Old May 19, 2011, 01:46 AM
hcsk8ter is offline
Find More Posts by hcsk8ter
hcsk8ter's Avatar
United States, NY, Jericho
Joined Jun 2008
Help!
Nicads and Storage ...
Hi,
Took my nicads out the other day (for my nitro planes' receivers) and I charged them on the trickle charge overnight.
They are 4 cell nicads and they charged to about 5.32v total.
I read somewhere a fully charged nicad should charge to around 6v??
So are my nicads ok to use?
Also how do you charge your nicads/nimhs to reach their full potential and maximum longevity?
Thanks.
hcsk8ter is offline Find More Posts by hcsk8ter
Old May 19, 2011, 04:14 AM
typeRA is offline
Find More Posts by typeRA
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
Trickle charging is used to maintain fully charged cells at full charge. It isn't to charge a drained cell.
Your battery should be charged at a rate of C/10 for about 16 hours.
For example, if your cells are 800mAh:
Code:
800  10 = 80
That would mean that the charge rate should be 80mA.
typeRA is offline Find More Posts by typeRA
Old May 19, 2011, 05:38 AM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Yes, NiCads can be in excess of 1.5v per cell when fully charged, so you should be seeing something higher than 5.32v.
As typeRA has suggested, your charge was maybe not enough mA and duration to get the pack fully charged.
How long were the packs in "storage", and do you know what voltage they were before you started the charge? Personally, I would cycle them a couple of times and see if the same mAh goes in each time.
I don't know what the definitive answer is about ensuring a long life, but I believe that slow charge rate (1/10C) helps. I then judge whether a pack needs binning by seeing how many mAh it takes after it's been used the previous week and then sat on the shelf for a week. No hard numbers, but simply a comparison with what it "normally" takes -- if it suddenly takes more than "normal", it's binned. Operating that way, my receiver and transmitter packs last several years.
abenn is online now Find More Posts by abenn
Old May 19, 2011, 12:50 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
Trickle charge, by definition, is just enough to overcome the self discharge rate of the battery so will never charge a discharged cell. What you may mean, if you were using a wall wart that usually comes with a system, is you were slow charging. This is typically at 0.1C and to fully charge (an insure balanced cells) is to charge at 0.1C for 15 to 16 hours, longer won't hurt. Your fully charged 4 cell unit could read as high as 6 volts, at least 5.8 volts fresh off a 16 hour slow charge.
Rodney is offline Find More Posts by Rodney
Old May 19, 2011, 01:14 PM
Mugwa is offline
Find More Posts by Mugwa
Mugwa's Avatar
NW Chicago Burbs
Joined Oct 2003
A fully charged NiCd will only reach 1.35 volts per cell. If you want to bring a NiCd pack back to life you will have to discharge then recharge (cycle) the pack 3-4 times. Discharge down to .9 volts per cell, then recharge the pack at 1 amp using a peak Delta type charger like the Triton, iCharger, etc. NiCd and NIMh packs have to be worked vigorously to get the best performance out of them. Cycling a pack using the above parameters once every 6 months will keep the pack in top condition.
Mugwa is offline Find More Posts by Mugwa
Old May 19, 2011, 02:00 PM
write2dgray is offline
Find More Posts by write2dgray
write2dgray's Avatar
United States, NJ, Princeton
Joined Dec 2006
Good advice here.
As a side note I've found this special treatment is not often required on the newer low self-discharge (LSD) NiMh cells and I'm slowly phasing out all my older ones for this much more predictable type. They seem to have less memory effect (behave more like lipos) and still have near full capacity after a month on the shelf.
- David
write2dgray is offline Find More Posts by write2dgray
Site Sponsor
Old May 19, 2011, 02:34 PM
abenn is online now
Joined Jul 2004
Originally Posted by Mugwa View Post
A fully charged NiCd will only reach 1.35 volts per cell. ...
I don't have any NiCd transmitter or receiver packs any more (all NiMh now), but the two larger NiCd packs I have (7-cell 2000mAh) both normally peak at around 11.6 - 11.7 volts, which is 1.66 - 1.67v per cell.
