Old May 20, 2011, 12:33 PM
RichardM is offline
Find More Posts by RichardM
United States, GA, Atlanta
Joined Apr 2011
e-flight blade 120 SR short flight time
My blade 120 SR will fly for about 2 minutes and then act like the battery is dead. It will then fly for another few minutes and repeat the process. It is not that old and tech support seems to think that it is a motor going out and the only thing to do is wait to a failure of that offending component.
Has anyone else experienced this?
RichardM is offline Find More Posts by RichardM
Old May 20, 2011, 01:59 PM
arbilab is offline
Find More Posts by arbilab
Fly Runaway Fans
United States, TX, Fort Worth
Joined Jan 2009
Stick your finger on the motor after it has run. After 2 minutes it should be barely warm. If it's HOT it is failing. Not a common early failure on 120SR. Main motors typically run ~a year before that happens.
Not all the phone answerers are equally knowledgeable on a specific model, Horizon sells so many. Short flight is characteristic of the 120 battery. When it becomes balky, the light is flashing, right? Then it rests a little and does it again?
They should be sending you a replacement battery. They did me. Though under the strictest interpretation of warranty it's not covered, Horizon leans more toward customer satisfaction than toward stinginess.
If not, don't buy theirs, you'll get another of much the same and they're overpriced. See the model thread under 'micro', there is an aftermarket batt that fits if you peel some of the tape off.
Support the battery holder when installing/removing, it tends to break easily.
arbilab is offline Find More Posts by arbilab
Old May 20, 2011, 06:18 PM
micronut is offline
Find More Posts by micronut
dont play with rc anymore
micronut's Avatar
United States, MO, St Joseph
Joined Feb 2005
http://www.rcgroups.com/micro-helis-42/
micronut is offline Find More Posts by micronut
Old May 24, 2011, 11:41 PM
RichardM is offline
Joined Apr 2011
I thought it was the connecting wire to the tail motor as it was partially broken, but after a new tail boom and motor I find it doing the same thing with both of the batteries I purchase. The tail motor is slightly warm and the main motor is cool. Maybe I will buy another brand of battery and see how that responds.
Old May 24, 2011, 11:47 PM
arbilab is offline
Fly Runaway Fans
Joined Jan 2009
I have 2 stock batts one runs 3min+ and the other runs 5min+ and I treated them the same so there is variability in the stock batt. The aftermarket batt is 'Tiger'.
Old May 25, 2011, 12:22 AM
micronut is offline
micronut's Avatar
Joined Feb 2005
I have five eflite batteries for my 120sr. One runs for about 90 seconds and gets real hot. The other four are all over the board, ranging from 2 minutes to 5+ minutes. I would definitely suspect the battery.
Old May 25, 2011, 01:36 PM
RichardM is offline
Joined Apr 2011
i have Tenergy 1S 3.7V 500mAh LiPo Battery coming from ebay so i am anxious to see if that takes care of it. if so those stock eflite batteries really are junk.
Old May 25, 2011, 04:39 PM
arbilab is offline
Fly Runaway Fans
Joined Jan 2009
Like Eflite thought we weren't going to find out? Mine are 'adequate' and one is even 'good' but I won't be buying Eflite batteries.
Old May 26, 2011, 07:51 PM
Chrisfly is offline
Find More Posts by Chrisfly
Go play before it is too late!
Chrisfly's Avatar
Newmarket Canada
Joined Dec 2008
MMM - I guess I must be lucky - I have 2 Eflites and get 6 mins on all of them. I use a timer vs. cut out. Mind you I do charge them on my "real charger" vs. the one that came with it and I am not flying very aggressively.
Chris
Chrisfly is offline Find More Posts by Chrisfly
Question Blade 120 SR Flight control questions?? james1300 Beginner Training Area (Heli-Electric) 28 May 31, 2011 03:48 PM
For Sale e-flight blade 120 sr controller $20 bordhead Aircraft - Electric - Helis (FS/W) 0 Apr 23, 2011 02:14 PM
Discussion E-flight Blade 120 SR Mods IndyThreeWheel Micro Helis 1 Mar 20, 2011 05:57 PM
Yippee! Blade 120 SR maiden flight anxiousflyer Electric Heli Talk 1 Mar 12, 2011 03:01 PM
Discussion blade sr 120 FLIGHT ISSUE ? zippyshutt Mini Helis 3 Mar 06, 2011 05:46 PM
