Old Apr 06, 2012, 01:30 PM
witstick is offline
Find More Posts by witstick
KY3JBD
lebanon, PA
Joined Dec 2000
Hello, i just did my first FPV flight with 200mw TX and RC305 rx with bluewhip antennas. Reception was great, matter of fact it was so good that my twinstar got so far away my spotter could hardly see it and i had to turn back before i got lost. Only time i had a fuzzy picture is when i flew over some huge power line towers. So far i am really impressed with this setup!
Chris.
witstick is offline Find More Posts by witstick
Old Apr 06, 2012, 01:32 PM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Originally Posted by markus123456 View Post
...i suggest to organize a very clean 3.3volt power source (for a quick hack, a 1s lipo with a linear voltage regulator but don't try without the regulator as you otherwise will fry your module) ...
renatoa is offline Find More Posts by renatoa
Old Apr 06, 2012, 01:51 PM
Airbuzzler is offline
Find More Posts by Airbuzzler
Joined Aug 2011
I know that I am using this module : http://www.foxtechfpv.com/product/5....23-Spec-V1.pdf
And I was thinking that a 3,3 V UBEC like mine (http://www.hobbyking.com/hobbyking/s...ly_6_23v_.html) would do its job.
So you think its best when I change my power source from UBEC to a normal voltage regulator ?
Airbuzzler is offline Find More Posts by Airbuzzler
Old Apr 06, 2012, 02:00 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
You could install some capacitors to clean up the signal...do you have the channels correctly set?
msev is offline Find More Posts by msev
Old Apr 06, 2012, 02:09 PM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
A UBEC does not have to generate a power train as clean as you need it to process an analog signal like the TV signal. There might be such products which are very quiet. There is nothing wrong with the UBEC aproach per se, but you would have to take aditional measures to clean it's signal.
The voltage regulator alone, when fed from the main battery where the ESC is connected to would also not work. You need a combination of DC/DC (read UBEC) to bring the voltage down and aditional filtering to do the trick. One aproach is the daisy chain a UBED (DC/DC converter) with a following linear (low drop) voltage regulator. But that would be a "final" aproach. I think we now have to find out what's going on first and get there as simple and quickly as we can, hence the proposed test.
Markus
markus123456 is offline Find More Posts by markus123456
Old Apr 06, 2012, 02:52 PM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
That is what I have done markus.
here is with no filtering.
http://www.youtube.com/watch?feature...&v=ed7Sbn5kBGc
here with a filter
http://www.youtube.com/watch?&v=PoG_XKnWDcs
here is the filter
All taken from an old computer power supply.
1 - toroid core
1 - 470u 16v cap
1 - 104 ceramic cap
http://static.rcgroups.net/forums/at...7-IMG_0916.jpg
whakahere is offline Find More Posts by whakahere
Old Apr 06, 2012, 03:29 PM
Registered FPVer :)
Joined Aug 2006
here with a filter
here is the filter
1 - toroid core
1 - 470u 16v cap
1 - 104 ceramic cap
Every DC/DC converter type also has other harmonics and ripple, so what helped in your case might helps in the other, but not necessairly. I currently have my CNC mill running, so I could not hear in your video if you had the motor running (and every bec and motor also behaves differently) or not. To me it looked more like remaining ripple from your DC/DC converter as noise introduced by motors usually looks different (bigger stripes).
Makeing a good clean power train is sometimes not so trivial. As mentioned, the trouble also could be caused by other things, that's why I suggested to reduce the setup to the abolutely necesairy things, then do range tests without motor to see if we face an issue with the HF parts including the antennas cables etc. or if it's power source related. In situations like this you need to exclude causes to get to the bottom of the problem.
Markus
Old Apr 06, 2012, 03:32 PM
msev is offline
Joined Sep 2010
The guy with the low range uses a two battery setup, so there shouldn't be interferences through the wires, if its not connected to the motor..right.
Old Apr 06, 2012, 04:08 PM
Registered FPVer :)
Joined Aug 2006
It sounded alike, but he uses a UBEC, alas a DC/DC converter to power the HF module (at least that's how I understood), so either ripple and or harmonics caused by that (or other on board components) could have disasterous influence.
