Old May 21, 2011, 12:07 PM
cooler69 is offline
Find More Posts by cooler69
Singapore
Joined Dec 2010
Help on Evo pro spektrum module conversion
Hi, anyone can help on Multiplex EVO Royal Pro 16 V 3.41 to convert to use DM8 spektrum module?
cooler69 is offline Find More Posts by cooler69
Old May 21, 2011, 12:59 PM
tadawson is offline
Find More Posts by tadawson
tadawson's Avatar
Lewisville, TX
Joined Dec 2003
The biggest question is why? Since you are not in the US, you could use the Multiplex M-Link 2.4, which is light years better than Spektrum . . . especially considering that Spektrum isn't doing DSMX in their modules - you would be stuck with DSM2 which even Spektrum is getting rid of . . .
tadawson is offline Find More Posts by tadawson
Old May 21, 2011, 11:45 PM
cooler69 is offline
Singapore
Joined Dec 2010
The main purpose to change is to use with many of my spectrum receivers and on parkzone micros.. Also very user friendly on Evo Tx.
Old May 21, 2011, 11:47 PM
cooler69 is offline
Singapore
Joined Dec 2010
I'm new.. Please help
Old Aug 08, 2011, 10:40 AM
Slingjet is offline
Find More Posts by Slingjet
Joined Aug 2011
I have the same issue:
My EVO 9 is an old friend and I also would like to use it for the nice ParkZone Bind-And-Fly models where the Spektrum rx is integrated in the electronics.
I recently received a Spektrum module for internal mounting in the EVO but have not been able to make it work.
My software version is 3.41.
Somebody claims that there should be a PPM signal coming out of the trainer port but I see no PPM signal?
Did I miss something?
Thanks!
Slingjet is offline Find More Posts by Slingjet
Old Aug 08, 2011, 06:57 PM
ek123 is offline
Find More Posts by ek123
United States, CA, Irvine
Joined Sep 2004
Hi,
Maybe this thread will give you some help:
http://www.rcgroups.com/forums/showt...t=evo+spektrum
I believe from reading various threads on the EVO and conversion to 2.4GHz 3rd party modules that firmware versions > 2.62 do not output PPM on the internal deck pins but do output PPM on the trainer port. There is another thread on converting to the Hitec 2.4GHz system with lots of info. I suggest you read through that thread also. I converted a Royal Evo Pro with v2.62 to a Frsky DIY module no problems using the internal deck.
Hope this helps some.
Regards,
Eusebio
ek123 is offline Find More Posts by ek123
Old Aug 09, 2011, 09:01 PM
CustomPC is offline
Find More Posts by CustomPC
CustomPC's Avatar
Australia, NSW, Cherrybrook
Joined May 2004
I think you have to downgrade your firmware to v2.62 (??) as v3 and above are specifically for the M-Link modules and do not emit a PPM signal that the Spektrum module can use.
CustomPC is offline Find More Posts by CustomPC
Old Aug 10, 2011, 05:46 AM
GlowFly is offline
Find More Posts by GlowFly
GlowFly's Avatar
Midlands, UK
Joined Jun 2004
The problem is that the Evo attempts to interrogate the RF module at power up to work out what protocol to use. Certain synth modules and the 2.4GHz modules use a serial protocol not PPM. v2.61 and earlier defaulted to PPM on the internal module connector if no reply was received from a module. After that version the default is to assume no module is fitted making it awkward for 3rd party manufacturers. The only way to get PPM on the internal connector on versions 3.xx is to fool the Evo by replying to the boot time module polling and telling it you're a 35MHz synth module or similar. Then it will provide PPM.
PPM remains available on the DIN connector if pins 3&5 (from memory - check!) are linked as used on sims etc.
Steve
GlowFly is offline Find More Posts by GlowFly
Old Dec 26, 2011, 02:31 AM
Bevcan is offline
Find More Posts by Bevcan
Joined Nov 2006
Almost there i think.
http://shop.lindinger.at/product_inf...ducts_id=93120
http://shop.lindinger.at/product_inf...ducts_id=93122
Bevcan is offline Find More Posts by Bevcan
Old Dec 26, 2011, 02:57 AM
Kambalunga is online now
Find More Posts by Kambalunga
Kambalunga's Avatar
Deutschland, Hessen, LA
Joined Jan 2009
He has a Multiplex TX and need therefore no FASST telemetry.
What he need is Multiplex Royal EVO w/ Spektrum Module
http://www.rcgroups.com/forums/showthread.php?t=682256
Kambalunga is online now Find More Posts by Kambalunga
Discussion Multiplex Royal EVO w/ Spektrum Module kasra Radios 1436 Jun 19, 2015 07:17 AM
Sold Multiplex Royal Evo Pro 12 + XPS + extras CiprianGugu Aircraft - General - Radio Equipment (FS/W) 5 Mar 23, 2011 01:22 PM
Question Spektrum Futaba MZ DM9 module -> JR XP9303 module conversion salat Radios 6 Aug 01, 2009 04:29 PM
Sold Multiplex Royal Evo 12 w/spektrum module, FM scanner module, and PC cable renelu Aircraft - General - Radio Equipment (FS/W) 7 May 21, 2009 07:36 AM
Discussion Spektrum Module Conversion on Futaba 9C phyxer Radios 11 May 11, 2009 06:17 PM
