Old May 19, 2011, 07:51 AM
xkubr is offline
Find More Posts by xkubr
Joined Oct 2006
Question
How to connect motor, ESC, battery and receiver?
I am new to electric RC and building a Brio 10. I have a Park 480 motor, brushless ESC, 3S 11.1v LiPo battery and a JR crystalless receiver. I need some advice on how to connect these all up.
If I need to post more details on the parts, etc. just ask.
xkubr is offline Find More Posts by xkubr
Old May 19, 2011, 08:57 AM
xkubr is offline
Joined Oct 2006
I found the "How do I connect Motor, ESC, RX & Battery???" post: http://www.rcgroups.com/forums/showthread.php?t=953918 - this seems to give the info I need.
But I just want to dbl check one thing: Does the ESC connect to the RX throttle slot? What, if anything connects to the RX battery slot?
Old May 19, 2011, 09:11 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
If you look at the wires on the ESC, it only goes together one way.
Also, the ESC is usually marked as to where each wire set goes.
aeajr is offline Find More Posts by aeajr
Old May 19, 2011, 09:24 AM
jkettu is online now
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
When using Esc, nothing is connected to the Rx battery slot. Esc will feed the Rx through the throttle slot.
The battery slot is used to connect an external radio battery in a pure glider or when using a piston engine (no esc/bec available).
jkettu is online now Find More Posts by jkettu
Old May 19, 2011, 10:11 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
A picture is worth.....more than my explanation anytime
Just one thing to watch for, check if the Rx has the +, -, and ~, marked on it, as many servos and ESC connectors can be plugged in either way round.
Getting it wrong wont damage anything though, it just wont work.
eflightray is offline Find More Posts by eflightray
Old May 20, 2011, 01:48 AM
xkubr is offline
Joined Oct 2006
Thank you for the replies & pic.
Another noob question: Can\should I connect a battery to the battery slot AND the ESC\LiPo to the throttle? Would this act as a backup for the servos & RX or run the servos & RX off the battery slot and the motor off the LiPo\throttle slot?
Old May 20, 2011, 11:01 AM
Gary Hoorn is offline
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
NO! You should go back and start reading some of the threads for new electric flyers before you ruin something...
Gary
Gary Hoorn is offline Find More Posts by Gary Hoorn
Old May 20, 2011, 11:27 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Read post 4 and 5 again.
Still confused?
EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT
http://www.wattflyer.com/forums/showthread.php?t=31368
Read Chapter 5 and 23
Table of contents
1 ............Preface
2 ............Amps vs Volts vs C
3 ............Sizing Power Systems
4.............Props vs. Amps
5 ............What is an Electronic Speed Control
6 ............The LVC, Low Voltage Cut-off
7 ............Who Needs a Wattmeter?
8 ............Why Use a Gearbox?
9 ............Extended Flight Times and Balance
10 ...........Battery Basics
11 ...........Lithium Batteries, Chargers and Balancers
12 ...........Six Keys to Success for New Pilots
13 ...........Things to Check on an RTF
14 ...........Now its Your Turn!
23 ...........The Role of the BEC in your ESC
24 ...........The Mythical Best First Plane
33 ...........What You Need to Know About Receivers
43 ...........WHAT DO THE KV RATINGS ON MOTORS MEAN?
51 ...........A DOWNLOADABLE EDITED VERSION OF THIS E-BOOK (editing by Ken Meyers)
71 ...........Estimating Battery Run Time
Discussion How to buy a ESC, Motor, Battery?? devansh Batteries and Chargers 5 May 14, 2011 07:38 AM
Help! How to connect microcontroller to ESC and program ESC? chen5798 DIY Electronics 6 Mar 29, 2011 08:06 AM
Discussion How do I connect Motor, ESC, RX & Battery??? jzcode49 Beginner Training Area (Aircraft-Electric) 14 Nov 15, 2008 12:31 PM
Discussion berg 4 receiver -- how to connect battery? slotstik Radios 3 Aug 13, 2006 09:05 PM
