Old Mar 20, 2012, 06:49 AM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
Originally Posted by RENATOA View Post
Probably he means 5V at the input of LM1117T and 3.3 output powering the module.
Yup input. I want to through 12volts into it but I am starting to think this isn't as easy as I first thought. Damn I wish I had the knowledge to make a low noise switching power supply for these things. Anyone with knowledge how to build such a circuit?
whakahere is offline Find More Posts by whakahere
Old Mar 20, 2012, 07:21 AM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
Circuit is simple, 2 caps and you're done.
Better to feed it from 2S via balance lead.
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Mar 20, 2012, 09:43 AM
jon davies is offline
Find More Posts by jon davies
S. Wales
Joined Jun 2008
I once used an LM1117 to supply 3.3v to a 100mW AWM Tx and an LM7805 to supply a 5v camera. To spread the heat dissipation I connected the 12v supply to an 8v reg to supply the 5v reg which supplied the 3.3v reg, rather than use two batteries, or two connectors from the same battery. Worked OK without capacitors. I've never had to use any filtering on linear regulators.
jon davies is offline Find More Posts by jon davies
Old Mar 20, 2012, 04:27 PM
piollo is offline
Find More Posts by piollo
I wish I could fly...
piollo's Avatar
Spain
Joined Nov 2007
Kind of connector
Originally Posted by emadine View Post
I have just bought this Tx/Rx but I haven't received yet. I'm willing to make SPW/CP antennas but I don't know what kind of connector I should buy: SMA or RP-SMA?
Any help will be appreciated.
Thanks.
piollo is offline Find More Posts by piollo
Old Mar 20, 2012, 04:33 PM
CTvxl is offline
Find More Posts by CTvxl
United States, TX, Mansfield
Joined Jan 2012
Thanks.
looks like airwave, so should be RP-SMA
CTvxl is offline Find More Posts by CTvxl
Old Mar 20, 2012, 04:40 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
It's skyrf, but still RP-SMA
sammyc is offline Find More Posts by sammyc
Old Mar 21, 2012, 08:06 AM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
At last my 3.3volt regs arrived. first thing was t open them up and see what they are made of. I found that they have the MP2307DN reg chip in them. Is this any good or will it create noise for our uses?
On a side note, as I was searching for the chip details I came across this :
http://www.ledsales.com.au/catalog/i...roducts_id=810
Since I opened it up and look at the board this is a complete copy of what you see here. Everything is in the same place apart that the hobbyking bec has a cap on it and is sheilded with a wrap of tin foil. other than that it is a complete copy.
or buy 10 for $9
http://www.ebay.com/itm/10x-3A-DC-DC...ht_3982wt_1348
http://www.aliexpress.com/fm-store/3...KIS-3R33S.html
So If they work you can get them much cheaper
Old Mar 21, 2012, 08:14 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Now try it and tell us if you get that white lines ..
msev is offline Find More Posts by msev
Old Mar 21, 2012, 08:26 AM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
going to do that next. If it does I will need some smart people to tell me how to fix it.
Old Mar 21, 2012, 01:07 PM
rcall is offline
Find More Posts by rcall
FPVing for fun...
rcall's Avatar
Joined Jul 2003
Originally Posted by rcall View Post
I've got a 200mW module from FPVHobby and I mounted it to the back of a mini 420tvl camera for a quick test... both are 5V and I'll connect them directly to the receiver...
the Tx came with a simple wire for antenna and before I change it to a CL I'll do some tests with a rubber duck on the receiver...
flew today and got nice results, no noise or interference, only some when flying behind trees... up to 300m video was fine, didnīt go further than that...
I had a bad surprise when I got to the field: weird colors, whitish trees!
I had replaced the original 3.6mm lens with a 2.8mm and found out that this camera needs lenses with a built-in IR filter... the color shift wasn't visible when I tested it indoors...
rcall is offline Find More Posts by rcall
Old Mar 21, 2012, 01:44 PM
Devonboy is offline
SW England
Joined Aug 2009
You may be able to place a bit of IR glass on top of the sensor and negate the need for a lens with IR filter.
I had the same problem, but had an old camera with the bit of IR glass, swapped it in and nice colours outdoors again.
At least your camera will be good for night flying !!
HTH
Nigel.
Old Mar 22, 2012, 10:51 AM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
yes there are white lines. Very small but they are there. Good news is that you can remove them with a toroid core. I might just make a LC filter there too but I don't think it is needed.
Old Mar 22, 2012, 10:58 AM
msev is offline
Joined Sep 2010
Nice so an easy solution..Great!
Old Mar 22, 2012, 11:09 AM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
bugger ... not really as I tried it again and while the lines did go away they were still there. I tried with just a large toroid but it didn;t work ...then put the small one back on and it didn't work as well. Need to find a simple and light way to remove the noise properly.
Old Mar 22, 2012, 11:32 AM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
here is what it looks like without the extra toroid core. I was going to record with it but the battery on my record died.
http://www.youtube.com/watch?v=ed7Sbn5kBGc
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari FPV Talk 7 Aug 12, 2013 12:48 AM
Cool Hobbyking has cheap 5.8ghz 200mW sets. SargeNZ FPV Talk 7 Mar 06, 2012 09:32 AM
Discussion 5.8ghz 200mw on Blade 120 SR - pics Vitamin_J FPV Talk 2 Mar 27, 2011 10:25 AM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV Equipment (FS/W) 1 Mar 22, 2011 08:01 PM
Sold 5.8GHz / 200mW Video Tx and Rx. New. Mr.RC-CAM FPV Equipment (FS/W) 1 Nov 02, 2010 09:07 PM
