Old Mar 06, 2012, 06:47 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
So far, at least on paper they have a 5dB less sensitive receiver, which involve the need for three times more powerful transmiter to have the same range.
Again on paper, the set with 500mW Airwave transmitter should have same range versus the set subject of this thread, using 200mW transmitter.
Some manufacturers has a misterious preference to embed Airwave modules in their products, without any technical explanation of this choice. They claim in several places they use modified Airwave modules with improved performance, but in the online shop pages the specifications are still the same as the genuine Airwave modules.
When we switch from paper to facts, in real world I don't know any user video of a flight at least 9.6km done with an Airwave based system, as was the previous record of this thread for some months, before being busted by Romania team. I don't count manufacturers demo flights, I want to see user flights, with setup built by real users. Preferably with similar antennas, to not compare apples vs oranges.
renatoa is offline Find More Posts by renatoa
Old Mar 06, 2012, 07:43 AM
OMGFLY is offline
Find More Posts by OMGFLY
OMGFLY's Avatar
Joined Feb 2012
see it
OMGFLY is offline Find More Posts by OMGFLY
Site Sponsor
Old Mar 06, 2012, 07:53 AM
renatoa is offline
Joined Sep 2007
Spam ^^^
Old Mar 06, 2012, 09:17 AM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
I guess you could say the new modules have a different layout. The channel buttons are on the bottom but they are only from one shop and I haven't seen anyone use them.
I like these systems for ta few main reasons. They are also low power which really helps with the placement as it doesn't swamp other gear as much. People are showing that they can work well in a lot of situations. Stunt flying behind trees, long range, on copters. I don't see many people doing that on 5.8ghz airwave modules. I don't see many people talking about the 5.8ghz airwave systems. Most of the time i hear more people getting off those systems than staying with them. I know a lot more people using sky-rf systems and getting good results.
Team Romania sure beat Team Germany (as myself and rabe2000 both live in the same country). I don;t think I will ever challenge your record. My goal is still to go 10km as Markus123456 once said when we started looking at range on these modules that you should be able to fly 10km on these 200mw systems. It has been my personal goal since the beginning and I hope this summer to achieve that goal. I hope you guys can break the 20km barrier and fly home That would be a record and a half.
whakahere is offline Find More Posts by whakahere
Old Mar 06, 2012, 10:53 AM
Ceros007 is offline
Find More Posts by Ceros007
Ceros007's Avatar
Montreal, Québec, Canada
Joined Apr 2010
But I'm a little confuse. ReadyMadeRC have stop carrying the FoxTech 200mW because of the poor quality. I've seen a couple of people with blown up TX but here, you seem to be preaching this TX.
Are they all the same? I mean, is the HK 200mW the same as FoxTech or BEVRc?
Ceros007 is offline Find More Posts by Ceros007
Old Mar 06, 2012, 11:07 AM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
it is the 500mw that blows up. The 200mw doesn't even need the heatsink. There are a few minor issues with the 200mw, weight, connectors (ground on inside) and the rp-sma connectors.
foxtech and bever and hobbyking are all the same.
Old Mar 06, 2012, 11:55 AM
Ceros007 is offline
Ceros007's Avatar
Joined Apr 2010
Do you guys recommend them? Or you prefer an alternative version from somewhere else?
Old Mar 07, 2012, 03:01 AM
futurebreeze is offline
Find More Posts by futurebreeze
FPV addicted
futurebreeze's Avatar
Romania, Bucharest
Joined Jul 2010
I agree regarding the heatsink, I removed it from the beginning.
futurebreeze is offline Find More Posts by futurebreeze
Old Mar 07, 2012, 08:12 AM
BKMorpheus is offline
Find More Posts by BKMorpheus
BKMorpheus's Avatar
NRW, Germany
Joined Dec 2010
The 200mW version, yes! I like them very much (yesterday i reached 5km with a 10 turn helical and still got a solid picture).
Just make sure you use 2S for the receiver instead of 3s and if you use the tx power out for a cam, make sure the wires are colored correctly (i think some times + and - were labled wrong).
Then nothing will blow up. You also should have a look in the online-manual, to make sure your channels are matching (tx dip switch position is not equal rx dip switch position).
BKMorpheus is offline Find More Posts by BKMorpheus
Old Mar 07, 2012, 08:13 AM
v1ru3 is offline
Find More Posts by v1ru3
United States, GA, Roswell
Joined Jan 2012
guys, I'm really sorry for your loss
here's something that may help in similar situations.
it's under 50g if you remove the case, I'm sure with a small lipo will be even lighter.
v1ru3 is offline Find More Posts by v1ru3
Old Mar 07, 2012, 11:31 AM
Ceros007 is offline
Ceros007's Avatar
Joined Apr 2010
Originally Posted by v1ru3 View Post
guys, i'm really sorry for your loss
It's under 50g if you remove the case, i'm sure with a small lipo will be even lighter.
lol
.../old people/...
Old Mar 07, 2012, 11:47 AM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
Here's another solution for a lost model locator...
http://www.rcgroups.com/forums/showthread.php?t=1521561
or
http://fmtv.us/rf_beacon.html
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Mar 09, 2012, 01:19 AM
renatoa is offline
Joined Sep 2007
I seen rabe posted yesterday a video showing 4.5km using 25mW, with Airwave stuff.
If we upscale power this will equate to 12.7km using 200mW.
The difference to 15-18km could be either receiver, either antennas.
Anyway, same ballpark, the limits are reached for this band.
Old Mar 10, 2012, 06:09 AM
Martinba77 is offline
Find More Posts by Martinba77
Always soldering
Joined Dec 2011
I wondering what one can achieve with one of this :
http://www.superpass.com/SPPJ48W.html
And a dipole or something on the VTx.
Off course this is linear polarization and maybe doesnt count here?
Men I would love to have one of this to try...or maybe a 27dB grid like this one:
http://www.l-com.com/item.aspx?id=33970
Martin
Martinba77 is offline Find More Posts by Martinba77
Old Mar 10, 2012, 11:55 AM
renatoa is offline
Joined Sep 2007
Just for ... the record ? pun intended
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari FPV Talk 7 Aug 12, 2013 12:48 AM
Cool Hobbyking has cheap 5.8ghz 200mW sets. SargeNZ FPV Talk 7 Mar 06, 2012 09:32 AM
Discussion 5.8ghz 200mw on Blade 120 SR - pics Vitamin_J FPV Talk 2 Mar 27, 2011 10:25 AM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV Equipment (FS/W) 1 Mar 22, 2011 08:01 PM
Sold 5.8GHz / 200mW Video Tx and Rx. New. Mr.RC-CAM FPV Equipment (FS/W) 1 Nov 02, 2010 09:07 PM
