Old Mar 12, 2012, 12:58 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
Cool, thank you!
msev is offline Find More Posts by msev
Old Mar 12, 2012, 02:07 PM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Originally Posted by nkkromhof View Post
Slightly off-topic, but this thread seems to be as good a place to ask as any:
When using a 5.8Ghz CP omni antenna, how high do you recommend raising the RX/antenna from the ground.
I'm sure "as high as possible" will be a popular answer, but I'm looking to balance practicality with maximizing range on the omni and I'm guessing there's a point of diminishing returns.
I'm using a tripod with a wooden stick mounted onto it and the rx is then on the top of that stick. Sits about 3m above ground this way. This makes sense as otherwise people walking around you will get into the LOS with potentially disasterous consequences. I'm flying with glasses, and often don't have control over who is aproaching me and again this height above ground solves this problem.
From a link standpoint of view probably 2m or even slightly less should be sufficient.
Markus
markus123456 is offline Find More Posts by markus123456
Old Mar 12, 2012, 03:52 PM
msev is offline
Joined Sep 2010
While I'm waiting for the video rx to arrive I'm slowly trying to look at the schematic and have a few questions.
Do I need those 470uF caps? Do I need to connect all the ground pins (3,5,11,9) to ground or just one?
Can the module tin case be considered as ground for channel selection? Ground for power should be the ground on power supply and should be connected to one of the pins - 3,5,11,9 right?
Can the tin case also be considered as ground for antenna? The coax central conductor should be connected to pin 10, should the outer shield be connected to tin case?
Old Mar 12, 2012, 04:23 PM
Registered FPVer :)
Joined Aug 2006
The caps are not needed if you have a very clean power source (dedicated battery). GND is connected internally, so answer is no. The case is GND too, so yes you can use it for strapping the channel. Again, GND is GND, does not matter where you connect it. The antenna should be connected such that the center of the coax goes to the decicated pin AND THE MESH SHOULD BE CONNECTED TO THE TWO PINS ON THE SIDES OF THIS CENTER PIN. That's very important for shielding purposes and to maintain the impedance of the output.
HTH
Markus
Old Mar 12, 2012, 05:13 PM
msev is offline
Joined Sep 2010
Thanks M.! So shielding should be connected to both pin 11 and pin 9...Great!
Old Mar 12, 2012, 05:18 PM
Registered FPVer :)
Joined Aug 2006
Yes, and the shorter/closer you manage to do this the better.
Markus
Old Mar 12, 2012, 05:41 PM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Originally Posted by edge0xc View Post
hey,
i just got my 200mW TX, but it looks like, if there is something missing?
Is this normal?
Cheers
Alex
hi Alex,
i received my set from foxtech today. the cap is also not soldered on my tx!
seems to be the new lo-cost version
can anyone translate what "476 25K 011" means .... xxF/yyV?
cheers Thomas
Thint1 is offline Find More Posts by Thint1
Old Mar 12, 2012, 05:49 PM
Registered FPVer :)
Joined Aug 2006
Originally Posted by Thint1 View Post
hi Alex,
cheers Thomas
It's a relatively expensive low ESR capacitor and I suspected the factory started to make them without it. The transmitter will work as the output stage of the dc/dc converter is likely to have capacitors too. Maybe those transmitters have more noise in the picture or are a bit more prone to noise but we would have to measure and compare them to know.
Markus
Old Mar 12, 2012, 11:53 PM
futurebreeze is offline
Find More Posts by futurebreeze
FPV addicted
futurebreeze's Avatar
Romania, Bucharest
Joined Jul 2010
hi Alex,
cheers Thomas
It's a tantalum 47F capacitor and it is not so expensive, 0.10-0.20 USD. Or maybe it is expensive for the Chinese cheap manufacturers
futurebreeze is offline Find More Posts by futurebreeze
Old Mar 13, 2012, 03:45 AM
fmkit is online now
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Are my Yagis the ugliest?
I get lightbulb lit within 20cm using AWM 500mw TX
fmkit is online now Find More Posts by fmkit
Old Mar 13, 2012, 04:21 AM
Registered FPVer :)
Joined Aug 2006
Please let me know where you get these LOW ESR tantalum capacitors for this price. I did a little search on Mouser.com - surely not the cheapest supplier, but also not that bad.
http://ch.mouser.com/Search/Refine.a...uF&NewSearch=1
There are variants, especially the LOW ESR ones which even cost > $5 per piece.
Seriousely, if you have a quality supplier with that cheap prices - please foreward it.
Markus
Old Mar 13, 2012, 04:29 AM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
fmkit - 2 element Yagi - but now you are back to linear mode.
Try a crossed Yagi and phase feed for C-P...
Yes, the ugliest on RCG
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Mar 13, 2012, 05:28 AM
FPV addicted
Romania, Bucharest
Joined Jul 2010
Markus
I don't know if they are really low ESR but these capacitors are better than nothing on that PCB
Old Mar 13, 2012, 05:38 AM
Registered FPVer :)
Joined Aug 2006
They seem to be pretty much ok to me. Thanks for this link. I so far had to spend a fortune on those suckers.
Markus
Old Mar 13, 2012, 08:51 AM
Thint1 is offline
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Markus
hi futurebreeze, Markus
as i would like to have the best filtering possible i searched a little bit for the capacitors.
the european distributors are a little bit crazy ... shipment costs up to 20,-- EUR
finally i bought on ebay .... 10 pcs for 2,99 pound and 1pound shipment.
http://www.ebay.co.uk/itm/1108311289...84.m1497.l2649
cheers Thomas
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari FPV Talk 7 Aug 12, 2013 12:48 AM
Cool Hobbyking has cheap 5.8ghz 200mW sets. SargeNZ FPV Talk 7 Mar 06, 2012 09:32 AM
Discussion 5.8ghz 200mw on Blade 120 SR - pics Vitamin_J FPV Talk 2 Mar 27, 2011 10:25 AM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV Equipment (FS/W) 1 Mar 22, 2011 08:01 PM
Sold 5.8GHz / 200mW Video Tx and Rx. New. Mr.RC-CAM FPV Equipment (FS/W) 1 Nov 02, 2010 09:07 PM
