Old Feb 06, 2012, 04:29 PM
Farmer_Joe is offline
Find More Posts by Farmer_Joe
RC Farmer
Farmer_Joe's Avatar
Joined Aug 2011
Guys what element on the picture will need additional cooling if i increase the voltage to the module?
Farmer_Joe is offline Find More Posts by Farmer_Joe
Old Feb 06, 2012, 04:48 PM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
For long life of the module, feed it with 3.3v.
Cheap as you like
http://www.hobbyking.com/hobbyking/s...ly_6_23v_.html
Much better than a failed module during a flight...
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Feb 06, 2012, 05:02 PM
RC Farmer
Farmer_Joe's Avatar
Joined Aug 2011
Yes i agree with you, but if you apply proper heat transfer from hot component, you could drive it with slightly higher voltage, like 3.7V... On the original 200mw completed TX you just need to change resistor divider that dictates output voltage.
Old Feb 06, 2012, 05:19 PM
_Sibi_ is offline
Find More Posts by _Sibi_
_Sibi_'s Avatar
Joined Aug 2008
Uhhm, could anybody post a picture which resistor you will need to change on the foxtech 200mW Tx to apply 3.3V to module? I've sort of missed that post...
ty.
regards,
Sibi
_Sibi_ is offline Find More Posts by _Sibi_
Old Feb 06, 2012, 05:22 PM
RC Farmer
Farmer_Joe's Avatar
Joined Aug 2011
There is already 3.23V on the module on my stock TX.... You don't need to change anything.
Old Feb 06, 2012, 05:23 PM
_Sibi_ is offline
_Sibi_'s Avatar
Joined Aug 2008
ahh alright thanks!
Old Feb 07, 2012, 06:32 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
The upper right corner chip in the first picture is the final PA of this module.
On the opposite side you will find a cluster (circled in red) of metalized through holes, that is the heat pump point, where the whole heat of this module is dissipated outside. The whole ground plane around that point, under the green mask, is actually the real module heatsink, not the tin cover, as some might think.
renatoa is online now Find More Posts by renatoa
Old Feb 07, 2012, 07:04 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
So that metalic rectangle located to the bottom right of the top picture needs cooling right.
msev is offline Find More Posts by msev
Old Feb 07, 2012, 07:05 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Nope, that's the oscillator. The upper black small square chip in the UPPER right of the picture.
Markus
markus123456 is offline Find More Posts by markus123456
Old Feb 07, 2012, 07:32 AM
msev is offline
Joined Sep 2010
So we need to put the heatsink directly on the chip or on the opposite side of the pcb (where Renato draw his circle)...
So the tin case of this module doesn't help in transfering the heat and if would not be beneficial to add a heatsink on it..
Old Feb 07, 2012, 07:59 AM
Registered FPVer :)
Joined Aug 2006
The so called 500mW variant of the transmitter does something similar. The chip is rated for what it's used with the module and if so does not need a special heatsink. The modules are actually pretty much ok with this regard. They get hand warm which is ok.
If you intend to overdrive it by supplying a higher voltage you can - acording to Renato - squeeze some mW more out of it, but remember, to double the range, you have to have four times the power. So going from 200mW to 250mW or even 300mW won't buy you so much more really. What it does buy you though is the increased risk of a failure. This module, with standard power and propper antennas is good for 15km and more of range. Unless you are after breaking the 5.8Ghz distance record, I really wonder why you think you need a heatsink?
If you want to add a heatsink because you intend to embedd this module deep into isolating foam or such of a fuselage, then you maybe could add one, but for this purpose adding one to the metal can type of cover should be sufficient as this cover is nicely connected to the ground planes on both sides of the PCB which as Renato correctly mentioned also serve as a heatsink.
I made the experience that exposing the metal can a little bit to the air or even a fuselage internal slight airflow is aboslutely sufficient provided you don't overpower it.
Markus
Old Feb 07, 2012, 08:38 PM
Pisces is offline
Find More Posts by Pisces
The Dreamer
Pisces's Avatar
Sydney, Australia
Joined Dec 2010
@markus123456
Very well explained and correct 100% in my humble opinion. . Beware of overdriving IC beyond the manufacturers spec or you run the risk of a premature failure.
Note also I have commented in other post that the antenna VSWR is an important consideration. A poor Antenna VSWR will reflect power back into the RF amplifier output transistors and add more watts and cause the transistor to overheat and fail.
Heat is the enemy of silicon chip and causes either instantaneous failure and or long term failure of the IC transistor.
Lindsay
Pisces is offline Find More Posts by Pisces
Old Feb 08, 2012, 02:44 AM
msev is offline
Joined Sep 2010
I didn't intend on doing it all the time, maybe once a year ...And I even don't have the equipment, so I'm just asking...And you've read that Renato has been using his module for over a year on 4.2 volts and he hasn't got any problems...But yes I agree the difference in distance would be very small...But would be interesting to see just as an experiment.
Again I don't have any equipment yet except the camera
Old Feb 08, 2012, 04:40 AM
Pisces is offline
The Dreamer
Pisces's Avatar
Sydney, Australia
Joined Dec 2010
RC305 BCD Rotary Switch Mod.
I have replaced the RC305 ch switch with a BCD rotary switch.
Reason is so I can easily scan the channel number and check for adjacent channel interference.
This mod makes it easier to find out what channel other guys are set to before taking to the air.
This photo is a 10 position BCD 4 line switch. Also available is a 16 position BCD switch same footprint.
FYI
Old Feb 08, 2012, 03:34 PM
cactus is offline
Find More Posts by cactus
United States, CO, Durango
Joined Sep 2001
Originally Posted by whakahere View Post
Just used the helical. it is easy to stay in the beam of a 4 turn. 6 turn I don't have to many problems either. The 4 turn has a wide angle to it. I have even flown close behind myself no worries.
In the first post where I did 5.1km was a 6 turn helical. At the end of it I was playing with the edges.
My new model I made straps to my head too .... so when I get off target i move my head. Antenna tracker kiwi style.
I know this is an old post but I am wanting to go back to using my 200mw 5.8ghz gear on my quadcopter for the more compact antenna size. I currently use 300mw 1280 CL/SPW set but the size of the CL on the quad is just too big and fragile. So I do not want to invest in diversity, so If I put my 5.8ghz 200mw CL setup back on the quad and used a single 5 turn helical on the Rx, how far to the sides and behind me can I realistically go? 200M?
cactus is offline Find More Posts by cactus
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari FPV Talk 7 Aug 12, 2013 12:48 AM
Cool Hobbyking has cheap 5.8ghz 200mW sets. SargeNZ FPV Talk 7 Mar 06, 2012 09:32 AM
Discussion 5.8ghz 200mw on Blade 120 SR - pics Vitamin_J FPV Talk 2 Mar 27, 2011 10:25 AM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV Equipment (FS/W) 1 Mar 22, 2011 08:01 PM
Sold 5.8GHz / 200mW Video Tx and Rx. New. Mr.RC-CAM FPV Equipment (FS/W) 1 Nov 02, 2010 09:07 PM
