Old May 20, 2011, 09:07 PM
nvmike is offline
Find More Posts by nvmike
Joined Nov 2009
My $10 Harbor Freight kite flight video
This project started with a $10 two line stunt kite (65 in. WS) from Harbor Freight, a $1 light weight 24 in. level from a Dollar store, 28 34 brushless motor (from headsuprc) about $20 and a 10x8 slow fly prop. I started with a rudder and elevator but no longer use an elevator, it is just as easy to control pitch with motor speed (the small elevator is not effective with such a large surface area, the down side is it will not loop without the elevator).
My lastest version was to move the motor up on the post, after moving the motor I have not broke a prop.
I am also flying a home made Rogallo wing on the same frame.
CERF-VOLANT RC.KITE (2 min 5 sec)
nvmike is offline Find More Posts by nvmike
Old May 21, 2011, 10:14 PM
inventing_man is offline
Find More Posts by inventing_man
Whats a search engine?
inventing_man's Avatar
Missouri
Joined Jun 2006
Cant Beat it with a stick ..errr I mean ,, level
Nice flyer for sure .
inventing_man is offline Find More Posts by inventing_man
Old May 22, 2011, 08:07 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
impressive
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old May 22, 2011, 10:06 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
very cool and cheap!
rcrich is offline Find More Posts by rcrich
Old May 23, 2011, 03:21 AM
johnvb is offline
Find More Posts by johnvb
Canberra, Australia
Joined Nov 2002
Terrific! Flies great!
johnvb is offline Find More Posts by johnvb
Old May 28, 2011, 07:46 PM
IFLYOS is offline
Find More Posts by IFLYOS
14s 180mah should be enough...
IFLYOS's Avatar
United States, NC, Pfafftown
Joined Feb 2001
LOVE IT...Gotta go shopping now!!
How about a little more info...whats the angle of incidence of the kite? Where did the CG work out to be?
Tim
AG4RZ
IFLYOS is offline Find More Posts by IFLYOS
Latest blog entry: Intro..a few years to late!
Old May 29, 2011, 12:02 AM
nvmike is offline
Joined Nov 2009
Details on my rc stunt kite
Fuselage is a dollar store 24 inch level, 2 oz. Motor is 2834-9 2.6 oz, 900Kv.
30 amp ESC, 1800 mAh lipo, I have used 10x8 and 11x5.5 props. pylon is 17.5 in tall and 7.75 in. back from front of the level, motor is mounted as tractor 6 in. up on the post. The post is 1.5 x 1/4 in. wood. Angle of incidence is 10 degrees. Vertical stab. is 7 in. high by 5 in. including the 2 in. rudder. Horizontal is 9 x 5 with 2 in. elevator (at present I am not using the elevator). Both vert. and horizontal are made of coroplast. The COG is 15 in. back from the tip of the kite and located on the center of the verical post. The front of the battery is 10 in. back from the front of the level. I have light wires from midway down the outer kite rods to the fuselage, I adjust the length of these wires as needed for trim. I also add a wire to the rear tip of the kite to the top of the vert. stab. Ready to fly weight is 28 oz.
I am now using a Rogallo wing ( homemade) and it seems to fly better than the stunt kite, center beam is 36 in. outer rods are 42 in., 56 in. wide at the back. If you have questions, I will try to answer them.
Old Jul 18, 2011, 03:56 PM
Eddie P is online now
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Hey, that's pretty cool! I had to laugh at the dollar store "level" fuselage. Pretty well thinking outside the box on that one Looks like it flies great.
Eddie P is online now Find More Posts by Eddie P
Discussion Harbor Freight EPO Foam 4 channel P-51 Mustang...RTF $79.99..Flight report and Video modfly Electric Warbirds 1342 Jan 06, 2016 09:28 AM
Build Log Harbor Freight Biplane v3 build Rex A Lott Scratchbuilt Indoor and Micro Models 19 Oct 04, 2011 02:05 AM
Sold Harbor Freight Wild Hawk Captain Ron Aircraft - Electric - Airplanes (FS/W) 0 Apr 24, 2011 07:19 PM
Discussion Ultralite, Harbor freight Kite UFly Foamies (Scratchbuilt) 308 Mar 01, 2011 10:19 PM
Discussion Harbor Freight box Kite UFly Foamies (Scratchbuilt) 2 Apr 20, 2008 02:11 AM
