This thread is privately moderated by ChrisBowker, who may elect to delete unwanted replies.
Old May 19, 2011, 09:43 AM
ChrisBowker is offline
Find More Posts by ChrisBowker
RC Bum 4 Hire
ChrisBowker's Avatar
United States, NM, Albuquerque
Joined May 2004
Build Log
Dark Side Models EPP Yak 55
Its time to start a build log on my new EPP Yak 55. This yak is designed to be an intermediate model. The Yak has great flight performance and feels much like a 3mm depron model on the sticks. The Yak is a great model for anyone looking to improve their own flying. Its the perfect model for people looking to break into the "low and slow" category of 3D.
A quick look:
Model:Yak 55
Wing Span: 31"
Weight:6-8oz
motor:1700kv 2 cell outrunner
ESC:9 amp
Battery:350-450mah
Servo(s)6g
My setup
Motor:Hacker a-109L
ESC:thunderbird9
Servo(s):hs-65(ail) hs-45 elev/rudd
battery:nanotech 350mah 2s
I get between 4-6 min flight times swinging a 8x4.3 on this plane.
Unpainted "short kits"(Foam parts only) start at just $25(ALL KITS COME PRE BEVELED & WELDERS GLUE HINGED)
Full kits are Discontinued, full kits include all carbon fiber necessary to build the model, CF aileron diff horn(with Du-Bro ez links), wheels, motor mount, control horns, music wire(for z bends), heat shrink, push rod guides. pretty much everything you need minus glue/radio gear.
The following will be a build log to help out with the construction of your EPP Yak. Before you start building you will need a nice flat table to work on, with out a flat surface to build your model on it will never come out straight. Also remember to take your time building the model, check your work with a square and leave the hack and dash attitude for chopping fire wood.
Glue suggestions: I use Bob Smith regular CA thick&thin to build my model. I only use the thin CA once the model is up off of my building table, EPP acts like a sponge and I have glued many of them to my work bench with thin.
CG location is aproz 1/2" behind the spar
For control throw I run aprox 45 degrees on everything with 80% expo on my epp planes(90-95 on my depron models)
Chris
Still more to come...
Chris Must Be Bored (0 min 41 sec)
http://www.youtube.com/user/sr71afan#p/u/7/xDooKcl1JLE
ChrisBowker is offline Find More Posts by ChrisBowker
Old May 26, 2011, 12:01 PM
ottpilot is offline
Find More Posts by ottpilot
Joined May 2011
looking to buy epp yak 55 kit
terry
ottpilot is offline Find More Posts by ottpilot
Old May 26, 2011, 03:20 PM
RC Bum 4 Hire
Joined May 2004
Hey Terry,
I sent you a PM. For those of you looking to get a kit off me please send me a PM and we can work out the details. I plan on getting my website up in a few weeks but have just not had the time yet.
Chris
Discussion 42" EPP Yak-55 and Yak-54 motorhead 3D Foamies 730 Apr 14, 2016 10:10 AM
Sold Brand New 19" EPP Brushless Yak (UMX Beast Guts) tonebone Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Mar 20, 2011 11:14 AM
Discussion 'Good' Jobs Report Has Dark Side Arbo Life, The Universe, and Politics 2 Mar 05, 2011 02:45 PM
Discussion helifrek has crossed into the dark side, well mini side.... helifrek Mini Helis 24 Apr 08, 2008 04:25 PM