Old May 19, 2011, 03:23 PM
Wayne Giles is offline
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
The reason for the difference is that the 1.35V/cell is the fully charged settled voltage ie the voltage the fully charged cell will settle at some time after charging so that 1.55V/cell is the fully charged voltage on charge 1.66V/cell sounds a bit high - could well be a diode in series with the pack accounting for the extra.
Nicads will always benefit from cycling if they have been left unused, but generally they are not damaged by discharged storage. Really good ones will last years. I have a Sanyo Rx pack which I had not touched for 14 years and it still had significant energy left in it. A few cycles brought it back to practical use.
BTW it is (or was) and industry standard to assume that a nicad cell was at the end of its life when its capacity has fallen to 80% of rated value.
Wayne
Wayne Giles is offline Find More Posts by Wayne Giles
Old May 19, 2011, 03:40 PM
hcsk8ter is offline
hcsk8ter's Avatar
Joined Jun 2008
How would I go about getting the Nicad down to .9 volts per cell? By flying the plane? And doing this 3-4 times? confused.
What I meant by trickle charge is the wall wart charger, yes.
Old May 19, 2011, 04:09 PM
RedStarArmy is offline
Find More Posts by RedStarArmy
RedStarArmy's Avatar
United States, NJ, Middlesex
Joined Feb 2008
NOO!! You never want to fly a pack that is 4.8volts or lower (for 4 cell packs). You need a charger that can cycle packs (ie, any modern 'smart charger').
RedStarArmy is offline Find More Posts by RedStarArmy
Old May 19, 2011, 07:48 PM
hcsk8ter is offline
hcsk8ter's Avatar
Joined Jun 2008
I have a few parkzone nimh chargers, cellpro 4s revolution (believe it's just for lipos), imax b5 (not sure it can cycle but it can charge micads) and that's about it.
There isnt any way I can cycle without a charger?
If not what's the most cost effective charger for the money for nicad/nimh cycling and lipos? thanks!
Old May 20, 2011, 03:47 PM
Mugwa is offline
Mugwa's Avatar
NW Chicago Burbs
Joined Oct 2003
You'll have to study up on how to cycle battery packs, or get together with someone in your area who knows how. I mentioned the Triton & iCharger because I use them and they have the ability to cycle NiCd/Mh packs. For example when you cycle any Nickel pack on the Triton it automatically sets the cutoff voltage per cell for both NiCd/Mh batteries at 0.9 volts/cell, so you don't have to manually set it. When you cycle Nickel packs on the iCharger it also automatically sets the cutoff voltage per cell, it uses slightly different values for NiCd/Mh packs. Pretty much all of the new inexpensive chargers by Turnigy, Hobby King, etc have functions to cycle Nickel packs.
Old May 21, 2011, 10:03 AM
Rodney is offline
Florida
Joined Aug 2004
You do not need a special charger to discharge your packs but it sure makes the job easier. You can put any reasonable load on your battery by just connecting is between the terminals and then monitor the cell voltages with a VOM (volt-ohm-meter) and, when the voltage across the cells fall to the desired value, disconnect the load. If you are comparing it to factory specifications, the load is generally sized to draw a current of 1/3C and you discharge down to 0.9 volts/cell.
When using your Nixx batteries, it is perfectly safe to use them down to 1.1 volt/cell or 4.4 volts for a 4 cell battery. If you stop at 4.8 volts, you probably have at least 40% of the usable energy still available. You can prove this to yourself by putting a reasonable load on the battery and then measuring the time it takes for the battery voltage to fall from 4.8 volts to 4.4 volts. You will find this is quite a high percentage of the total time it takes to fall from a full charge down to 4.4 volts.
For Sale Anyone still need a project Storage Unit Sale NW Indiana stevesomuchstuff Non R/C Items (FS/W) 21 Oct 26, 2015 09:27 PM
Discussion How low can Nicads be discharged? John Webb Batteries and Chargers 4 Apr 18, 2011 02:50 PM
Question first use after longer storage any things i should keep in mind? cmulder Batteries and Chargers 9 Mar 15, 2011 04:01 PM
Question First engine test after storage Saito FA-82 buechelr Fuel Plane Talk 4 Mar 12, 2011 08:33 PM
