Old Mar 28, 2012, 10:07 AM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
hi Renatoa,
thank you for the link!
as i understand: this element is for the filtering between power supply and video power .... to burn this element there must be a short connection outside the plug (in the plane) for video/audio to burn this.
the workaround is to make the bridge on the pcb.
but for a repair i need the definiton of this element ... any idea?
cheers Thomas
Thint1 is offline Find More Posts by Thint1
Old Mar 28, 2012, 10:26 AM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
@ whakahere,
I used a 3.3v 800mA Low Drop Out regulator
http://www.national.com/mpf/LM/LM1117.html#Overview
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Mar 29, 2012, 01:02 PM
Airbuzzler is offline
Find More Posts by Airbuzzler
Joined Aug 2011
Hey guys I got some problems with my fochtech modules. I got a RX Module which is working pretty nice. But my TX Module is causing some problems. I dont get a signal from the TX to RX. Just If I am turning the TX there is short signal on the screen. I checked all connections and resoldered them but nothing seem to work. I am using the 200mW 5,8ghz module from fochtech and I am powering it with an 3,3V UBEC.
Anyone got an idea ?
Airbuzzler is offline Find More Posts by Airbuzzler
Old Mar 29, 2012, 01:33 PM
futurebreeze is offline
Find More Posts by futurebreeze
FPV addicted
futurebreeze's Avatar
Romania, Bucharest
Joined Jul 2010
Did you set the channels properly?
futurebreeze is offline Find More Posts by futurebreeze
Old Mar 29, 2012, 01:40 PM
Joined Aug 2011
I soldered them all to GND for the first tests. That should work ?! Later I will install a switch for changing channels.
Old Mar 29, 2012, 01:47 PM
FPV addicted
Romania, Bucharest
Joined Jul 2010
Yes the TX should work, you are now on 5705 mHz channel. The same must be on your RX, of course, all the switches to ON position. Like in the picture below:
Old Mar 29, 2012, 02:14 PM
Joined Aug 2011
Thank you so much. It was not exactly the way you told but now its working
But I also got the problem with the lines and when I am just soldering a cap 470uf the TX is not working anymore. Any solution ?
Old Mar 29, 2012, 03:04 PM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Err...
If he soldered all the connectors on the tx to GND, then he's on channel 8 which equals 5945Mhz.
Leaving the connections OPEN (not connected to GND) would put him on channel 1, alas 5705Mhz.
However, your advice to switch all rx switches to ON (alas down) was correct as this also sets the rx to channel 8 => 5945Mhz
Markus
markus123456 is offline Find More Posts by markus123456
Old Mar 29, 2012, 03:19 PM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Err... nope, viceversa
"Channels selection are below:
Ch1 pin + Ch2 pin + Ch3 pin connect to ground (Channel 1 - 5.705 gHz)
DEFAULT - no connect to ground (Channel 8 - 5.945 gHz)"
Quoted from fpvhobby
renatoa is offline Find More Posts by renatoa
Old Mar 29, 2012, 03:31 PM
rcall is offline
Find More Posts by rcall
FPVing for fun...
rcall's Avatar
Joined Jul 2003
that's correct, that's how I am using it at 5.705 GHz...
rcall is offline Find More Posts by rcall
Old Mar 29, 2012, 03:34 PM
Devonboy is offline
SW England
Joined Aug 2009
Err... I'm with Markus on this one.
Direct from Sky-rf...PDF
http://www.sky-rf.com/Upfile/2011815...1562268065.pdf
Nigel.
Old Mar 29, 2012, 03:40 PM
Registered FPVer :)
Joined Aug 2006
Nigel.
I'm with myself too. But hey, maybe we all should vote. I hope the modules respect democracy!
SCNR,
Markus
Old Mar 29, 2012, 03:57 PM
costi_n is offline
Find More Posts by costi_n
Romania, Bucuresti, Bucharest
Joined Dec 2010
Originally Posted by markus123456 View Post
Err...
Markus
Errr...conecting all pins to GND vtx is on CH1 5705Mhz
costi_n is offline Find More Posts by costi_n
Old Mar 29, 2012, 04:02 PM
Devonboy is offline
SW England
Joined Aug 2009
Spectrum Analyser anyone?
Nigel.
Old Mar 29, 2012, 04:15 PM
costi_n is offline
Joined Dec 2010
Nigel.
Me. Frequency counter.
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari FPV Talk 7 Aug 12, 2013 12:48 AM
Cool Hobbyking has cheap 5.8ghz 200mW sets. SargeNZ FPV Talk 7 Mar 06, 2012 09:32 AM
Discussion 5.8ghz 200mw on Blade 120 SR - pics Vitamin_J FPV Talk 2 Mar 27, 2011 10:25 AM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV Equipment (FS/W) 1 Mar 22, 2011 08:01 PM
Sold 5.8GHz / 200mW Video Tx and Rx. New. Mr.RC-CAM FPV Equipment (FS/W) 1 Nov 02, 2010 09:07 PM
