Espritmodel.com Heli Air
Old Jan 06, 2013, 12:13 PM
Romania, Dolj, Craiova
Joined Sep 2007
Should not matter, because VTx internally reduce the voltage down to 3.6V, this is the operational voltage of the core VTx. There are reports working fine even from 5V.
If that 7.x Volts power also the camera, then this is the weak link, not VTx.
renatoa is offline Find More Posts by renatoa
Latest blog entry: JRSky - birth of a dream radio
Old Jan 06, 2013, 12:40 PM
FPV addicted
futurebreeze's Avatar
Romania, Bucharest
Joined Jul 2010
Originally Posted by ridgewalker View Post
Talking about the full size 200mw vtx and 305 vrx...
Found this video on yt and at around 7.9v you can see the picture degradation.
It is the camera that can't handle low voltage. Pixim Seawolf handles a little better the low voltage, it works flawlessly down to 7V.
futurebreeze is offline Find More Posts by futurebreeze
Old Jan 06, 2013, 12:57 PM
The lunatic is on the grass
ridgewalker's Avatar
Joined Aug 2008
My camera is a RMRC 420xv and operates fine at 5v,never tried it at lower voltage.
This camera can handle lower voltage than the one in the video so i'm alright powering the vtx (which is powering the camera) on a 1300mah 2s.
And since the vtx reduces the incoming voltage anyways then using a 3s would just result in more voltage being wasted as heat,with nothing more to gain,does that sound correct?
ridgewalker is offline Find More Posts by ridgewalker
Old Jan 06, 2013, 01:02 PM
Joined Sep 2007
No heat, the VTx regulator is switching.
Old Jan 06, 2013, 01:13 PM
Joined Aug 2008
Didn't know that the vtx regulator is a switching one,thanks for pointing that out.
So then,using a 3s for powering the vtx is ok ?
Old Jan 06, 2013, 02:39 PM
FPV addicted
Romania, Bucharest
Joined Jul 2010
Go with 3S, it will be OK. People that use 2S may need less voltage for OSD's like Remzibi. I did the same thing to avoid the dissipated heat of the linear regulator.
Old Jan 06, 2013, 04:27 PM
Joined Aug 2008
Next time out will use 3s on the vtx.
Have made several flights and only used 2s on the vtx and started getting some static at 850m,antennas Bluebeam cl and a home built spw.
Will see if the 3s makes a difference next time out.
Good to know the 3s is ok and can use a 2s as back up.
Thank you for the help.
Old Jan 07, 2013, 12:43 AM
FPV addicted
Romania, Bucharest
Joined Jul 2010
It is normal to get static at 850m in certain positions. I'm very sure you won't notice any difference between 3S or 2S. There is a difference though: at the same capacity the 2S is lighter than 3S . On the other hand, going on 3S gives you the possibility to power video from the engine battery so no supplementary weight at all.
Old Jan 13, 2013, 03:31 AM
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
I have been using the 3.3v Type A 5.8ghz module from Rangevideo with success and now they sell one the same but 5v. I need to but a couple more now.
I guess the 5V will be more versatile and can be used on a 1cell LiPo.
Anyone had any problems with the 5v version?
Here are the two they sell 3.3v and 5v.
3.3v
http://www.rangevideo.com/index.php?...roducts_id=217
5v
http://www.rangevideo.com/index.php?...roducts_id=304
Firepower is offline Find More Posts by Firepower
Old Jan 13, 2013, 04:17 AM
Joined Sep 2007
Even 3.3V version can be used with 1s Lipo, is how I use mine for years.
Old Jan 13, 2013, 05:00 AM
Expert Crasher
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Nov 2011
same here i use mine 5.8 got from Foxtech with 1s lipo no problem at all
skellator is online now Find More Posts by skellator
Old Jan 13, 2013, 06:11 AM
Firepower
Firepower's Avatar
Joined Mar 2010
Thanks renatoa & skellator just was not brave enough to use the on a 1S LiPo on the 3.3v module but from what you say no problems.
Just been attaching the modules to some vero board with double sided tape and soldering an antenna connector to the vero board with wires to the TX to use a SPW. Simple and works great.
So there does not seem to be any problem with the 5v ones and the 5v can be taken from the receiver if BEC/UBEC has enough power.
Old Feb 17, 2013, 05:59 PM
deleted's Avatar
Central Coast, NSW, Australia
Joined Apr 2007
Hi Guys,
I bought the 5.8ghz 200mw system for my quad about a month or two ago as my introduction to FPV. I am using these spironet antennas from HK.
I don't seem to be getting anyway near the range I expected (1km). At the most in a clear LOS area like the beach I get around 150 - 200meters before the signal starts to degrade. I get the same range if I fly at a sports field as well. From what I have read I should have been able to get at least a few hundred meters with the stock antennas and around 1km with the spironets.
Are the HK spironet antennas no good or is there something else I am missing?
Thanks in advance.
deleted is offline Find More Posts by deleted
Old Feb 17, 2013, 07:07 PM
Opt
New Zealand, Auckland
Joined Oct 2010
Originally Posted by deleted View Post
Hi Guys,
Thanks in advance.
Not sure but same thing happens to me. I get about 5-600m max with 200mW and spironets. Although I am running about 3.7V to the 3.3V vtx to get a bit more power from it.
Opt is offline Find More Posts by Opt
Old Feb 17, 2013, 07:14 PM
deleted's Avatar
Joined Apr 2007
Sounds like your still getting 3 times the distance I do!
I run the vtx of a 3s 500mah pack s0 12 volts. I didn't realise they could run on as little as 3.7v...I thought it was 7v to 12v input?
Cool Hobbyking has cheap 5.8ghz 200mW sets. SargeNZ Video Piloting (FPV/RPV) 7 Mar 06, 2012 09:32 AM
Discussion 5.8ghz 200mw on Blade 120 SR - pics Vitamin_J Video Piloting (FPV/RPV) 2 Mar 27, 2011 10:25 AM
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari Video Piloting (FPV/RPV) 6 Mar 26, 2011 02:25 PM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV/RPV - Equipment and Vehicles (FS/W) 1 Mar 22, 2011 08:01 PM
Sold 5.8GHz / 200mW Video Tx and Rx. New. Mr.RC-CAM FPV/RPV - Equipment and Vehicles (FS/W) 1 Nov 02, 2010 09:07 PM
