Old Mar 29, 2012, 04:15 PM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Originally Posted by Devonboy View Post
Spectrum Analyser anyone?
Nigel.
Sure, her we go, and it gets interesting!
Renato, costi_n, futurebreze you guys were right, the datasheet is wrong, so was I!
Scan of tx with all connections left open (floating) reveals it in fact transmits on 5945Mhz, alas channel 8.
Lesson learned, you have to doubth datasheets from chinese vendors....
Markus
markus123456 is offline Find More Posts by markus123456
Old Mar 29, 2012, 04:23 PM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Err... I'm with Markus on this one.
Direct from Sky-rf...PDF
http://www.sky-rf.com/Upfile/2011815...1562268065.pdf
Nigel.
Sure, but depends what means 0 and 1 in Chinese
renatoa is offline Find More Posts by renatoa
Old Mar 29, 2012, 04:34 PM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
OK, fair enough, I was going by their pdf data sheet as well.
Should we put this down to Chinglish interpretation again
Lesson learnt.
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Mar 29, 2012, 09:00 PM
rcall is online now
Find More Posts by rcall
FPVing for fun...
rcall's Avatar
Joined Jul 2003
the datasheet is right: 0 means ground, 1 means open... so 0-0-0 = 5.705...
rcall is online now Find More Posts by rcall
Old Mar 30, 2012, 12:11 AM
futurebreeze is offline
Find More Posts by futurebreeze
FPV addicted
futurebreeze's Avatar
Romania, Bucharest
Joined Jul 2010
Err...nothing
futurebreeze is offline Find More Posts by futurebreeze
Old Mar 30, 2012, 07:25 AM
Airbuzzler is offline
Find More Posts by Airbuzzler
Joined Aug 2011
Anyone know why my system is not working with the 470uf cap ? I use the 200mW SkyRF TX module from foxtech. The system is running good and the picture is not that bad. But I want to build in these caps for best picture.
I soldered the cap between the GND from the 3,3V UBEC and the GND on the module. Any ideas ?
Airbuzzler is offline Find More Posts by Airbuzzler
Old Mar 30, 2012, 07:29 AM
renatoa is offline
Joined Sep 2007
Ooouuuppsss ?!!!
How this ?! The two grounds must be soldered together, and cap is between plus and ground, not between grounds !
Old Mar 30, 2012, 08:46 AM
Joined Aug 2011
ohhhh okaaay I now I understand I thought the cap is just on gnd Thank you
BTW:
This is my ugly little ground station First FPV Setup :
http://s14.directupload.net/file/d/2...xur3o2_jpg.htm
Old Mar 30, 2012, 03:12 PM
janissav is offline
Find More Posts by janissav
Latvija
Joined Nov 2010
BTW:
Nice. Good job.
But or LCD is too small and too low resolution?
Suitable for FPV?
janissav is offline Find More Posts by janissav
Old Mar 31, 2012, 01:11 PM
Ceros007 is offline
Find More Posts by Ceros007
Ceros007's Avatar
Montreal, Québec, Canada
Joined Apr 2010
Just bought the 200mW 5.8Ghz from HK with the Super Simple OSD and the 17$ CCD (PAL) Cam as a starting kit.
Ceros007 is offline Find More Posts by Ceros007
Old Mar 31, 2012, 02:48 PM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
make yourself a cloverleaf and SPW antenna and you will have a great cheap kit.
whakahere is offline Find More Posts by whakahere
Old Apr 01, 2012, 10:06 AM
Ceros007 is offline
Ceros007's Avatar
Joined Apr 2010
I don't own any tools for analysing the frequency, etc.. And I guess that your put the cloverleaf on the TX and SKew on the RX?
Old Apr 01, 2012, 10:42 AM
renatoa is offline
Joined Sep 2007
Not need, if you have good soldering skills and are precise with distances, angles, you have from scratch better results than stock antennas without any tuning.
Old Apr 01, 2012, 10:56 AM
Ceros007 is offline
Ceros007's Avatar
Joined Apr 2010
Yea I read the Cloverleaf tuto from IBCrazy. The only thing I don't understand is how you determine if it's right-hand or left-hand...
Old Apr 01, 2012, 10:59 AM
renatoa is offline
Joined Sep 2007
how are the leafs leaned, L or R
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari FPV Talk 7 Aug 12, 2013 12:48 AM
Cool Hobbyking has cheap 5.8ghz 200mW sets. SargeNZ FPV Talk 7 Mar 06, 2012 09:32 AM
Discussion 5.8ghz 200mw on Blade 120 SR - pics Vitamin_J FPV Talk 2 Mar 27, 2011 10:25 AM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV Equipment (FS/W) 1 Mar 22, 2011 08:01 PM
Sold 5.8GHz / 200mW Video Tx and Rx. New. Mr.RC-CAM FPV Equipment (FS/W) 1 Nov 02, 2010 09:07 PM
