Old Mar 05, 2012, 01:32 PM
Martinba77 is offline
Find More Posts by Martinba77
Always soldering
Joined Dec 2011
Nice tip costi_n, thanks for sharing!
Martin
Martinba77 is offline Find More Posts by Martinba77
Old Mar 05, 2012, 01:35 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by costi_n View Post
Hello guys. I wanna show you a simple method to tune your helix if you already have a SWR-meter or a professional VNA. For me that method works. I tuned the helix for a 1:1.2 SWR which is very good for a DIY antenna .
After building the antenna from mictronics thread on FPVlab
http://fpvlab.com/forums/showthread....Y-5.8GHz-Helix
I found that is very difficult to move the wave trap to the first turn to find the best match. I tried for several times, I found the best place for wave trap, but after secured the solder, the match was gone so...I cut a little piece of FR4 board, about 3X4mm, put down on the reflector under first turn and move slowly forward and backward to find the best match. Pay attention not to touch the turn with FR4 board piece. If you are still not able to find the best match try to move the feed point higher or lower. For me that method worked.
That's a really good idea! I never thought of moving the base plate. I always moved the first 1/4 turn. I need your name because this matching technique deserves your name on it.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 05, 2012, 01:57 PM
costi_n is offline
Find More Posts by costi_n
Romania, Bucuresti, Bucharest
Joined Dec 2010
-Alex
Tnx Alex. My name is Costin
It would be really nice if someone with an professional VNA will try this tuning method and post some screen of analyzer.
I don't have a VNA, it costs more than my car with my wife inside.
costi_n is offline Find More Posts by costi_n
Old Mar 05, 2012, 03:05 PM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
Markus123456 has a spectrum analyzer and I sure when he has time he will try it out.
I am really interested in the board. I have a few modules myself and i would love to put them on my smaller planes. 15grams plus a light weight camera and all up I would add very little weight. I hope for under 30 grams with an e-osd. I would put a rp-sma because I have so much damn rp cable Sounds like a great dyi project and if you need someone to test your board (I'll use my modules etc) just let me know.
thanks for the tip on tuning too. I am going to try that with a few helicals I have!
whakahere is offline Find More Posts by whakahere
Old Mar 05, 2012, 06:54 PM
papa_lazerous is offline
Find More Posts by papa_lazerous
papa_lazerous's Avatar
United Kingdom, Southend-on-Sea
Joined Feb 2011
Where are you guys buying the 200mW module?
papa_lazerous is offline Find More Posts by papa_lazerous
Old Mar 06, 2012, 01:15 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
They are all the same, the source is not important, fortunatelly the unique mfr of these modules make the final user job easier.
But beware to not get Airwave modules instead, those are indeed other story.
renatoa is online now Find More Posts by renatoa
Old Mar 06, 2012, 02:15 AM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
@ papa_lazerous
http://www.foxtechfpv.com/fpv-equipm...t-c-70_76.html
Don't bother with the 500mW version though
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Mar 06, 2012, 03:26 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
They are not all the same.
Two main things to consider. a) Band strapping. Most modules sold are strapped to band "e", but i.e. RangeVideo sells modules (and matching RC305 receivers) strapped to band "a". The modules can be opened. I posted a way to modify them some months ago.
b) voltage regulation. There are variants of this module around with an aditional internal 3.3v linear regulator. Most modules don't have that.
The one refered to is band "e" without voltage regulator. That's the most frequently seen incarnation of this module.
Markus
markus123456 is offline Find More Posts by markus123456
Old Mar 06, 2012, 03:35 AM
Joined Sep 2007
You know very well what I meant
Old Mar 06, 2012, 03:50 AM
costi_n is offline
Joined Dec 2010
All the modules are identical, the band is a PLL selection feature, not a hardware change. The fpvhobby version internal LDO also could be external as well, not worth the 100% price increase anyway
Old Mar 06, 2012, 04:59 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
On a related subject , has anyone tried writing SPI PLL rather than using set frequencies?
To use the rx module with higher power airwave tx modules?
I have the data sheets for both tx and rx, but have never changed frequencies with these modules. It doesn't look too bad for someone who could code pic/avr/arduino even. They are very kind and even give you default settings for 5.8ghz...! any takers...
Shikra is offline Find More Posts by Shikra
Old Mar 06, 2012, 05:00 AM
Devonboy is offline
SW England
Joined Aug 2009
I also disagree that all the modules are the same. OK, very broadly they are the same, but there are differences and that small difference is a huge one !!
The PLL is changed by a hardware link (0402 SMD pull down resistor) and the module does need opening up to make the band change.
I did add some description in this thread and also made a 'how to' in the FPVUK forum, here
http://www.fpvuk.org/forum/index.php?topic=4163.0
Nigel.
Old Mar 06, 2012, 05:24 AM
Registered FPVer :)
Joined Aug 2006
Errr, the band is selected using internall straping resistors as you know, the internal LDO is also a component that is stuffed or not inside the modules housing. I do consider this to be different, at least for the average RC-Groups user. Depending on where you buy them, the price does not matter. I formyself also use the standard Band E modules, but stating here they are all the same could lead some beginner to try to combine i.e. a Band A module from RangeVideo with a standard Band E Rc305 leading to a tuff time for said beginner IMHO. It's all about not posting inadequate information. Not every reader here is electronics savey.
Markus
Old Mar 06, 2012, 06:03 AM
costi_n is offline
Joined Dec 2010
Markus
Yes, from this perspective you're right. I stated they are identical from another point of view.
cheers
Old Mar 06, 2012, 06:29 AM
Ceros007 is offline
Find More Posts by Ceros007
Ceros007's Avatar
Montreal, Québec, Canada
Joined Apr 2010
What you mean with the airwaves modules? Not good?
Ceros007 is offline Find More Posts by Ceros007
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari FPV Talk 7 Aug 12, 2013 12:48 AM
Cool Hobbyking has cheap 5.8ghz 200mW sets. SargeNZ FPV Talk 7 Mar 06, 2012 09:32 AM
Discussion 5.8ghz 200mw on Blade 120 SR - pics Vitamin_J FPV Talk 2 Mar 27, 2011 10:25 AM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV Equipment (FS/W) 1 Mar 22, 2011 08:01 PM
Sold 5.8GHz / 200mW Video Tx and Rx. New. Mr.RC-CAM FPV Equipment (FS/W) 1 Nov 02, 2010 09:07 PM
