Old Mar 11, 2012, 08:25 AM
edge0xc is offline
Find More Posts by edge0xc
Joined Sep 2011
hey,
i just got my 200mW TX, but it looks like, if there is something missing?
Is this normal?
Cheers
Alex
edge0xc is offline Find More Posts by edge0xc
Old Mar 11, 2012, 08:52 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
It's a decoupling capacitor, not critical
renatoa is offline Find More Posts by renatoa
Old Mar 11, 2012, 09:13 AM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
Originally Posted by edge0xc View Post
hey,
Is this normal?
Cheers
Alex
where did you get it from? Are all the missing capacitors coming from the same place?
whakahere is offline Find More Posts by whakahere
Old Mar 12, 2012, 04:12 AM
Peril is offline
Find More Posts by Peril
Jets Suck (and blow)
Peril's Avatar
Australia, QLD, Deception Bay
hey,
Is this normal?
Cheers
Alex
Now there's something, I was missing that cap too 12 months ago, I soldered one to mine just in case.
http://fpv-community.com/forum/showt...id=830&page=19
Peril is offline Find More Posts by Peril
Old Mar 12, 2012, 04:46 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Well so I got the tx module from foxtech..
I have written a few things below the pictures, please answer
Will it work even if it is damaged there?
msev is offline Find More Posts by msev
Old Mar 12, 2012, 05:05 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
It looks like a normal ground connection. Check a wiring diagram of the TX and I'm
sure you'll find it's normal.
Teamsherman is offline Find More Posts by Teamsherman
Old Mar 12, 2012, 05:13 AM
msev is offline
Joined Sep 2010
You were explaining the solder blobs right...What about that upper part of the pcb that looks like a small chinese mouse had a bite at it...does it look critical to you?
Old Mar 12, 2012, 05:37 AM
BCSaltchucker is online now
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
try it and see if it works. Doesn't look bad to me.
Among the foxtech 200mW: Anyone notice much difference in performance with the micro Tx as opposed to the regular sized Tx? I have a whole selection of these 5.8 Tx, and an extra micro Tx lying around which I might use for a larger aircraft.
BCSaltchucker is online now Find More Posts by BCSaltchucker
Old Mar 12, 2012, 06:03 AM
msev is offline
Joined Sep 2010
Can't try it since I haven't received the video receiver yet..
Here are some better pics for reference and advice
Old Mar 12, 2012, 08:32 AM
Papat is offline
Find More Posts by Papat
Pat K
The Netherlands
Joined Dec 2010
Both Tx and Rx I got from FPVHobby (Turkey) were having the same kind of bad screen soldering. I reworked them in order to have all ground connections properly connected to the PCB ground.
I have no clue how it would work with only 1 or 2 operating connections.
Papat is offline Find More Posts by Papat
Old Mar 12, 2012, 11:34 AM
msev is offline
Joined Sep 2010
So you are saying this is a critical pcb flaw? Should I issue a paypal dispute?
Old Mar 12, 2012, 12:04 PM
nkkromhof is offline
Find More Posts by nkkromhof
NKK for short...
nkkromhof's Avatar
United States, IN, Mitchell
Joined Oct 2010
Slightly off-topic, but this thread seems to be as good a place to ask as any:
When using a 5.8Ghz CP omni antenna, how high do you recommend raising the RX/antenna from the ground.
I'm sure "as high as possible" will be a popular answer, but I'm looking to balance practicality with maximizing range on the omni and I'm guessing there's a point of diminishing returns.
nkkromhof is offline Find More Posts by nkkromhof
Old Mar 12, 2012, 12:07 PM
renatoa is offline
Joined Sep 2007
No, you worry too much for no reason, the tin case is even optional, and will work ok without. It is not even needed as heatsing, the main heat pump is via the metalised pad near CHR3 text on the green PCB side.
The retail 200mW unit has no tin cover inside because it is covered by the radiator.
Old Mar 12, 2012, 12:09 PM
msev is offline
Joined Sep 2010
Renato what about my tx module, how does it look to you? Should I issue a paypal dispute?
Old Mar 12, 2012, 12:28 PM
renatoa is offline
Joined Sep 2007
No need to return, is the typical variation of Chinese (lack of) products quality.
The tin case is not required at all to be aligned with PCB at micron level and have impecable solder to work flawless.
The channel choice will affect you much more than redoing tin case soldering to look perfect.
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari FPV Talk 7 Aug 12, 2013 12:48 AM
Cool Hobbyking has cheap 5.8ghz 200mW sets. SargeNZ FPV Talk 7 Mar 06, 2012 09:32 AM
Discussion 5.8ghz 200mw on Blade 120 SR - pics Vitamin_J FPV Talk 2 Mar 27, 2011 10:25 AM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV Equipment (FS/W) 1 Mar 22, 2011 08:01 PM
Sold 5.8GHz / 200mW Video Tx and Rx. New. Mr.RC-CAM FPV Equipment (FS/W) 1 Nov 02, 2010 09:07 PM
