Hehe, maybe you are right about flying with linear antennas some times to keep in mind why we switched over to CP antennas
![]() I am uploading a new video at the moment. Sadly my last flight in over 700m altitude was not recorded but i got some nice air-footage from the flying wing of my buddy. edit: done
Joined Jan 2010
So whats been happening lately with the 5.8ghz 200mw systems?
Im new to fpv and iv gone with Team blacksheeps' rule that the video frequency must be higher than the radio frequency. since im using 2.4ghz, 5.8ghz is the only option and I went with the 200mw tx rc305 reciever. Iv pretty much read the whole thread and I have learnt alot. Im glad I went with this system! I will be building some cp antenna's soon=) |
![]() SCNR Markus |
Long range became not as much fun because it too far to pick up the plane after going crazy
![]() For those that say you can't fly behind things .... then they haven't tried!
I will fly long range again but as of right now I find keeping things close and flying around everything improves my overall flying better than flying high and far. |
I've managed to get out to 6km so far with a 6 turn helical with a wavetrap match on it and a clover on the plane. definitely could go further at least another 1 km or more only limitation in the end was the size of the battery in the plane I was using on the day. helical was built using 16mm dowel with 12.5mm spacing and 1.25mm coil winding wire http://www.youtube.com/watch?v=mty_DR9YFsc
Impressed as your video looked pretty clear for a long time! |
I was able to have about 3 flights this past weekend with my Radian. Running Dragon link and 5.8, Immerson 600mW transimitter with CL antenna. My first flight sucked bad with black outs. I corrected that by getting my ezOSD away from the motor. 2nd flight much better but was not getting the distance with sharp picture at about 609.6 meters/2000'. Ground station I am running diversity with SPW antenna and 8dBi patch. The Patch and SPW are close together (less than 1 foot). The patch is set up for tracking. This may be my biggest problem... but not sure yet. I have moved my CL tx antenna further away from DL antenna (off of the fuse onto the wing). I will plan on shutting down the Patch and see how things do with the just the CL and SPW. Seeing that you have gotten near 4km and I am struggling to get 1km. I notice you had installed CL under your wing. Did you at one time have it on the top and noticed it does better underneath the wing? Help appreciated, I hope to make corrections and get a chance to fly this weekend. |
Try without the patch installed and see what happens. Linear and CP antennas are not the best mix. Also show us a picture of your layout. Sometimes it is the location you have everything that can effect your performance. Since 5.8ghz signal doesn;t like to be blocked it generally work better if you can mount it where nothing gets in the way. Under the plane often can be a very good option. |
Today I tested out some antenna built by Markus123456. they were tuned on the 5885mhz band. I ended up getting a max of 3km before I lost picture. I tried in all direction around me to see if it could have been noise issue but I was stuck at the 3km barrier. The weather was not the greatest overall for 5.8ghz though. It was so damn humid that there was a haze over everything. This does effect the range on 5.8ghz ... hell even my noes were sweeting in sandals
!I did notice that a few things from my tests. One was the null above me was smaller, and the rejection when doing low flying was much much better than my home builds. The picture remained 100% for about 300 meters but I was expecting something like this with the weather I was flying in. In hot dry days with low humidity the clear range gets at least 1km. If anyone is looking for great preforming antennas i would recommend Markus123456 fully. They are great. I just need to fly on a better day to see if I can break the 4km mark. Damn this crappy weather. I am making a video now and I will post it when I am done. |
| Thread Tools | |
| Cool Hobbyking has cheap 5.8ghz 200mW sets. | SargeNZ | Video Piloting (FPV/RPV) | 7 | Mar 06, 2012 09:32 AM |
| Discussion 5.8ghz 200mw on Blade 120 SR - pics | Vitamin_J | Video Piloting (FPV/RPV) | 2 | Mar 27, 2011 10:25 AM |
| Help! Poor range: Identifiy this 5.8Ghz(?) antenna | nosaari | Video Piloting (FPV/RPV) | 6 | Mar 26, 2011 02:25 PM |
| Sold FPV a/v system 5.8ghz 200mW NEW | karolpenconek | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Mar 22, 2011 08:01 PM |
| Sold 5.8GHz / 200mW Video Tx and Rx. New. | Mr.RC-CAM | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Nov 02, 2010 09:07 PM |
