Old Aug 30, 2011, 06:59 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Guys so which is the current price/performance favourite when it comes to 5.8ghz 200mW? It's this one right: http://www.hobbyking.com/hobbyking/s...dproduct=15295
Why are there bad reviews at the top...
msev is offline Find More Posts by msev
Old Aug 30, 2011, 07:09 AM
aSa2 is offline
Find More Posts by aSa2
Joined May 2010
Hi, maybe not the right place, but ...
Does any of you have a link to DIY diversity controller?
aSa2 is offline Find More Posts by aSa2
Old Aug 30, 2011, 08:20 AM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
Well because hobbyking give no documents with it. no worries though as they are the same units sold at foxtechfpv.com and bevrc.com
We are using the same ones but NOT with those antennas. We all use CP antennas as the stock are pointless. But don't throw them away as you can rip off the cap and then use that cable to make your own cp antennas.
whakahere is offline Find More Posts by whakahere
Old Aug 30, 2011, 08:22 AM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
of course .. click on IBCrazy's name .... they are all there!
Old Aug 30, 2011, 09:32 AM
msev is offline
Joined Sep 2010
I am aware of the goodness of CP antenna's ....that unit that we are talking about, it can be powered from a seperate video battery right (would 2S do? how big battery do I need for the vtx)...what about vrx battery (2S or 3S)..I know the stock antennas are generally bad but has anyone tried increasing the range with a windsurfer reflector (scrtsqrl had good success with a windsurfer on 2.4ghz)...
Old Aug 30, 2011, 01:11 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
the video tx and rx can both be powered from s2. I run my plane on s3 because of the camera needing 12 volts but I use s2 on the ground as it keeps my fatshark cooler. On the ground I run a 800mah for the receiver and goggles for an hour. In the plane I run a 1 battery system, all on s3.
No idea about the windsurfer but since it remains linear I am going nowhere near it. I have a 5.8ghz patch which I never use. I get much better results from CP antennas.
Old Aug 30, 2011, 01:13 PM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
You can power the rx with a 2s battery, and you also could use a dedicated battery for the tx, but there is no problem with powering the tx directly from your 3s flight battery.
Don't even bother with a windsurfer etc. Get CP antennas as others mentioned. It's a quantum leap and especially with 5.8Ghz reflections will otherwise kill you.
Markus
markus123456 is offline Find More Posts by markus123456
Old Aug 30, 2011, 01:18 PM
msev is offline
Joined Sep 2010
I think you guys should also try the turbine cp antenna, just for scientific purpuses
What's the beam width for a 6 turn helical? With such a small antenna aiming must be pretty delicate right?
Theoretical question, if I were to make also a cp omni for rc (both on receiver and transmitter), what range could I achieve, the power output is probably 100mW (turnigy 9x)...Some guys get even 3km from the 9x with the stock antennas, how is that possible?
Old Aug 30, 2011, 01:24 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
not really. Look at my video on the front page. At the end I am in pretty close going sideways. .5km and all still good.
I would love to try the turbine. It seems like a great antenna
Old Aug 30, 2011, 01:27 PM
msev is offline
Joined Sep 2010
But it looks very hard to make
Old Aug 30, 2011, 01:42 PM
Registered FPVer :)
Joined Aug 2006
The turbine and virewent etc. antennas are great also. Those antennas are fairly compareable in performance with a CL or SPW. The "hard to make" has it's reflection in the price Hugo asks for one.
I'm currently experimenting a lot and I will share my findings once I have completed the test round I started.
Markus
Old Aug 30, 2011, 02:45 PM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
You tried them?
-Hugo
Hugeone is offline Find More Posts by Hugeone
Old Aug 30, 2011, 02:47 PM
rabe2000 is offline
Find More Posts by rabe2000
Joined Jan 2011
Originally Posted by Trnquill View Post
Can you post your setup, especially 1) what camera and 2) what recorder? I think the pic quality looks exceptionally good! Best I've ever seen.
Thanx.
Cam is a 600TVL from kamera2000.com
(http://www.kamera2000.com/products/6...8mm-Linse.html )
Recorder is 2,5" DVR, RM RMVB REKORDER Multimedia 2.5 HDD PLAYER RECORDER 3 (not availiable anymore, i think)
( http://cgi.ebay.de/ws/eBayISAPI.dll?...#ht_5102wt_906)
Originally Posted by whakahere View Post
I think he is using a 6 turn helical. They are easy to build too Once you get them up and going you won't turn back. I am very happy with the performance and I am going to build another with a wave trap setup.
@rabe2000 you said you were getting some interference ... blueangle posted this
http://www.rcgroups.com/forums/showp...5&postcount=24
try picking a band that is outside the wifi area. Here in europe I use band 5. 5885mhz
oh, are you using an antenna tracker?
Was my new 14-turn Helical, but had also video with the 8-turn (bit worse).
Yes, use a Tracker, EagleEyes.
Originally Posted by Farmer_Joe View Post
rabe2000 - great achivent!! It looks i missed it, how many turns on the helix?
Thanx. 14 turns.
Originally Posted by IBCrazy View Post
Congrats rabe2000! Keep pushing the limits, guys. I'm sure you'll get even further in future flights.
-Alex
Thanx Alex. Without your work this would not have been possible.
I have to thank you for your published How-to's.
Hopefully with the Guardian my RTH works fine, then I will try the 10 km.
rabe2000 is offline Find More Posts by rabe2000
Old Aug 30, 2011, 03:11 PM
Registered FPVer :)
Joined Aug 2006
Originally Posted by Hugeone View Post
You tried them?
-Hugo
Hugo,
I built a virevent and tried it. I am in the process of trying your other designs too. They are great Hugo, really, no offense. All our optimisations we do here lead to better results, but the biggest change I experienced so far was going from linear to circular polarized antennas. This is IMHO a must for anyone trying to do FPV on 5.8Ghz (which is what this thread is about). The difference between a FINE TUNED CL or SPW and a virevent and your other designs is subject to ongoing tests I'm performing whenever possible.
My admitedly so far only quick and dirty comparison tests revealed that the difference in performance among those CP antennas - provided they are really made well and fine tuned - is not THAT big that it would justify the bigger building efforts. Those are my prelimenary findings, and I intentionally tried to stay vague in my previous post because I really truly in depth test all those antennas. These tests - as you may know from personal experience - take a lot of time. Rest assured that I for myself will go to the bottom of all this, doing whatever it takes.
I may should not have said anything at this still early point in time as I haven't come to a final conclusion, so I'm sorry for this. However, someone starting with FPV on 5.8Ghz like the poster to which I replied can't go wrong with omni directional CP antennas no matter if he opt's for a CL/SPW pair or your antennas.
Markus
Old Aug 30, 2011, 03:56 PM
Hugeone is offline
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
These tests - as you may know from personal experience - takes a lot of times
Yes, it been 6 months of almost everyday testing/simulating and I'm still perfecting the design. Also, some new stuff is born from that work that will be released later this year.
Keep us posted Markus.
-Hugo
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari FPV Talk 7 Aug 12, 2013 12:48 AM
Cool Hobbyking has cheap 5.8ghz 200mW sets. SargeNZ FPV Talk 7 Mar 06, 2012 09:32 AM
Discussion 5.8ghz 200mw on Blade 120 SR - pics Vitamin_J FPV Talk 2 Mar 27, 2011 10:25 AM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV Equipment (FS/W) 1 Mar 22, 2011 08:01 PM
Sold 5.8GHz / 200mW Video Tx and Rx. New. Mr.RC-CAM FPV Equipment (FS/W) 1 Nov 02, 2010 09:07 PM
