and running true.
I've got a turnigy Light wood e 13x6 I want to try and see if it takes some of the amps off the battery during flight. I tried it today but with the bent shaft I'm not sure I got a true idea of its performance. Sure sounds a lot different to the APC 13x6.5e I had on at the start. |
What a sweet fleet Groove.
Very nice indeed. I must admit the three times I've tossed my Extra300L into the air it certainly draws a crowd. Every one that wanders over cannot believe its EPP foam. (I don't tell them it EPO under the skin). They see me ripping up blenders and KE's and flat upright and inverted spins and lovely KE spins then they say 'Oh it a foam plane'. Groove, what motor prop combo did you and Nac end up settling on for the 48" planes? |
Thanks guys.
Bigroger, Nac and I are currently happy with a Scorpion 3020-890 and APC 13x6.5e for good power and great efficiency. I tried a Vox 14x7 wood prop on the Scorp and it gives a bit more thrust at higher amps but the APC 13x6.5e is sufficient for the way I fly and the APC props are much cheaper; an important factor when I break props on these planes all the time! Here's a video of my Extra from yesterday. It's only in standard definition at the moment since I used up my Vimeo HD quota on my Yak video. I'll update it to HD when I can. http://www.vimeo.com/30260612 |
. Lately it seems that many of my Hobby King orders are going via Singapore, so the next time one passes through can you give it a push to speed it along ? .Quote:
I get my APC props from www.aircraft-world.com in Japan. Shipping is so cheap you won't believe it! Try www.windrider.com.hk for Scorpion motors. |
Just put another 3 packs through mine this morning.
Getting lower and lower every pack. Its so responsive in harrier and hover and knife edge without being over aggressive. I swapped out the corona Digitals in the wings for the MG14's and it feels far more predictable in the response of the ailerons. Its a hover beast, so easy. Still haven't worked out how to correct the torque roll yet without popping it out of hover each time. Maybe I need to gain a little more finess on the sticks. Had to pack up early as dodging the damn council pack mower was getting too damn difficult. Love this plane. |
Ok Feda,
I really need you to investigate replacement motor shafts for these AX3715 1000kV motors please. I had a go at straightening mine the other day, but it seems every time I have a slight nose over on landing I cause the shaft to bend a little and gets a wobble. I've sent an email to 'Max'. Not sure if that is you or one of your people in China. If you can get these shafts I'll buy a few to be on the safe side. I'd rather buy some then try and buy a generic and grind the grooves and so forth to try and make it fit. |
| Thread Tools | |
| New Product The Good Getting Better: Skywing's 48-in MXS | feda | 3D Foamies | 2160 | Apr 21, 2013 10:29 PM |
| Discussion Extra 300L | woodfit | 3D Foamies | 2 | Apr 21, 2011 05:31 PM |
| Sold Hirobo Extra 300L ARF NIB | 4wt | Aircraft - Fuel - Airplanes (FS/W) | 0 | Apr 02, 2011 10:15 AM |
| Sold **REDUCED**Hirobo Extra 300L ARF NIB | 4wt | Aircraft - Fuel - Airplanes (FS/W) | 0 | Mar 05, 2011 12:52 PM |
| Discussion !new DW foamies BAF 48" Extra 330 and 300L! | appleflyer | 3D Foamies | 91 | Aug 24, 2010 10:00 PM |
