Old Mar 14, 2012, 06:39 AM
rcall is offline
Find More Posts by rcall
FPVing for fun...
rcall's Avatar
Joined Jul 2003
I've got a 200mW module from FPVHobby and I mounted it to the back of a mini 420tvl camera for a quick test... both are 5V and I'll connect them directly to the receiver...
the Tx came with a simple wire for antenna and before I change it to a CL I'll do some tests with a rubber duck on the receiver...
the antenna is 17mm long, should I trim it to a proper length for the frequency I am using, 5705MHz?
rcall is offline Find More Posts by rcall
Old Mar 14, 2012, 08:17 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Expect terrible noise in the picture as soon as you turn on the motor. The ESC causes big spikes in current which change the "level" of the vidoe signal relative to ground as seen by the transmitter. For this configuration, you need a dedicated lipo cell to power the tx and camera.
Does not make much sense since you intend to change it anywaysy. The limitation of this setup in it's current configuration is not range (here tuning the antenna could help provided you could measure what you do), but reflections and they are not influenced by such a change. Safe yourself the hassle and switch to CP antennas.
Remember, if you use a CP antenna, to solder the mesh of the coax to BOTH pins on the sides of the pin where right now the antenna wire is soldered to. Splice it up accordingly. That's important to shield the signal and also to somewhat maintain the impedance. Make this connection as tight/short as you can. The center of the coax then would replace the current antenna wire.
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old Mar 14, 2012, 08:22 AM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
@ rcall
5V for the VTx module is really too much, it should be 3.3v and some are using a single cell LiPo @ ~3.7v
Seriously, for long life you should run it at 3v3 - HK sell a little v-reg suitable for powering it.
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Mar 14, 2012, 09:15 AM
Registered FPVer :)
Joined Aug 2006
+1 on this ^
I overlooked it and unless you have one of the rare modules with internal regulator, you definately WILL fry it if running at 5V. Been there, done that....
Markus
Old Mar 14, 2012, 11:05 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
He wrote in OP is the FPVHobby module, so should have embedded regulator.
Anyway, keep a finger on module when first time power, if it heats in some seconds at more than 50C (max the human skin can support without issues) then power off imediatelly.
renatoa is online now Find More Posts by renatoa
Old Mar 14, 2012, 11:09 AM
rcall is offline
FPVing for fun...
rcall's Avatar
Joined Jul 2003
HTH
Markus
bench tests didn't show any noise with motor and servos running, let's see what happens on the field... it will be a 3rd person flight recorded
I will change to CP but I wanted to make a quick test to compare...
as for the 5V, FPVHobby says it is regulated and I have it running for several minutes without problem... it gets a bit hot but not excessively...
Old Mar 16, 2012, 06:16 AM
BKMorpheus is offline
Find More Posts by BKMorpheus
BKMorpheus's Avatar
NRW, Germany
Joined Dec 2010
My buddy has now built the DIY SWR meter to find out if our antennas are any good.
We were suprised after we found out that most of the antennas have a swr between 2.05 and 3.5 instead of ~1.05
One of those Antennas was built on our own, the others were bought from other people.
Is it possible, that the SWR meter is not working correctly or needs some tuning (because we are satisfied with the FPV performance of those antennas)?
Tomorrow we can test one of Marcus antennas which are looking really nice, maybe they will give better results.
edit: seems to be a problem of the SWR...even when we test the same antenna multiple times the result is very different...so we will check the SWR meter to fix it.
BKMorpheus is offline Find More Posts by BKMorpheus
Old Mar 16, 2012, 07:34 AM
Joined Sep 2007
If the measuring of SWR in GHz would be so simple, the xxxx$ units wouldn't sell...
Too many gurus in that swr thread to make them understand this.
Old Mar 16, 2012, 09:08 AM
MarekM is offline
Find More Posts by MarekM
Bielsko-Biala, Poland
Joined May 2006
Better check environment when measuring..... (close to SWR-meter and antenna)
MarekM is offline Find More Posts by MarekM
Old Mar 18, 2012, 12:43 PM
Papat is offline
Find More Posts by Papat
Pat K
The Netherlands
Joined Dec 2010
RSSI voltage vs distance
Hi all,
has anyone of you ever recorded the RSSI value of your receiver vs distance?
I just made a flight using 5.8GHz 200mW from FPVHobby (I guess Tx/Rx come from SkyRF) and my brand new DIY CL/SPW. I measured the RSSI values of my video receiver and got the following:
- 10m: 1.19V
- 500m: 0.85V
- 1km: 0.70V (still clear video)
- Noise floor (Tx unpowered): 0.43V
I have not checked my antennas yet at the Lab but will do ASAP.
Are these values consistent with your experience?
Pat
Papat is offline Find More Posts by Papat
Old Mar 18, 2012, 12:54 PM
msev is online now
Find More Posts by msev
Joined Sep 2010
Question is written on the pic...Although there is minus written above that triangle, but you can't never trust the chinese .
This is the power cable for the video receiver btw.
msev is online now Find More Posts by msev
Old Mar 18, 2012, 12:57 PM
msev is online now
Joined Sep 2010
Papat would you share how you modified it for rssi?
Old Mar 18, 2012, 01:04 PM
Papat is offline
Pat K
The Netherlands
Joined Dec 2010
I did not modify anything, just connected the RSSI output to a voltmeter.
Here is the Rx I'm using: Here
Old Mar 18, 2012, 06:22 PM
Registered FPVer :)
Joined Aug 2006
Asuming you have an RC-305 or RC-805, if you open it, you see a HF module soldered onto the PCB. Put the rx in front of you such that the antenna connector points away from you. Then, the RSSI output is the sixt connection from the left.
HTH
Markus
Old Mar 19, 2012, 03:56 AM
msev is online now
Joined Sep 2010
HTH
Markus
Markus what about my question about the powering cable for rc305? Is there where there is a triangle and a - written, ground? I gotta ask since this is a critical area where I could make a mistake..
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari FPV Talk 7 Aug 12, 2013 12:48 AM
Cool Hobbyking has cheap 5.8ghz 200mW sets. SargeNZ FPV Talk 7 Mar 06, 2012 09:32 AM
Discussion 5.8ghz 200mw on Blade 120 SR - pics Vitamin_J FPV Talk 2 Mar 27, 2011 10:25 AM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV Equipment (FS/W) 1 Mar 22, 2011 08:01 PM
Sold 5.8GHz / 200mW Video Tx and Rx. New. Mr.RC-CAM FPV Equipment (FS/W) 1 Nov 02, 2010 09:07 PM
