Old Feb 17, 2013, 09:04 PM
Opt
New Zealand, Auckland
Joined Oct 2010
I'm using the bare module rather than a rtf transmitter with built in voltage reg etc.
should otherwise be the same thing though
Just checked on google maps and the range is more like 350-450m :/
Opt is offline Find More Posts by Opt
Old Feb 17, 2013, 09:16 PM
United States, AZ, Tucson
Joined Mar 2008
Originally Posted by deleted View Post
Hi Guys,
I bought the 5.8ghz 200mw system for my quad about a month or two ago as my introduction to FPV. I am using these spironet antennas from HK.
I don't seem to be getting anyway near the range I expected (1km). At the most in a clear LOS area like the beach I get around 150 - 200meters before the signal starts to degrade. I get the same range if I fly at a sports field as well. From what I have read I should have been able to get at least a few hundred meters with the stock antennas and around 1km with the spironets.
Are the HK spironet antennas no good or is there something else I am missing?
Thanks in advance.
I have the same setup as you RC305 and 200mw with sproNet form Hobby King and I thought I'd get more range. The farthest I got was 3,000ft. I have my antenna mounted on the end of an arm on my quad.
I ordered a Dragon Link and I also want more video range so I'm going to order a 1.3 400mw system.
jasper7821 is offline Find More Posts by jasper7821
Old Feb 17, 2013, 09:27 PM
deleted's Avatar
Central Coast, NSW, Australia
Joined Apr 2007
I would be happy with that range as that is all I am aiming for for the moment!
Could you please post a pic of your setup on your quad? Maybe placement of the vtx and rx is key?
Can any of the gurus advise why the range would be so different and any help for me to get a bit further out that 200 meters?
deleted is offline Find More Posts by deleted
Old Feb 17, 2013, 09:32 PM
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, BC, Summerland
Joined Nov 2012
Hi Guys,
Thanks in advance.
i'm willing to bet anything that it's the positioning of your antenna on your rig, when i first tried mine (200mW 5.8) w/blue beam antennas (more or less the same as your spironets) i got maybe 100m before i started losing signal. After I installed legs on it and let the antenna hang down way below the rig i was getting 1km
CrashAffinity is offline Find More Posts by CrashAffinity
Latest blog entry: DJI F550 build w/naza
Old Feb 17, 2013, 09:35 PM
deleted's Avatar
Joined Apr 2007
So to clarify you mounted your antenna upside down on your quad ie. below your quad? Does placement near other electronics on the quad matter as well?
Old Feb 17, 2013, 09:37 PM
Joined Nov 2012
it does help if your tx is further away from your electronics, and yes my antenna is pointing straight down at the moment. the bulb i guess you could say is about 6" from the bottom plate of the hex, so no matter how much i tilt in any direction i always get clear LOS to home.
having said that, i just finished my 900mhz tests today on my hex (i have both 5.8 and 900 mounted on it) and i was able to tx video through a lot of trees with the 900, so the 5.8 is likely going to be removed
luckily i have good size clearance legs, the 900mhz cloverleaf is BIG
Old Feb 17, 2013, 09:40 PM
deleted's Avatar
Joined Apr 2007
Thanks for your input - I will try this placement although I don't have a lot of clearance below.
Old Feb 17, 2013, 09:43 PM
Joined Mar 2008
Here's a few photos.
I had it mounted upside down on the arm. I tried to get more range and I moved it to the rear on a piece of brass plate so the antenna was several inches in the air. That way made it worse and I only got about 500ft or so if I remember correctly.
So I moved it back onto the end of the arm and the farthest i can get is 3,000ft and that's with the RX on a pole about 8ft above the ground.
With the TX sitting on top of my monitor that's on my tripod I only get about 800ft or so.
Old Feb 17, 2013, 09:44 PM
Joined Mar 2008
I also had it mounted here and got terrible range.
Old Feb 17, 2013, 09:50 PM
deleted's Avatar
Joined Apr 2007
Thanks for the pics - that really helps. I was thinking of moving to the position you have in your last picture (right at the back) but won't bother given you have had no luck.
I will try upside down at the end of one of the arm.
Thanks again.
Old Feb 18, 2013, 12:26 AM
FPV addicted
futurebreeze's Avatar
Romania, Bucharest
Joined Jul 2010
Also check the channel selection DIP switches on both vTX and RX. Their wrong position is often the cause for short range. For channel 1 they must be all 4 to the ON position ( the manual has some mistakes about this). You can check very quickly if the position causes the short range by flipping all 4 mini knobs (from either vTX or RX) to the opposite direction (right now you might be on channel 8)
futurebreeze is offline Find More Posts by futurebreeze
Old Feb 18, 2013, 03:13 AM
deleted's Avatar
Joined Apr 2007
Thanks but I am already on Channel 1. Might try channel 3 if the vtx placement change yields no joy.
Old Feb 22, 2013, 09:21 AM
Living in the south of France
paulinfrance's Avatar
Joined Aug 2011
I'm getting 600 meters at home( 800+ on the model field) and now that i have put table tennis balls on the aerials to protect them i only get 500 meters, this is with 'terry build' 4 lobes or my home built 3 lobes, there's no difference.
paulinfrance is offline Find More Posts by paulinfrance
Old Feb 22, 2013, 10:24 AM
Romania, Dolj, Craiova
Joined Sep 2007
table tennis balls = white plastic, i.e. 99% chances to be white due to titanium oxide, the most used white pigment in industry.
titanium oxide = conductor, thus absorbing microwaves, proof this by placing a ball in mw oven, if warm then I am right.
renatoa is offline Find More Posts by renatoa
Latest blog entry: JRSky - birth of a dream radio
Old Feb 22, 2013, 10:41 AM
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
hi,
use a separable acryl-ball ... no dampening! like this http://www.ebay.de/itm/Acrylkugel-Ku...item92b23776bf
cu Thomas
Thint1 is offline Find More Posts by Thint1
Cool Hobbyking has cheap 5.8ghz 200mW sets. SargeNZ Video Piloting (FPV/RPV) 7 Mar 06, 2012 09:32 AM
Discussion 5.8ghz 200mw on Blade 120 SR - pics Vitamin_J Video Piloting (FPV/RPV) 2 Mar 27, 2011 10:25 AM
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari Video Piloting (FPV/RPV) 6 Mar 26, 2011 02:25 PM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV/RPV - Equipment and Vehicles (FS/W) 1 Mar 22, 2011 08:01 PM
Sold 5.8GHz / 200mW Video Tx and Rx. New. Mr.RC-CAM FPV/RPV - Equipment and Vehicles (FS/W) 1 Nov 02, 2010 09:07 PM