I would rip the vtx and camera out, provide a clean 3.3v source and do a ground test. Should give a clear answer. If this works, then add the UBEC and so on up until the source of the problem is found. If it does not work, replace the camear also to exclude that too and so on.
Markus
Old Apr 06, 2012, 04:18 PM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
That's why I use a 'dumb-as-a-rock' 3v3 800mA LDO regulator.
I get no interference on my little 'pod' and no need for complex filtering, just a simple DIY power supply that feeds the VTx and camera from the balance port of the flight battery.
http://www.rcgroups.com/forums/showp...&postcount=790
Just waiting for a nice C-P antenna to arrive
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Apr 06, 2012, 05:16 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
when you say you power it off the balance port does that mean you only tap 2 cells?
Old Apr 07, 2012, 02:14 AM
Devonboy is offline
SW England
Joined Aug 2009
Yep, exactly that.
2S lead
http://www.giantcod.co.uk/silicone-c...-p-406533.html
3S lead
http://www.giantcod.co.uk/silicone-c...-p-406534.html
Cut off the male end and then feed whatever voltage(s) you need from the female end to the voltage regulator/pod/camera/VTx.
You could tap it twice, once for the camera and again for the VTx and not bother with the voltage regulator (same as running from a 1S LiPo).
Nigel.
Old Apr 07, 2012, 03:45 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
As oposed to quix-fz opinion, the antennas make a big difference, but the range you get is catastropic. Asuming you use a 200mW sky-rf setup, you should get 3km for sure with the antennas unless you fly above some very very RF noisy area. Even there you would get way more than 300 - 500 meters. So something must be fundamentially wrong.
The 5.8Ghz setups usually are pretty roubust in terms of other components radiating in or harmonics even thoug this still could be. Are you sure what you observe is not based on an unfiltered noisy power train? Do you use the stock transmitter, or are you useing a HF module alone with some sort of power source? Did you made ground range tests without motor running? How about posting a video?
Markus
Power train? Mine's completely unfiltered and as simple as it gets. I have the F450 frame with the built-in power distribution board, that supplies power to all motors. I also have a JST connector on one pad and that feeds power to the video setup. So one battery is used for everything. I used to have a dedicated 3S Lipo feeding the video Tx (It won't take 2S as far as I know) but removed that to save weight and that setup worked for me at close range, so I never noticed any issues.
Are you saying you have to use a dedicated battery and whatnot? The voltage fluctuations in the main power train is enough to throw off the 5.8ghz equipment? I've heard the thing about some cameras being noisy, mine's right up against the video Tx, here's a pic of the setup, ignore the antenna, I've got yours on it right now. Also, I'm using the Hobbyking 200mw 5.8ghz kit.
Here is my usable range at the moment... Also, it's worth noting that without ANY sort of quad, just holding the receiver and goggles in my hand I got 900m out of my own antennas before I had to turn back because lunchtime was over! So it's the quad for sure, something on it... Also, I wouldn't say this is an area full of interference, there are no towers or buildings nearby, it's just a huge empty area.
WiseDuck is offline Find More Posts by WiseDuck
Old Apr 07, 2012, 04:28 AM
msev is offline
Joined Sep 2010
Whaka if you have some extra time on your hands you could make a flight test with that 3.3V ubec, so we'll know if that's the issue or not..
Wiseduck you could try a secondary lipo and add some distance between the cam and the tx, and then tell us if the range is still shabby..
Old Apr 07, 2012, 04:49 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Ive got everything on my VC-FPV frame now. I'll maiden it later today and also test the FPV setup with a separate Lipo and whatnot. I'm very close to finishing this thing.
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari FPV Talk 7 Aug 12, 2013 12:48 AM
Cool Hobbyking has cheap 5.8ghz 200mW sets. SargeNZ FPV Talk 7 Mar 06, 2012 09:32 AM
Discussion 5.8ghz 200mw on Blade 120 SR - pics Vitamin_J FPV Talk 2 Mar 27, 2011 10:25 AM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV Equipment (FS/W) 1 Mar 22, 2011 08:01 PM
Sold 5.8GHz / 200mW Video Tx and Rx. New. Mr.RC-CAM FPV Equipment (FS/W) 1 Nov 02, 2010 09:07 PM
