Old May 19, 2011, 04:11 AM
Mayer74 is offline
Find More Posts by Mayer74
Italy Roma
Joined Apr 2010
Alert
HobbyKing BuddyPrice Codes for Propellers and Motors
hi people a little thing or see if you need something
5X3 Propellers (5Pcs/Bag)
http://www.hobbyking.com/buddy.asp?c...7-9DAC7AA3E02F
5x3R Propellers (Counter Rotating) (5Pcs/Bag)
http://www.hobbyking.com/buddy.asp?c...9-B28F42E04E04
9x5 Propellers (Standard and Counter Rotating)
http://www.hobbyking.com/buddy.asp?c...7-6BEEA486A1C8
8X4R Propellers (Standard and Counter Rotating)
http://www.hobbyking.com/buddy.asp?c...6-FAEFE0367E24
SF E-Prop 10x4.7 / 254x119.5mm w/ Adapters B
http://www.hobbyking.com/buddy.asp?c...A-60A91A78432F
KD A22-15M Brushless Outrunner Motor
http://www.hobbyking.com/buddy.asp?c...3-E4BD66140CE0
KD Replacement Shaft Kit 22-__M
http://www.hobbyking.com/buddy.asp?c...5-DCF5298FBE89
KDA A22-**M motor accessory Pack
http://www.hobbyking.com/buddy.asp?c...B-47B1F248B039
Flat 26AWG servo wire 1mtr (R/O/B)
http://www.hobbyking.com/buddy.asp?c...A-8BEF820E2D91
C-Clip Ring Plier 4 in 1 set
http://www.hobbyking.com/buddy.asp?c...3-86E4D4E1DBBA
Peel-n-stick foam tape. 10x5inch 4mm thick
http://www.hobbyking.com/buddy.asp?c...7-61B02CCD538A
Turnigy Battery Strap 330mm
http://www.hobbyking.com/buddy.asp?c...1-459BBCBA9DB9
Mayer74 is offline Find More Posts by Mayer74
Alert HobbyKing BuddyPrice Codes for more products, use as you wish obuggy HobbyKing 7946 Jul 21, 2016 10:53 PM
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Discussion !NEWBIE! I need help picking out the proper motors and propellers! Sparky701 Multirotor Talk 18 Apr 27, 2011 05:02 PM
Question Anyone interested? Hobbyking EPP-FPV Plane and motor discount codes Gree FPV Aircraft 0 Apr 22, 2011 08:54 PM
