Old May 29, 2012, 12:48 AM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
I own this but have not do any real fpv with it yet still looking for a camera, at we have a small school football field that are surrounded by tree will it effect the signal if I'm flying up high and distant?
skellator is offline Find More Posts by skellator
Old May 29, 2012, 01:16 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Yes, a lot if the tree is between you and the plane.
renatoa is online now Find More Posts by renatoa
Old May 29, 2012, 01:33 AM
9W2DLR
Joined Nov 2011
here some view of it:
this the tree
more tree but I have a straight view
Old May 29, 2012, 01:47 AM
futurebreeze is offline
Find More Posts by futurebreeze
FPV addicted
futurebreeze's Avatar
Romania, Bucharest
Joined Jul 2010
If you make a flight plan and keep a high enough altitude you could avoid the trees interfering with your video/RC signal.
futurebreeze is offline Find More Posts by futurebreeze
Old May 29, 2012, 01:52 AM
9W2DLR
Joined Nov 2011
I guess I only know when i try it, but don't dare to try it yet as if crash 100% i wont be seeing it anymore as it a jungle on the other side :P, still sourcing for a OSD with RTH, I guess better stick with park flying for now
attached
Old May 29, 2012, 01:57 AM
Joined Sep 2007
RTH won't help if failsafe occurs behind the tree, will thing the shortest path to home is exactly passing through the tree, and quess what's next ...
Old May 29, 2012, 02:01 AM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
yebbut RTH is usually with a default altitude which can be set well above the height of the tree(s). and Skellator can ensure he is higher than the tree before exiting the park.
Much scarier here where I live the trees are 100ft+ tall and they are in every direction.
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old May 29, 2012, 02:04 AM
9W2DLR
Joined Nov 2011
I thought we can set safe altitude for RTH? i don't know i don't have one yet , I heard you could , mostly the tree here are not 100ft tall
Old May 29, 2012, 03:05 AM
tuongnhu is offline
Find More Posts by tuongnhu
Joined Dec 2006
Nova osd with rth does not have any function to set the safe altitude for RTH but It keeps the altitude very good in rth mode. If you fly high enough above the tree, rth will keep that altitude and bring your plane back. (if you have done the correct failsafe with rth)
Here is my video testing of dx7 and ar7000 failsafe with Nova osd rth. In the flight, the signal had been lost three times, but the failsafe and rth kept the plane went on and got home safety.
FPV 2km from base with DX7 stock antenna (6 min 13 sec)
tuongnhu is offline Find More Posts by tuongnhu
Old May 29, 2012, 03:25 AM
9W2DLR
Joined Nov 2011
http://www.youtube.com/watch?v=w7AwP1FyRj8
nova is the cheapest option but the only source with cheap shipping it out of stock (foxtech) ebay only 2 seller but I have bad experience with both sellers
Old May 29, 2012, 03:31 AM
tuongnhu is offline
Joined Dec 2006
I bought it from himodel with the china ems shipping cost about $10. It 's fast and not too expensive. it is instock now:
CYCLOPS NOVA OSD System W/GPS (Capacity consuming bug fixed)
Old May 29, 2012, 03:57 AM
9W2DLR
Joined Nov 2011
Thanks Just ordered one!
Old May 29, 2012, 08:11 AM
Gotwings is offline
Find More Posts by Gotwings
Joined Jan 2012
RC-805 5.8 GHz Receiver A/V Plug
Hello,
I found a discussion on the A/V plug pin out for the RC305 receiver, however I have a 508 that did not come with an A/V plug. Pictured on HK is a 4 pole mini jack (2.5 mm) with only two (2) RCA connections (1 audio and video). The 305 shows three RCA's (vid and 2 audio). As mentioned in previous discussion, the "standard" in cable wiring vary's from manufacture to manufacture, country to country...
Does anyone have an 805 that can help confirm the following:
1. what is the length of the plug connector (radioshack has 2, 3 and 4 pole 2.5 mm adapters but they are shorter than the 3.5 mm plugs)?
2. what is the corresponding layers of the minijack to RCA connector?
3. is this unit putting out a single channel of audio or splitting to Left / Right?
thanks for any input... right now, with the "shortened" 2.5 mini plug, I have to slightly pull the plug out, to get the connection to work (not sure if i'm removing an audio channel from the "tip" but it makes the connection not secure...
cheers!
Gotwings is offline Find More Posts by Gotwings
Old May 29, 2012, 09:34 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Originally Posted by Gotwings View Post
Hello,
cheers!
1.) 4 pole, 11.5mm
2) From tip to base, nc, audio, video gnd
3) Like all SkyRf based products it's mono audio only (single channel as you say).
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old May 29, 2012, 09:39 AM
Registered FPVer :)
Joined Aug 2006
Hello,
I found a discussion on the A/V plug pin out for the RC305 receiver, however I have a 805....
To others who don't have this rx but plan on buying one. Stay clear. Get the RC 305 instead.
Reasons:
#1, The 805 has all connections on one end, which leads to the A/V plug ending up in the nearfield of the rx antenna. Very bad.
#2, For unknown reasons the HF module is mounted diagonally on the carrying power supplying PCB board. This leads to uneven lenghts of the mass connection to the antenna and a somewhat longer, bow shaped antenna trace to the SMA connector. This is 5.8Ghz where things like this truly are very very bad ideas.
#3, the design is so broken cause the housing aparently comes from some small remote controll and someone decided to squeeze this rx into the same housing. The compromises as outlined above are probably ok for a baby monitoring application but definately not for FPV where we want to squeeze out the maximum of those video links.
HTH
Markus
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari FPV Talk 7 Aug 12, 2013 12:48 AM
Cool Hobbyking has cheap 5.8ghz 200mW sets. SargeNZ FPV Talk 7 Mar 06, 2012 09:32 AM
Discussion 5.8ghz 200mw on Blade 120 SR - pics Vitamin_J FPV Talk 2 Mar 27, 2011 10:25 AM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV Equipment (FS/W) 1 Mar 22, 2011 08:01 PM
Sold 5.8GHz / 200mW Video Tx and Rx. New. Mr.RC-CAM FPV Equipment (FS/W) 1 Nov 02, 2010 09:07 PM
